πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Multiple offset.
13 Posts 9 Posters 20.0k Views
    remus
    Itd be really useful if the offset tool could handle multiple faces at once. i.e. you select 2 faces then SU offsets both as if you had done each one separately.
      plot-paris
      **would be sleak indeed!(**the same for push/pull as well).
      and in addition to that the array function would speed up things considerably...
      the workflow would look something like this then:
      http://img180.imageshack.us/img180/1394/advancedoffsetep1.jpg
        remus
        Spot on mock up jakob πŸ‘ exactly what i was thinking of.
          drewpoeppel
          Indeed, would be nice. I'm not code savy but you'd think it wouldn't be that hard to implement.
            juju
            Make a component and replace other faces with same. Whatever you do to one will show on the others. You can always explode again later if you wish.
              plot-paris
              but that only works if the faces are all the same shape; and you have to create components first, which is another step in the workflow.
              we want this function all the time - simply an enhancement of the offset (and push/pull) tool's functionality...
                juju
                O I C
                  Must be doable by ruby since the bevel plugin also offsets all the faces.
                    plot-paris
                    ...and "normal push/pull" is basically what I asked for the push/pull tool to do
                    • F Offline
                      Interesting ideas, in particular the multiple offset option (like the rings I use for Shape On Surface). Unfortunately, the OffsetOnSurface does it only on faces that are not connected (if they are, it will consider them as part of the same surface). However JPP, using the option Normal Push Pull does it on multiple face selection, whether connected or not.
                      Of course, very easy to do in Ruby, especially if this is only for individual faces.
                      • E Offline
                        eidam655
                        bump πŸ˜„ does a similar plugin exist already? or am i just bad at googling? πŸ˜„
                        I'm using SketchUp 2017, V-Ray 3.4
                          Did you try searching here for 'multiple offset'? When I did I got this which installs very nicely with the SketchUcation Extension Store tool.
                          Click on the picture.
                            Yes SDmitch plugin rules! It's me who have ask to him to make this sort of detailed thing! πŸ˜‰
                            http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=21345;image
                            Use also with it the special "PushPull" (gives me some minute to refind it! πŸ˜„
                            Ok It was Step Extrude! πŸ˜‰
