    [Plugin] TIG-Cut_to_plane v1.1 20130107
    32 Posts 19 Posters 49.1k Views 19 Watching
    • dermotcollD Offline
      dermotcoll
      Thanks TIG. Looks like a very useful tool for woodworking and machining worksurfaces with a CNC.
      When you burn your arse - you gotta sit on the blisters!!
        penumbra
        Many thanks TIG. Is there a way to make this work on a non solid group? Or nested groups? zorro does something like what i need but is view dependent, you have to view your group from an orthogonal view if you want a "straight" cut.
          No.
          This tool works on solids only.
          Zorro2 will work by slicing along a Section Plane.
          Place one where you want and use that Zorro2 option.
          I haven't tried nesting the plane inside the group/instance so that the cur only applies to the active entities - try it and report back...
            penumbra
            @TIG
            Yes indeed, Zorro2 will cut through nested entities. There is a bit of clean up needed afterwards as some surfaces may need to be healed depending on how the section cut cuts through the objects.
            Slicing nested groups with zorro2
              shri
              great addition to the plugins list..thanks alot..can't wait playing with it
              πŸŽ‰ πŸŽ‰ πŸŽ‰
                rv1974
                Thank you TIG!
                I wish this tool could:
                1. work with non-solids (I won't miss section faces anyway)
                2. I guess the fourth click to manually choose the side to be cut off would be even more user-friendly. No pop-ups, just a hint in status bar.
                  penumbra
                  @ rv1974
                  For your #1 above you could use section tool in combination with zorro2.
                    rv1974
                    @penumbra
                    Maybe the things got better, but Zorro was kinda minefield- too much crashes,- I stopped using it. And besides, 3 clicks to define the cutting plane is the nicest way to cut.
                    • bmikeB Offline
                      bmike
                      Wonderful TIG!!!!
                      • bmikeB Offline
                        bmike
                        how does one get this into the right click menu? would love to see it right under 'solid solver'...
                        and, is there a way to customize my rubies so i can better order my right click menu?
                          This is the code that adds 'SolidSolver' to the menu AND the context-menu.
                          unless file_loaded?(__FILE__)
                            cmd=UI;;Command.new("SolidSolver"){self.solidsolver()}
                            UI.menu("Tools").add_item(cmd)
                            UI.add_context_menu_handler{|menu|
                              if self.solidsolver_unsolid?()
                                menu.add_item(cmd)
                          file_loaded(__FILE__)
                          The basis here is to make a command, and then add that to the the context-menu. Because this code is within the TIG module it says self.solidsolver(); however, TIG.solidsolver() would work otherwise... It also uses the built-in test self.solidsolver_unsolid?() [aka TIG.solidsolver_unsolid?()] which checks if the selected object is solid, otherwise there is no context-menu entry - try it with a selected line and the menu item is not added.
                          To add any tool to the context-menu you simply make a command of it and add it, perhaps testing that some 'case' is met in a selection etc before adding the item.
                          This example adds ' TIG-Cut_to_plane' to the context-menu... add this new code instead of the menu making code in ~line#259
                          UI.menu("Plugins").add_item("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
                          becomes
                          cmd=UI;;Command.new("TIG-Cut_to_plane"){Sketchup.active_model.select_tool(TIG;;Cut_to_plane.new())}
                          UI.menu("Plugins").add_item(cmd)
                              ss=Sketchup.active_model.selection[0]
                              if ss and (ss.is_a?(Sketchup;;Group) || ss.is_a?(Sketchup;;ComponentInstance)) and ss.manifold?
                                menu.add_item(cmd)
                          Change 'Plugins' to 'Tools' etc as desired...
                          To do the same for its sibling tool ' TIG-Split_to_plane' add this new code instead of the menu making code in ~line#298
                          UI.menu("Plugins").add_item("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
                          becomes
                          cmd=UI;;Command.new("TIG-Split_to_plane"){Sketchup.active_model.select_tool(TIG;;Split_to_plane.new())}
                                menu.add_item(cmd)
                          To do it to other tools you need to read and understand how they run and how to make a command from their code...
                          Be aware that adding too many 'commands' to SketchUp can cause the gray-out issue in the context-menu - this has bee 'fixed' by allowing you to have a lot more before it happens, but go bonkers adding them and items will spontaneously disable themselves and 'gray-out',
                            Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=433723#p433723
                            Now at Point 3 an alternative <Enter> press cuts vertically, keeping left-side parts.
                            Also Context-menu if selection suitable.
                              Ben Ritter
                              Thank you TIG.
                                rainboworiver
                                does it work on sketch 2013 (freeware) ? only on pro?
                                  Note for Pro >=v.8 only...
                                  • designerbursaD Offline
                                    designerbursa
                                    to select the portion to be cut
                                      Was that a question ?
                                      The direction of the 3 points defining the plane determine what is kept.
                                      Try clockwise/counterclockwise and see the results...
                                      Please read the usage notes...
                                        Alain
                                        Thank alot TIG, it's a fantastic Plugin! It fullfits my needs πŸ˜„
                                          kumudugayashan
                                          Awesome!
                                          • H Offline
                                            hgdar
                                            Great tools, thanks.
                                            But i can't cut multiple objets at the same time, which is very frustrating.
                                            Is there a custom version that can do this or a free alternative.
                                            • 2 / 2
