    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      I've got a few small fires to put out this morning, but other than that what should be next on the list?
      Current List:
      • Interior Trim
      • Garage Doors
      • Int-int door casing
      • Gypsum wrap for interior openings (without doors or windows installed)
      • Wall Split Tool
      • Wall Join Tool
      • Gable Wall Tool
      • Shed Wall Tool
      • Wall Grouping
      • Wall Paint Brush Tool (Transfer wall settings)
      • Interior (Gypsum) Painting Tool
      • More Windows, more doors (ie. sliding glass doors, french doors etc...)
      • Beam Tool
      • Add parameter for (glass) grille spacing both horz. and vert.
      • Enable Material Library (skm files).
      • Implementation of preset system into draw wall tool (with HTML menus)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 0.8.1 - 06.24.2018
        • Enabled exterior wainscoting for Ext-Int walls.
        • Added additional parameters to the wainscot menu for window and wall ledges.
        • Wainscot "cut" parameter added to the exterior trim menu in order to optionally cut corner trim at the wainscot height.
        http://design.medeek.com/resources/images/wall_su115_800.jpg
        There are still a few more parameters and features that I feel needed to be added to this new feature class. I am also willing to take suggestions on how to make this more useful. Please give it a go and let me know what you think.
        The wainscoting has also been added into the wall preset system.
        Which brings me to a new idea I just had as I was applying presets to a few walls this morning. The wall preset feature is quite handy but rather tedious to use if one wants to apply a specific preset to a number of walls (granted the wall grouping feature would come in handy here but that is still in development).
        What would be really handy is to have a "paintbrush" tool, where one could select any given wall panel and then all of its settings could then be transferred to any other wall panel with a single click of the mouse. Essentially treating the initially selected wall as a "preset" and then applying that preset to any walls selected. This would greatly speed up any changes one might need to make to a bunch of walls. I also think it would useful to have the tool differentiate between exterior and interior wall types. In other words if you initially select an exterior wall (ext-int) to copy those settings could not be applied to an interior wall (int-int).
        I don't know that I should call it the paintbrush tool though since I was thinking about creating a tool that allows the user to apply a color (paint) to the interior gypsum. It would kind of be like the eye dropper tool in Photoshop, how about "Wall Dropper"?
        design.medeek.com
        • medeekM Offline
          medeek
          Tutorial Video 1 - Plugin Overview:
          design.medeek.com
          • medeekM Offline
            medeek
            Six Panel and Solid Double Doors:
            http://design.medeek.com/resources/images/wall_su116_800.jpg
            http://design.medeek.com/resources/images/wall_su117_800.jpg
            I will add the full glass and half glass later today and then roll out a new sub-rev.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.8.1b - 06.25.2018
              • Added the following double door types: solid, six panel, half glass, full glass.
              http://design.medeek.com/resources/images/wall_su118_800.jpg
              Choosing LH or RH places the door hardware on the indicated side of the double door. I should probably add an additional option "LRH" that places the hardware on both doors.
              The image shows all as in-swing doors but they can also be drawn as out-swing as well.
              I have not shown an astragal for any of the double doors but if someone would like that option added please indicate and also send me details on how you would like it modeled.
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
                Charlie__V
                Nathaniel, all
                Draw wall......exterior trim = yes....Draw wall in +X direction 10' long....Draw wall in +Y direction 10' long....Draw wall in +X direction 10' long, and new wall segment begins to draw over first wall segment drawn in +X direction.
                Can you replicate this? (anyone else?)
                V 0.8.1b 06_25_18
                Thanks,
                Charlie
                X10ft_Y10ft_X10ft_Fail_06_26_2018.skp
                • medeekM Offline
                  medeek
                  @charlie__v said:
                  Nathaniel, all
                  V 0.8.1b 06_25_18
                  Thanks,
                  Charlie
                  Can you replicate the error with ruby console open? then post or email me the error codes (nathan@medeek.com). I'm not seeing this error but you may have some setting or parameter set a certain value which could be causing this behavior.
