    WallCutter by FlexTools
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    33 Posts 8 Posters 37.8k Views 8 Watching
    • halroachH Offline
      halroach
      @pixero said:
      From the looks of it it works on grouped geometry. That looks really great.
      Yes, it does! 😄
      FlexTools - Super Quick Windows, Doors, Slats...
      • PixeroP Offline
        Pixero
        Does it work on instances too?
        Meaning if I cut a hole in one all will receive a hole?
        When can we try this?
        • halroachH Offline
          halroach
          You mean like this?
          • PixeroP Offline
            Pixero
            Super cool
            • halroachH Offline
              halroach
              WallCutter will be released in 5... 4... 3 days!
              After endless testing, many busy days and sleepless nights... WallCutter is 97.42% ready and steady 😉 ​ Prepare for Dynamic Openings in SketchUp!
              https://flextools.cc/wallcutter/
              https://flextools.cc/wp-content/uploads/2018/07/WallCutter-Freedom_02e.gif
              • jujuJ Offline
                juju
                81.25% of all statistics is made up on the spot 😛
                • pbacotP Offline
                  I think that's a better completion percentage than most my projects ever see.... congratulations. Looks very nice.
                  I'd like to cut a grouped wall geometry too. Can we use somehow with our own window components? Despite expectations, I can rarely get two projects to have the same windows and trim, so it makes most sense to model a window with it's trim detail at the start of a project then modify it for all window sizes and types. When the windows are components or parts of components it can also help in all the changes that eventually and inevitably come.
                  • V Offline
                    valerostudio
                    I am 100% excited about this new Flex tool!
                    • halroachH Offline
                      halroach
                      WallCutter is designed to, and works best with wall geometry that is grouped into a component.
                      Yes! You can convert any component into a WallCutter as long as the component's axes point is facing in the correct orientation (Z (blue) faces out) and (currently) that the window's shape is a convex hull.
                      If you make changes to the window manually you can then refresh the opening it creates. If it's a DC, the opening will refresh automatically.
                      It's good you reminded me about Trim! 😳 We'll add support for that shortly after the release.
                      (Lucky I left 2.58% for little updates for the first release 😉
                      • halroachH Offline
                        halroach
                        Ladies and Gentlemen,
                        WallCutter is released and is now officially part of FlexPack Pro! 🎉 🎉 🎉
                        • PixeroP Offline
                          Pixero
                          I have a couple of questions.
                          I've made a quick test with a simple grouped wall and a simple rectangle that is made into a component.
                          Now I tried to make a hole in the wall (no window just a hole) I delete the face and keep the edges in the component. When trying to make this a wall cutter SU hangs with a spinning wheel and finally bugsplats.
                          Now I tried to make the rectangle (with a face) to a wall cutter and that works and creates a hole but if I then delete the face and keep only the edges in the component I can't move the wall cutter object.
                          How do I create a dynamic hole with nothing in it?
                          Second question is if it would be possible to make wall cutter work with Fredo Scale?
                          • halroachH Offline
                            halroach
                            Hi Pixero,
                            I just recreated that on my computer. BANG - Bug Splat. It's good you found it. We'll look into a fix. In the meantime... don't do it. 😎
                            Try hiding the face instead of deleting it. It will then work as you'd expect it.
                            Let me know how it goes.
                            • halroachH Offline
                              halroach
                              New update for WallCutter!
                              In this update we've introduced a much requested and significant enhancement for WallCutter - the ability to exclude sub-components from affecting the cutting algorithm. That means you'll now be able to have wall cutting windows (and doors) with Trim!
                              This update also includes a couple of bug fixes:
                              👊 One of the bugs found by Pixero (see two posts above) should now be fixed. Sketchup won't crash now when having 0 faces in a WallCutter component.
                              👊 The other bug fix addresses another similar crash that could happen if the faces in a cutting component had the thickness of 0. This could happen when a flat WallCutter component was created with the wrong axes orientation.
                              1. How to auto-update
                              2. Remember to restart Sketchup after the update!
                              Happy Flexing! 😄
                              • pbacotP Offline
                                Great work! (and since this is really beyond my ken how you do this) [highlight=#ffff80:3hp75q7g]MAGIC![/highlight:3hp75q7g]
                                • O Offline
                                  optimaforever
                                  It is indeed magic.
                                  I realized that juxtaposing a flexdoor and a flexwindow as wallcutters is problematic as one of them sometimes loses its wallcutting abilities. I had the habit of nudging my windows/doors when they are supposed to be close to a wall's edge, to avoid corrupting geometry (SketchUp's face cutting components tend to corrupt mesh if too close to the edge when exported).
                                  Here as well, nudging the door by 0.5cm from the window suffices to keep the wallcutting properties, and the difference remains barely visible.
                                  Idem, when I stretch a flex window on the whole height of the wall it is supposed to cut, I sometimes loses the wallcutting property. Then I have to stretch down a bit and the wallcut come back. Must be due to Sketchup's internal aprroximations.
                                  I also realized that painting a material upon the wallcutter component explodes the geometry. I need to double-click the wallcutter compo to be able to paint upon inner sub-compos. I guess this is a normal behaviour?
                                  • halroachH Offline
                                    halroach
                                    @optimaforever said:
                                    It is indeed magic.
                                    Yes, placing two WallCutters side by side doesn't always work well. You can 'unlink' one of them and it may help in some specific cases. Some of the cases we may be able to fix in the future.
                                    Can you post an example of this here?
                                    Painting explodes the geometry!?? Please post an example of that too.
                                    If you mean that the materials aren't saved with the component when saving into CoponentFinder, than the behavior is normal. You need to apply the materials inside the component if you want them to keep.
                                    • O Offline
                                      optimaforever
                                      When I try to paint, the geometry gets corrupted.
                                      the door I want to paint
                                      after I painted the door
                                      If I zoom extent
                                      • O Offline
                                        optimaforever
                                        But if I double-click the facecutter compo and paint INSIDE, it works.
                                        • halroachH Offline
                                          halroach
                                          Can you post the model before and after? I'll take a look.
                                          • O Offline
                                            optimaforever
                                            Sent by email.
