    [Plugin] TIG-Cut_to_plane v1.1 20130107
    32 Posts 19 Posters 47.8k Views 19 Watching
    • bmikeB Offline
      bmike
      how does one get this into the right click menu? would love to see it right under 'solid solver'...
      and, is there a way to customize my rubies so i can better order my right click menu?
        This is the code that adds 'SolidSolver' to the menu AND the context-menu.
        unless file_loaded?(__FILE__)
          cmd=UI;;Command.new("SolidSolver"){self.solidsolver()}
          UI.menu("Tools").add_item(cmd)
          UI.add_context_menu_handler{|menu|
            if self.solidsolver_unsolid?()
              menu.add_item(cmd)
        file_loaded(__FILE__)
        The basis here is to make a command, and then add that to the the context-menu. Because this code is within the TIG module it says self.solidsolver(); however, TIG.solidsolver() would work otherwise... It also uses the built-in test self.solidsolver_unsolid?() [aka TIG.solidsolver_unsolid?()] which checks if the selected object is solid, otherwise there is no context-menu entry - try it with a selected line and the menu item is not added.
        To add any tool to the context-menu you simply make a command of it and add it, perhaps testing that some 'case' is met in a selection etc before adding the item.
        This example adds ' TIG-Cut_to_plane' to the context-menu... add this new code instead of the menu making code in ~line#259
        UI.menu("Plugins").add_item("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
        becomes
        cmd=UI;;Command.new("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
        UI.menu("Plugins").add_item(cmd)
            ss=Sketchup.active_model.selection[0]
            if ss and (ss.is_a?(Sketchup;;Group) || ss.is_a?(Sketchup;;ComponentInstance)) and ss.manifold?
              menu.add_item(cmd)
        Change 'Plugins' to 'Tools' etc as desired...
        To do the same for its sibling tool ' TIG-Split_to_plane' add this new code instead of the menu making code in ~line#298
        UI.menu("Plugins").add_item("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
        becomes
        cmd=UI;;Command.new("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
              menu.add_item(cmd)
        To do it to other tools you need to read and understand how they run and how to make a command from their code...
        Be aware that adding too many 'commands' to SketchUp can cause the gray-out issue in the context-menu - this has bee 'fixed' by allowing you to have a lot more before it happens, but go bonkers adding them and items will spontaneously disable themselves and 'gray-out',
          Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=433723#p433723
          Now at Point 3 an alternative <Enter> press cuts vertically, keeping left-side parts.
          Also Context-menu if selection suitable.
            Ben Ritter
            Thank you TIG.
              rainboworiver
              does it work on sketch 2013 (freeware) ? only on pro?
              • Rich O BrienR Online
                Note for Pro >=v.8 only...
                • designerbursaD Offline
                  designerbursa
                  to select the portion to be cut
                    Was that a question ?
                    The direction of the 3 points defining the plane determine what is kept.
                    Try clockwise/counterclockwise and see the results...
                    Please read the usage notes...
                      Alain
                      Thank alot TIG, it's a fantastic Plugin! It fullfits my needs πŸ˜„
                        kumudugayashan
                        Awesome!
                        • H Offline
                          hgdar
                          Great tools, thanks.
                          But i can't cut multiple objets at the same time, which is very frustrating.
                          Is there a custom version that can do this or a free alternative.
                            rv1974
                            • 2 / 2
