    [Plugin] TIG-Cut_to_plane v1.1 20130107
    32 Posts 19 Posters 49.1k Views 19 Watching
      penumbra
      @ rv1974
      For your #1 above you could use section tool in combination with zorro2.
        rv1974
        @penumbra
        Maybe the things got better, but Zorro was kinda minefield- too much crashes,- I stopped using it. And besides, 3 clicks to define the cutting plane is the nicest way to cut.
        • bmikeB Offline
          bmike
          Wonderful TIG!!!!
          • bmikeB Offline
            bmike
            how does one get this into the right click menu? would love to see it right under 'solid solver'...
            and, is there a way to customize my rubies so i can better order my right click menu?
              This is the code that adds 'SolidSolver' to the menu AND the context-menu.
              unless file_loaded?(__FILE__)
                cmd=UI;;Command.new("SolidSolver"){self.solidsolver()}
                UI.menu("Tools").add_item(cmd)
                UI.add_context_menu_handler{|menu|
                  if self.solidsolver_unsolid?()
                    menu.add_item(cmd)
              file_loaded(__FILE__)
              The basis here is to make a command, and then add that to the the context-menu. Because this code is within the TIG module it says self.solidsolver(); however, TIG.solidsolver() would work otherwise... It also uses the built-in test self.solidsolver_unsolid?() [aka TIG.solidsolver_unsolid?()] which checks if the selected object is solid, otherwise there is no context-menu entry - try it with a selected line and the menu item is not added.
              To add any tool to the context-menu you simply make a command of it and add it, perhaps testing that some 'case' is met in a selection etc before adding the item.
              This example adds ' TIG-Cut_to_plane' to the context-menu... add this new code instead of the menu making code in ~line#259
              UI.menu("Plugins").add_item("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
              becomes
              cmd=UI;;Command.new("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
              UI.menu("Plugins").add_item(cmd)
                  ss=Sketchup.active_model.selection[0]
                  if ss and (ss.is_a?(Sketchup;;Group) || ss.is_a?(Sketchup;;ComponentInstance)) and ss.manifold?
                    menu.add_item(cmd)
              Change 'Plugins' to 'Tools' etc as desired...
              To do the same for its sibling tool ' TIG-Split_to_plane' add this new code instead of the menu making code in ~line#298
              UI.menu("Plugins").add_item("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
              becomes
              cmd=UI;;Command.new("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
                    menu.add_item(cmd)
              To do it to other tools you need to read and understand how they run and how to make a command from their code...
              Be aware that adding too many 'commands' to SketchUp can cause the gray-out issue in the context-menu - this has bee 'fixed' by allowing you to have a lot more before it happens, but go bonkers adding them and items will spontaneously disable themselves and 'gray-out',
                Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=433723#p433723
                Now at Point 3 an alternative <Enter> press cuts vertically, keeping left-side parts.
                Also Context-menu if selection suitable.
                  Ben Ritter
                  Thank you TIG.
                    rainboworiver
                    does it work on sketch 2013 (freeware) ? only on pro?
                      Note for Pro >=v.8 only...
                      • designerbursaD Offline
                        designerbursa
                        to select the portion to be cut
                          Was that a question ?
                          The direction of the 3 points defining the plane determine what is kept.
                          Try clockwise/counterclockwise and see the results...
                          Please read the usage notes...
                            Alain
                            Thank alot TIG, it's a fantastic Plugin! It fullfits my needs πŸ˜„
                              kumudugayashan
                              Awesome!
                              • H Offline
                                hgdar
                                Great tools, thanks.
                                But i can't cut multiple objets at the same time, which is very frustrating.
                                Is there a custom version that can do this or a free alternative.
                                  rv1974
                                  • 2 / 2
