    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 697.9k Views 151 Watching
    • N
      numerobis
      @fredo6 said:
      What do you mean exactly by storing "material id"
      I mean material IDs like in other other programs, which can be used for multi materials, random materials, object distribution or selection sets.
      Here in max:
      1 https://www.youtube.com/watch?v=yJiwnQ3anwM
      2 https://www.youtube.com/watch?v=K8qQlb8HupI
      Or used in RailClone for distribution of objects
      https://youtu.be/Xe0MPT0S0wI?t=625
      Btw. would it be possible to get material informations from lines, when you extrude lines to a face? Then you could have a set of lines with assigned materials and they will be applied to the extruded faces. Combined with an automatic generation of mapping coordinates that follow the extrusion like it is already possible in ThruPaint, this could be really helpful i think (video 2).
      • OxerO
        Oxer
        Thanks Fredo for this incredible tool!! 👍
        There is an issue on macOS 10.13.6 & SU2016, when the tool is activated I can't orbit (through shortcut: Ctrl+Cmd) to select edges.
        I created the Spanish language file, here is:
        FredoCorner_ES.lang.zip
        • fredo6F
          What is Ctrl+Command doing exactly.
          Note: I had to implement a custom orbit and Pan tool within FredoCorner, because otherwise, it would not be possible to see the preview, which is simply drawn in the viewport.
          You will notice it, because unlike the native orbiter, mine stops orbiting when the mouse is not in the viewport (i.e. over toolbars or dialog boxes).
          On Windows, the following is implemented
          • Middle mouse button --> orbit
          • Middle mouse button + shift --> Pan
          • Middle mouse button + Ctrl --> Free orbit (i.e. not keeping horizontal floor)
          • Middle mouse button + Left mouse button --> Pan
          I have assumed it would be the same on Mac.
          So please tell me if it is different and also if there are extra features that I missed.
          PS: For the translation, very kind of you. Thank you. Actually, in v1.1a, not all strings are exposed yet, so there will be a remaining part (same for LibFredo6)
          • fredo6F
            Ok, I see the concept, and it might be useful.
            However, all what is shown in the videos seems to be beyond the power of Sketchup, unless this is implemented natively or explicitely supported by the Ruby API.
            Since SU2017, where a change was introduced that severely damaged the only robust pattern to control the generation of geometry based on temporary groups, it is extremely difficult to propagate information when you create new geometry derived from an old one containing this information. It is challenging, even for something as simple a FredoCorner, where the only information I propagate is about edge properties and face materials.
            So I am afraid that extensions will remain fairly limited in this domain, and for the concept of modifiers too, except in some specific situations.
            • cmdC
              cmd
              Hello Fredo. Great stuff!! Thanks for building this.
              I am seeing a possible bug. --> Except for zoom, I am not able to navigate the model with my mouse while FredoCorner is active. To be specific, Pan (Middle mouse button + shift) and Orbit (Middle mouse button) do not work via the mouse controls.
              Navigation DOES work while using your Round Corner extension
              Mac HighSeirra 10.13.6
              SketchUp Pro 2018, Version 18.0.16976
              Cheers
              CMD
              • CMD
                Ahmed0007
                Thank You Fredo
                i hope i can do this in paid version
                • OxerO
                  Oxer
                  On Mac you can orbit while you use another tool (i.e draw a line) without the neccesity to exit of the tool to orbit.
                  I can't test the shortcuts above because I use a Apple Magic Mouse, there isn't middle button:
                  - Middle mouse button --> orbit
                  - Middle mouse button + shift --> Pan
                  - Middle mouse button + Ctrl --> Free orbit (i.e. not keeping horizontal floor)
                  - Middle mouse button + Left mouse button --> Pan
                  Ok, I will translate it when you add all strings.
                    Are you interested by the French version ? 😉
                    • fredo6F
                      Pilou,
                      Thanks, I think I will manage. The point is that I did not expose yet all the strings.
                      • fredo6F
                        Cheers
                        CMD
                        Well, Yes, I should have thought that Macs would have a problem with this, probably in relation with the values of flags in the mouse events, which I forgot are not the same as on Windows.
                        Could a Mac user does the following:
                        1. Copy the attached rb file TestMacMouse.rb ito its Plugin directory
                        2. Open the Ruby console and type flag_mac. This starts a dummy tool tracing the Move and Middle button events
                        3. Press the Middle Mouse button, move around and release. Type Spacebar to end the test
                        4. Reply to this post with what is displayed in the Ruby console
                        Thanks in advance.
                        And sorry for inconvenience for Mac users.
                        TestMacMouse.rb
                          @Fredo : Pas de problème, d'ailleurs je n'avais même pas trouvé le fichier! 😄
                          Windows est un tel labyrinthe ! 💚
                          • fredo6F
                            On ORBITING on MAC.
                            I jut published LibFredo6 8.6b, where I tried 'blindly' to fix the problem of Orbiting on Mac.
                            Thanks to advise
                            • fredo6F
                              Actually, in my plugins, you translate from within the plugin, not from files: Menu "Language Translation".
                              But don't worry I'll take care of French in due time.
                                dihe
                                Tank you Fredo,
                                Variable offset is grate thing!
                                Grate job!
                                • fredo6F
                                  NEW RELEASE: FredoCorner v1.1a - 06 Sep 18
                                  FredoCorner 1.1a is the first public release.
                                  Requirement: LibFredo6 8.6b
                                  Please note that:
                                  • there are known issues and likely bugs here and there
                                  • This concerns in particular the Collision, i.e. when the offset is too large.
                                  • Terminal corners (that is with a single edge) may present issues and bugs
                                  • Variable offset tools are experimental
                                  • No documentation yet, so watch the videos that I will publish.
                                  Please report issues, questions and any feedback in the present thread
                                  Home Page of FredoCorner for information and Download.
                                  Main post of this FredoCorner thread.
                                  • cmdC
                                    cmd
                                    Fredo,
                                    Your TestMacMouse.rb test results are below:
                                    MButton down flags = 33554432
                                    OnMouseMove flags = 33554432
                                    MButton Up flags = 0
                                    Also, after installing LibFredo6 8.6b, the Pan & Orbit bug appears to be fixed 😄
                                    I hope this helps
                                    CMD
                                    • CMD
                                    • fredo6F
                                      I hope this helps
                                      CMD
                                      Many thanks. Very helpful indeed.
                                      • fredo6F
                                        NEW RELEASE: FredoCorner v1.1b - 08 Sep 18
                                        FredoCorner 1.1b includes a fix for the orbiting on Mac platforms, as well as a first translation in Spanish by Oxer.
                                        Requirement: LibFredo6 8.6c
                                        Please note that:
                                        • This concerns in particular Collisions, i.e. when the offset is too large.
                                        • Terminal corners (that is ending on a single edge) may present issues and bugs
                                        • ArcA
                                          Arc
                                          Thank you Fredo for your great work.
                                          I created the Chinese simplified language file, here is:
                                          FredoCorner_ZH.lang
                                          • JQLJ
                                            JQL
                                            Amazing work Fredo. It's really impressive how much you've put into it.
                                            I always avoid using round corners just because of everything you've tried to circumvent with FredoCorner, so even if I'm already so used to avoid them I will definetely give this one a try.
                                            Thanks for pushing the boundaries! (around corners)
                                            PS: I hope this can open new paths to a lot of stuff being it at the core of Sketchup or only at plugin side of things… let's see what happens!
                                            PS2: I'm not offering for a PT version because I'm out of time, but if you don't have someone else doing it and if you need it, then don't hesitate to ask and I will find the time.
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 22
                                            • 23
                                            • 2 / 23
