    WallCutter by FlexTools
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    33 Posts 8 Posters 38.5k Views 8 Watching
    • jujuJ
      juju
      @halroach said:
      WallCutter is 97.42% ready and steady
      81.25% of all statistics is made up on the spot 😛
      • pbacotP
        I think that's a better completion percentage than most my projects ever see.... congratulations. Looks very nice.
        I'd like to cut a grouped wall geometry too. Can we use somehow with our own window components? Despite expectations, I can rarely get two projects to have the same windows and trim, so it makes most sense to model a window with it's trim detail at the start of a project then modify it for all window sizes and types. When the windows are components or parts of components it can also help in all the changes that eventually and inevitably come.
        • V
          valerostudio
          I am 100% excited about this new Flex tool!
          • halroachH
            halroach
            WallCutter is designed to, and works best with wall geometry that is grouped into a component.
            Yes! You can convert any component into a WallCutter as long as the component's axes point is facing in the correct orientation (Z (blue) faces out) and (currently) that the window's shape is a convex hull.
            If you make changes to the window manually you can then refresh the opening it creates. If it's a DC, the opening will refresh automatically.
            It's good you reminded me about Trim! 😳 We'll add support for that shortly after the release.
            (Lucky I left 2.58% for little updates for the first release 😉
            FlexTools - Super Quick Windows, Doors, Slats...
            • halroachH
              halroach
              Ladies and Gentlemen,
              WallCutter is released and is now officially part of FlexPack Pro! 🎉 🎉 🎉
              https://flextools.cc/wallcutter
              • PixeroP
                Pixero
                I have a couple of questions.
                I've made a quick test with a simple grouped wall and a simple rectangle that is made into a component.
                Now I tried to make a hole in the wall (no window just a hole) I delete the face and keep the edges in the component. When trying to make this a wall cutter SU hangs with a spinning wheel and finally bugsplats.
                Now I tried to make the rectangle (with a face) to a wall cutter and that works and creates a hole but if I then delete the face and keep only the edges in the component I can't move the wall cutter object.
                How do I create a dynamic hole with nothing in it?
                Second question is if it would be possible to make wall cutter work with Fredo Scale?
                • halroachH
                  halroach
                  Hi Pixero,
                  I just recreated that on my computer. BANG - Bug Splat. It's good you found it. We'll look into a fix. In the meantime... don't do it. 😎
                  Try hiding the face instead of deleting it. It will then work as you'd expect it.
                  Let me know how it goes.
                  • halroachH
                    halroach
                    New update for WallCutter!
                    In this update we've introduced a much requested and significant enhancement for WallCutter - the ability to exclude sub-components from affecting the cutting algorithm. That means you'll now be able to have wall cutting windows (and doors) with Trim!
                    This update also includes a couple of bug fixes:
                    👊 One of the bugs found by Pixero (see two posts above) should now be fixed. Sketchup won't crash now when having 0 faces in a WallCutter component.
                    👊 The other bug fix addresses another similar crash that could happen if the faces in a cutting component had the thickness of 0. This could happen when a flat WallCutter component was created with the wrong axes orientation.
                    1. How to auto-update
                    2. Remember to restart Sketchup after the update!
                    Happy Flexing! 😄
                    • pbacotP
                      Great work! (and since this is really beyond my ken how you do this) [highlight=#ffff80:3hp75q7g]MAGIC![/highlight:3hp75q7g]
                      • O
                        optimaforever
                        It is indeed magic.
                        I realized that juxtaposing a flexdoor and a flexwindow as wallcutters is problematic as one of them sometimes loses its wallcutting abilities. I had the habit of nudging my windows/doors when they are supposed to be close to a wall's edge, to avoid corrupting geometry (SketchUp's face cutting components tend to corrupt mesh if too close to the edge when exported).
                        Here as well, nudging the door by 0.5cm from the window suffices to keep the wallcutting properties, and the difference remains barely visible.
                        Idem, when I stretch a flex window on the whole height of the wall it is supposed to cut, I sometimes loses the wallcutting property. Then I have to stretch down a bit and the wallcut come back. Must be due to Sketchup's internal aprroximations.
                        I also realized that painting a material upon the wallcutter component explodes the geometry. I need to double-click the wallcutter compo to be able to paint upon inner sub-compos. I guess this is a normal behaviour?
                        • halroachH
                          halroach
                          @optimaforever said:
                          It is indeed magic.
                          Yes, placing two WallCutters side by side doesn't always work well. You can 'unlink' one of them and it may help in some specific cases. Some of the cases we may be able to fix in the future.
                          Can you post an example of this here?
                          Painting explodes the geometry!?? Please post an example of that too.
                          If you mean that the materials aren't saved with the component when saving into CoponentFinder, than the behavior is normal. You need to apply the materials inside the component if you want them to keep.
                          • O
                            optimaforever
                            When I try to paint, the geometry gets corrupted.
                            the door I want to paint
                            after I painted the door
                            If I zoom extent
                            • O
                              optimaforever
                              But if I double-click the facecutter compo and paint INSIDE, it works.
                              • halroachH
                                halroach
                                Can you post the model before and after? I'll take a look.
                                • O
                                  optimaforever
                                  Sent by email.
                                  • halroachH
                                    halroach
                                    1. Use components instead of groups for the walls. That should solve it. (You may need to recreate that first opening again)
                                    (We tried to get WallCutter to work as much as possible with groups, but unfortunately they are very problematic - Components is the way to go!)
                                    • O
                                      optimaforever
                                      I think the bug is file specific.
                                      I copy-pasted the incriminated geometry in a new skp session and eveything works fine as is supposed.
                                      Try yourself and you'll see.
                                      The source file came from the architect. I just opened the skp and tried to clean it, but as you can see, I prefer to model my geometry from scratch, always. The rare often bugs caused by imported DWG, inadequate pushpulling, errors due to scale or precision miscalculation, etc.
                                      • halroachH
                                        halroach
                                        1. If you move the door in the new file you will see that the wall becomes corrupted. It's because of the groups. The minute I converted the groups to components, everything was fine! Use components only!
                                        2. BTW. You can place the door outside of the wall component's context. It doesn't have to be inside.
                                        • O
                                          optimaforever
                                          1. ok
                                          2. I know, it's just I didn't know yet if the wall had to be componented in order to be mirrored so I left the door inside the group. Otherwise the door will be "forgotten" when mirroring the wall...
                                            Well, I understand what I mean 😄
                                          • halroachH
                                            halroach
                                            1. I know, it's just I didn't know yet if the wall had to be componented in order to be mirrored so I left the door inside the group. Otherwise the door will be "forgotten" when mirroring the wall...
                                            You could always surround the wall and door with a new component and that should work fine. The only thing to watch out for is when wanting to make the component later unique. You will need to Remove Cuts (openings will disappear) -> Make Unique - both the surrounding component and the wall component -> Refresh.
                                            More on that here: https://flextools.cc/learn/wall-cutter/#Advanced-Operations
