    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • n000bieN
      n000bie
      Hi Fredo, thanks for your prompt reply.
      I'm posting below some screen shots showing my problem, along with my model, fyi πŸ˜„ .
      I guess a bit more explanation should help : I've managed to get this model as and OBJ file, along with material settings, then easy to re-composing the model with its maps by using 3D-Max, since there is no UVW Map Unwrap/Re mapping tool in Sketchup. But for the model developing/shape editing works, I've always used Sketchup (my 3D Max skill just not enough).
      So then I found out the model is kind of "squeezed" by some perspective-affection, making it not in an ISO-3D form, but actually into a Perspective form (like a cubic box with front face is bigger than back face - following perspective rule of view). Thought it'd be easy to tweak it with Tapering Scale, but .. things just not easy as it seems to be, hah.
      Again, appreciated your help and thank you.
      Head test 3.skp
      • n000bieN
        n000bie
        Just want to add : properly you will find the model looks just fine, but I have other parts/ models that is worse affected, just posting here the one I'm currently working on. Thanks.
        • E
          Einstein
          Hi!
          I think "Twisting" could be added to the manual. It takes a while to find out that TAB brings slicing settings πŸ˜‰
          Or there could be a hint in the left-bottom corner of UI "press TAB to set slicing params"
          • E
            Einstein
            Hi!
            I am using Box Tapering. Is it possible to orientate the deformation box to bounding box instead of "best-fitting"?
            • fredo6F
              @einstein said:
              Hi!
              Just find an edge or a face in the model which has the proper direction and click on it to orientate the box.
              You can also type Arrow Up, which default to the XYZ bounding box along axis.
              • E
                Einstein
                Hi!
                I have an idea for next upgrade.
                As you can see in the picture, if I apply Box Tapering on a bunch of loose edges (not grouped), the content is copied and only then transformed. What if we could use it as a "sculpting" tool? I mean such behaviour that geometry is not copied, just transformed with its connected edges staying connected, so it would be "content aware". In the illustrated case changes would apply to the mesh.
                FredoScale.skp
                • L
                  Lopismagic
                  You are just a f***ing genius.
                  Merci, merci, merci.
                  • E
                    Einstein
                    Hi!
                    I have problem matching deformation box to my group's bounding box. Normally it goes by clicking an edge of a target group but my group is rotated and mesh is more complicated (not just cuboid) so clicking one edge doesn't do proper matching. Is there an option like "match deformation box to gruop's bounding box"? so that deformation box would be matched just as with normal scale tool.
                    • H
                      Hafer
                      Hi Fredo, muchos gracias for this awesome plugin!
                      Recently I stumbled upon a problem. Aiming at stretching models of woodworking furniture (say, a bookcase) to individual sizes (width, depth, height) the standard method of SketchUp (Scale) scales everything evenly, that is, the thickness of the material, the hardware, the proportions of moldings etc.) which renders it useless. Stretching with FredoScale does exactly, what I looked for. However, after applying that function kind of disintegrates the model, respectivly make multiple used components unique. That is, before using that function, changing one instance of the component A changes every instances of A - intended behavior. After using that function, changing one instance of the component A does not change the other instances. Whoops!
                      Ist there
                      (a) something I'm doing plain wrong?
                      (b) some limitation with your plugin?
                      (c) another way to stretch models along an imaginary section through the model?
                      Thanks in advance!
                        Ist there
                        Yes. It sounds like you aren't opening the component for editing before running Box Stretching. If you were going to modify the components with other tools, you would need to open one instance for editing first. You need to do the same with Fredoscale as well.
                        Not anymore limitation than any other tool has for modifying components.
                        It can be done with native Move tool. Select the geometry that needs to move with the dimension change and use the Move tool to move that by the required distance.
                        • fredo6F
                          NEW RELEASE: FredoScale v3.1a - 18 Dec 18
                          Requirement: LibFredo6 8.7a
                          FredoScale 3.1a provides a Quick Launcher for all FredoScale tools. The divider is also enabled by default for the Stretch tool.
                          Home Page of FredoScale for information and Download.
                          Main post of this FredoScale thread.
                            rv1974
                            Fredo,
                            Maybe I as usual miss something but I thought it'd be a great improvement if there was an option to pull the grip and then input a number with +- with units abbreviation. Say +50cm.
                            And the tool would incrementally add 50cm in ordered direction. It'd be super awesome if it could add (those 50cm) to multiple objects simultaneously.
                            P.S. I attach something with some overhelming features, maybe it could be interesting for you
                            • fredo6F
                              @rv1974 said:
                              Fredo,
                              It's difficult to do it in the VCB because FredOscale would not know if you talk about the scale factor or the dimension, and in absolute or relative term.
                              What you can do currently is
                              • hover a handle
                              • Press TAB
                              • you get a dialog box where you the dimension(s), one, two or three fields depending on the active handle.
                              Since formulas are supported in the dimension fields you can modify the field and type "+50" or "+50cm".
                                rv1974
                                FredoScale fails to pick up the right reference data when objects are deep in the context. When I, for experiment sake, pull the objects out of contect, the tool works smoothly. Was this problem discussed earlier?
                                the objects are out of context- referencing is OK.
                                the objects are deep in context. referencing fails.
                                Standard scale- referencing is perfect
                                • fredo6F
                                  Yes. This is a bug which is on my list. This happens when you try to get the inference from an object which is another instance from the component you scale. My code for avoiding self-referencing need to be adjusted.
                                    milenoliegsalz
                                    @rv1974 & @fredo6
                                    I noticed that when you use "box stretching to target" (that is, when you double click the control boxes), Inferencing usually works fine... even with objects outside the group (nevertheless it would be nice if it would work without using "box stretching to target").
                                    @fredo6
                                    When I scale any components (with box stretching), Fredoscale makes it a unique component. This is reasonable when I just scale one component, but if I scale two or more of the same component and at the same time, it would be nice if they still stay as the same, and don't become unique.
                                    Thanks for your hard work.
                                    Greetings,
                                    Mileno.
                                      rv1974
                                      @Mileno no help from double clicking on my end
                                        rv1974
                                        Penny has dropped:
                                        click black grip->then click 1st referece point->finally click 'where-to' point.
                                        This way it works perfectly.
                                        Thank you Fredo
                                        • N
                                          nesh70
                                          Hi!
                                          I'm trying to bend a piano keyboard into a closed circle.
                                          Is it possible to do using the Radial Bend tool?
                                          I'm not figuring out what the target point is.
                                          • fredo6F
                                            @nesh70 said:
                                            Hi!
                                            Not possible. Maximum is 180 degree, that is a U-turn
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 58
                                            • 59
                                            • 49 / 59
