    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • W
      whiterabbit
      I only used the swf as the interface looks like that's what it prefers.
      • fredo6F
        New Release: Animator - v2.1a - 20 May 18
        Requirement: LibFredo6 v8.4a
        Major release
        Added Movement Apparition, allowing to make object progressively appear or disappear, based on section planes.
        Note: hose models by Eneroth3
        If you install LibFredo6 v8.4c, you have the option to use section planes for partial apparition, between 2 boundaries
        See plugin home page of Animator for Download of RBZ from the PluginStore.
        See Main Post of the Animator thread for more information.
          junphuc17945
          in version 2.1, i cant generate video
          • fredo6F
            Small bug coming from LibFredo6.
            Fixed in LibFredo6 v8.4f, just published.
            • fredo6F
              New Release: Animator - v2.2a - 13 July 18
              Requirement: LibFredo6 v8.5a
              Minor release
              • Extension of validity
              • Prompt for sequence names can now be configured from the Default Parameter Dialog box. If you set at NO PROMPT, then a default name will be used. You can change it later.
              • Note also that there is fast way to insert the current view camera in the timeline, by clicking on the small button in the Insert palette.
              • fredo6F
                New Release: Animator - v2.2b - 14 July 18
                Requirement: LibFredo6 v8.5b
                Minor release
                Full screen option: All Sketchup toolbars, native and extensions are automatically hidden when starting Animator. They are restored in their original position when exiting Animator, either temporarily or fully.
                This option can be activated in the Default Parameters dialog box.
                The idea is indeed to give you more space on the screen when designing animations.
                Here is a short video illustrating the Full Screen option.
                  Tricky! ☀
                  • fredo6F
                    @pilou said:
                    Tricky! ☀
                    Don't know if it works on Mac!
                    • T
                      Takkegek
                      Hello,
                      I was doing some tests today with Animator (just discovered the plugin and looks very promising!) and Thea Render for Sketchup v2 (recent version).
                      This is a very basic quick animation in sketchup I made with Animator:
                      I would like to render it in thea but thea can not find the clip when I push the button 'render Animation' ( like shown in printscreen )
                      Anyone an idea why Thea doesn't find the clip I made? Or has this something to do with the fact that Thea is a demo version? It is possible to render it in Animator itself but I want to render in thea because I think I will have more control over the network rendering settings.
                      Thank you!
                      Takkegek
                      • fredo6F
                        I think the external rendering from Thea requires that you have the licensed version installed.
                        • T
                          Takkegek
                          Thanks Fredo for answering! I have almost the licensed version, bought it but still waiting for the serials to come from Thea render. I can't wait to test this plugin any further.
                          I was wondering something. Is it possible to import a whole animation of one sketchup-file into a other sketchup-file? For example; I make a animation of a car driving. Can I import this car+animation into a other sketchup-file?
                          Or is it only possible the other way around: to import the second sketchup-file in the one where I have allready made all the animations that I would like to use?
                          • fredo6F
                            Animator does not allow this, because you would need to import exactly the same objects and contexts (layers, etc...).
                            However, if you do a Save-as of a file with animations inside, the new file also include the animation, since all animation data are stored within the model.
                            You can also create several animations in the same model. All elements of animations (i.e. sequences, clips, films) can be re-used.
                            • T
                              Takkegek
                              Actually it does not take much time to do the setup for a driving a car or for some flying birds. It is not really necessary to import it from one file to another because the workflow in Animator is pretty quick. Below a quick test with some flying birds.
                              This plugin can make a walkthrough for a project much more interesting (like opening a door in a interior walktrough).
                              Great plugin so far Fredo, if this all works well with Thea4SU v2 (have not yet the serials so can not test everything) than it should be a paying plugin!
                              • F
                                Floorguy
                                Disappearing group? When I choose the Translation movement and then go Selection of Objects, I select my group to move and it disappears, never to return. Even when I quit Animator and return to Sketchup, the group is gone. If I go back and purge all sequences, it comes back. Any ideas? (I'm pretty new to Sketchup and Animator)
                                Disappearing Group.mov
                                • fredo6F
                                  @floorguy
                                  Strange, indeed.
                                  Could you post the model so that I have a look.
                                  Many thanks
                                  • F
                                    Floorguy
                                    @fredo6 said:
                                    @floorguy
                                    Strange, indeed.
                                    Many thanks
                                    Here's a link to the Sketchup file Fredo. Thanks for looking.
                                    (drive.google.com)
                                    • soloS
                                      Is Animator and Thea 1.5 still working? I cannot get them to work together, I tried both from Animator dialog and from the Thea window to render an animation to no avail.
                                      • fredo6F
                                        Good you signal it.
                                        Something has changed in Thea 1.5, and the method for rendering does not work as it used to (you can see it in the Ruby console). This simply prevents the rendering from Animator with Thea. is ennoying and there is little I can do on my side.
                                        • soloS
                                          I have informed Tomasz about this issue, hopefully, he will fix it. I hear that Animator works with Vray now, I did not see Vray in the options, Is there a tutorial for Animator and Vray? I may need to use this if Thea is not working anymore.
                                          • fredo6F
                                            I sent a message to Tomas too.
                                            VRay is supported, but same thing happens with the most recent version (v1.6), where the API is less stable and can hang.
                                            More generally, there is not a lot of attention from rendering software companies to provide a stable and flexible API to use rendering from an external program (like Animator).
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 29
                                            • 30
                                            • 14 / 30
