    Multiple offset.
    13 Posts 9 Posters 21.2k Views 9 Watching
      remus
      Spot on mock up jakob πŸ‘ exactly what i was thinking of.
        drewpoeppel
        Indeed, would be nice. I'm not code savy but you'd think it wouldn't be that hard to implement.
        • jujuJ Offline
          juju
          Make a component and replace other faces with same. Whatever you do to one will show on the others. You can always explode again later if you wish.
          • plot-parisP Offline
            plot-paris
            but that only works if the faces are all the same shape; and you have to create components first, which is another step in the workflow.
            we want this function all the time - simply an enhancement of the offset (and push/pull) tool's functionality...
            • jujuJ Offline
              juju
              O I C
                Must be doable by ruby since the bevel plugin also offsets all the faces.
                  plot-paris
                  ...and "normal push/pull" is basically what I asked for the push/pull tool to do
                  • fredo6F Offline
                    @remus said:
                    Itd be really useful if the offset tool could handle multiple faces at once. i.e. you select 2 faces then SU offsets both as if you had done each one separately.
                    Interesting ideas, in particular the multiple offset option (like the rings I use for Shape On Surface). Unfortunately, the OffsetOnSurface does it only on faces that are not connected (if they are, it will consider them as part of the same surface). However JPP, using the option Normal Push Pull does it on multiple face selection, whether connected or not.
                    Of course, very easy to do in Ruby, especially if this is only for individual faces.
                    • eidam655E Offline
                      eidam655
                      bump πŸ˜„ does a similar plugin exist already? or am i just bad at googling? πŸ˜„
                      I'm using SketchUp 2017, V-Ray 3.4
                        Did you try searching here for 'multiple offset'? When I did I got this which installs very nicely with the SketchUcation Extension Store tool.
                        Click on the picture.
                          Yes SDmitch plugin rules! It's me who have ask to him to make this sort of detailed thing! πŸ˜‰
                          http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=21345;image
                          Use also with it the special "PushPull" (gives me some minute to refind it! πŸ˜„
                          Ok It was Step Extrude! πŸ˜‰