                  When you get a wall being drawn at the origin like this (and its all exploded) it means the plugin is encountering an error during the draw phase of the operation and has aborted mid-stream.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Since I've got the beam icons already active on the beams/columns toolbar I've decided to try and put together the beam module. The HTML edit menu (draw tool menu is very similar):
                    http://design.medeek.com/resources/images/wall_su119_800.jpg
                    Initially I will start with wood beams only: Sawn Lumber, Timber, Glulam, SCL (LVL, PSL, LSL)
                    Similar to the truss plugin the beams created within the wall plugin will be able to be analyzed directly with the beam calculator on my website via the engineering tools (engineering icon). This chunk of code is already fairly well tested and is simply a matter of recycling some of it from the Truss Plugin.
                    Later on I would also like to add steel beams (W, C, L, and HSS) but this will be based on user demand.
                    I would also like to bring the engineering calcs directly within the plugin so that the user can run the numbers even if they are offline, something for the long term todo list.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      @charlie__v said:
                      Nathaniel, all
                      V 0.8.1b 06_25_18
                      Thanks,
                      Charlie
                      Figured it out. The plugin is assuming that both the ext. and int. corner trim pieces will be six sided L-shaped polygon profiles. However with a thickness equal to width of the trim the resulting profile should then be a square. A simple fix and also a check for the situation where the thickness is greater than the width. When the thickness = width then the profile is a square and only four points are needed to describe the face to generate the profile.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 0.8.1c - 06.26.2018
                        • Fixed a bug where wall corner trim thickness equals trim width.
                        This will now allow the user to specify a 1.5" x 1.5" interior corner trim.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Just about to wrap up the beam tool this morning and then I got thinking about the end treatment of beams:
                          http://fdratlanta.com/images/gallery/pergolas/all-wood-custom-end-cut-rafter-pergola-vegas-style-garden.jpg
                          I don't know what the technical term is for this but I call it the Start Cut and End Cut of a beam.
                          http://www.tidewaterlumber.com/v/vspfiles/photos/End Cuts-2.jpg
                          There could be any number of possibilities for the end cut profile:
                          https://www.trexpergola.com/wp-content/uploads/2015/11/Trex-Pergola-Vision-Slight-End-Detail1.jpg
                          I think I will just start with two options:
                          • None
                          • 45 deg (to mid height of beam)
                          design.medeek.com
                            Charlie__V
                            Thank you Nathaniel, this resolves the issue.
                            And for the sake of clarity as to what the description means/is.....see pic below
                            • medeekM Offline
                              medeek
                              Thank-you for providing the additional clarification.
                              Inevitably I'm going to miss things, didn't even consider a square corner trim on an interior corner, funny thing is I've seen this sort of thing a million times though.
                              Please keep sending in the bugs and feature requests, I know there is more out there. Please also post up your models you create with the plugin I am curious as to how the plugin is actually being utilized.
                              design.medeek.com
                              • Bob JamesB Offline
                                Bob James
                                I know this sounds somewhat heretical but how about an option to set the full version to match the lite version for the times when all that's initially needed is a concept drawing?
                                Or is it obvious how to do it?
                                • medeekM Offline
                                  medeek
                                  Within the global settings under the Wall Tab you can set the default framing mode to one of the three options. This will then always bring up the wall draw tool with the selected mode, while still giving you the option to bump the wall to any of the other modes if you suddenly need to see the framing.
                                  design.medeek.com
                                    Bob James
                                    Thank you
                                    • medeekM Offline
                                      medeek
                                      Version 0.8.2 - 06.28.2018
                                      • Added the ability to draw and edit beams with the Beams/Column Toolset.
                                      • Glulam, PSL, LVL, LSL, Timber and Lumber beam types added to the beam module.
                                      • Start and end cut options (miter,firecut) added to the advanced options for beams.
                                      http://design.medeek.com/resources/images/wall_su120_800.jpg
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                        Bob James
                                        Could you add the revision number to the rbz file?
                                        medeek_wall_ext 0-8-1c.rbz
                                        medeek_wall_ext 0-8-2.rbz
                                        • medeekM Offline
                                          medeek
                                          Yes, that is probably not a bad idea.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Trying to find a decent wood grain to use for timber beams, any suggestions or images anyone is willing to share? I've got a decent end grain image, just looking for the side grain.
                                            P.S. I am also looking for a good pressure treated texture/material.
                                            design.medeek.com
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 74
                                            • 75
                                            • 68 / 75
