    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
      Charlie__V
      Nathaniel, all
      Draw wall......exterior trim = yes....Draw wall in +X direction 10' long....Draw wall in +Y direction 10' long....Draw wall in +X direction 10' long, and new wall segment begins to draw over first wall segment drawn in +X direction.
      Can you replicate this? (anyone else?)
      V 0.8.1b 06_25_18
      Thanks,
      Charlie
      X10ft_Y10ft_X10ft_Fail_06_26_2018.skp
      • medeekM Offline
        medeek
        @charlie__v said:
        Nathaniel, all
        V 0.8.1b 06_25_18
        Thanks,
        Charlie
        Can you replicate the error with ruby console open? then post or email me the error codes (nathan@medeek.com). I'm not seeing this error but you may have some setting or parameter set a certain value which could be causing this behavior.
        When you get a wall being drawn at the origin like this (and its all exploded) it means the plugin is encountering an error during the draw phase of the operation and has aborted mid-stream.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Since I've got the beam icons already active on the beams/columns toolbar I've decided to try and put together the beam module. The HTML edit menu (draw tool menu is very similar):
          http://design.medeek.com/resources/images/wall_su119_800.jpg
          Initially I will start with wood beams only: Sawn Lumber, Timber, Glulam, SCL (LVL, PSL, LSL)
          Similar to the truss plugin the beams created within the wall plugin will be able to be analyzed directly with the beam calculator on my website via the engineering tools (engineering icon). This chunk of code is already fairly well tested and is simply a matter of recycling some of it from the Truss Plugin.
          Later on I would also like to add steel beams (W, C, L, and HSS) but this will be based on user demand.
          I would also like to bring the engineering calcs directly within the plugin so that the user can run the numbers even if they are offline, something for the long term todo list.
          design.medeek.com
          • medeekM Offline
            medeek
            @charlie__v said:
            Nathaniel, all
            V 0.8.1b 06_25_18
            Thanks,
            Charlie
            Figured it out. The plugin is assuming that both the ext. and int. corner trim pieces will be six sided L-shaped polygon profiles. However with a thickness equal to width of the trim the resulting profile should then be a square. A simple fix and also a check for the situation where the thickness is greater than the width. When the thickness = width then the profile is a square and only four points are needed to describe the face to generate the profile.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.8.1c - 06.26.2018
              • Fixed a bug where wall corner trim thickness equals trim width.
              This will now allow the user to specify a 1.5" x 1.5" interior corner trim.
              design.medeek.com
              • medeekM Offline
                medeek
                Just about to wrap up the beam tool this morning and then I got thinking about the end treatment of beams:
                http://fdratlanta.com/images/gallery/pergolas/all-wood-custom-end-cut-rafter-pergola-vegas-style-garden.jpg
                I don't know what the technical term is for this but I call it the Start Cut and End Cut of a beam.
                http://www.tidewaterlumber.com/v/vspfiles/photos/End Cuts-2.jpg
                There could be any number of possibilities for the end cut profile:
                https://www.trexpergola.com/wp-content/uploads/2015/11/Trex-Pergola-Vision-Slight-End-Detail1.jpg
                I think I will just start with two options:
                • None
                • 45 deg (to mid height of beam)
                design.medeek.com
                  Charlie__V
                  Thank you Nathaniel, this resolves the issue.
                  And for the sake of clarity as to what the description means/is.....see pic below
                  • medeekM Offline
                    medeek
                    Thank-you for providing the additional clarification.
                    Inevitably I'm going to miss things, didn't even consider a square corner trim on an interior corner, funny thing is I've seen this sort of thing a million times though.
                    Please keep sending in the bugs and feature requests, I know there is more out there. Please also post up your models you create with the plugin I am curious as to how the plugin is actually being utilized.
                    design.medeek.com
                    • Bob JamesB Offline
                      Bob James
                      I know this sounds somewhat heretical but how about an option to set the full version to match the lite version for the times when all that's initially needed is a concept drawing?
                      Or is it obvious how to do it?
                      • medeekM Offline
                        medeek
                        Within the global settings under the Wall Tab you can set the default framing mode to one of the three options. This will then always bring up the wall draw tool with the selected mode, while still giving you the option to bump the wall to any of the other modes if you suddenly need to see the framing.
                        design.medeek.com
                          Bob James
                          Thank you
                          • medeekM Offline
                            medeek
                            Version 0.8.2 - 06.28.2018
                            • Added the ability to draw and edit beams with the Beams/Column Toolset.
                            • Glulam, PSL, LVL, LSL, Timber and Lumber beam types added to the beam module.
                            • Start and end cut options (miter,firecut) added to the advanced options for beams.
                            http://design.medeek.com/resources/images/wall_su120_800.jpg
                            View model here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            design.medeek.com
                              Bob James
                              Could you add the revision number to the rbz file?
                              medeek_wall_ext 0-8-1c.rbz
                              medeek_wall_ext 0-8-2.rbz
                              • medeekM Offline
                                medeek
                                Yes, that is probably not a bad idea.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Trying to find a decent wood grain to use for timber beams, any suggestions or images anyone is willing to share? I've got a decent end grain image, just looking for the side grain.
                                  P.S. I am also looking for a good pressure treated texture/material.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    The currently available beam types are:
                                    • Timber
                                    • LSL
                                    • Lumber
                                    • Glulam
                                    • LVL
                                    • PSL
                                    http://design.medeek.com/resources/images/wall_su121_800.jpg
                                    The number of plies can be 1, 2, 3, and 4
                                    Glulam species are currently Western Species and Southern Pine.
                                    SCL lumber (LVL, LSL, PSL) are the US industry standard sizes (Weyerhauser, Boise Cascade, Louisiana- Pacific).
                                    The miter cut puts the diagonal facing the bottom, the fire cut puts the diagonal facing the top.
                                    3D Warehouse
                                    The materials shown are the default (built-in) materials for the plugin if the materials option is turned on. I'm not totally in love with the various textures I have for LSL, PSL, LVL and Timber but it is better than nothing I suppose.
                                    For the timber and LVL option you can see that the end and edges have there own material assigned. Also if you apply a custom cut (after the fact) the way I have the materials assigned should allow you to maintain the proper end grain appearance.
                                    The only thing really missing is steel beams which should not be too big of a leap now that I have the whole beam system/module in place.
                                    Tomorrow I will jump back on the garage door module and see if we can make some headway with that.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      One last thing to note with the beam module is that all of the standard sizes are US/Imperial.
                                      I can add in standard sizes for metric however I will need that information. I currently have glulam beam data for the UK, South Africa and Australia but I will also need PSL, LVL, lumber, timbers and LSL.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.8.2b - 06.29.2018
                                        • Steel: Wide Flange (W) beam types added to the beam module.
                                        http://design.medeek.com/resources/images/wall_su122_800.jpg
                                        I've only added five wide flange sizes thus far. I just need to know what sizes are most typically used and I can add them in.
                                        Note that miter and fire cuts work with the steel beams as well.
                                        I was also thinking an advanced option for steel beams might be a nailer plate on top and/or bottom of the beam, again feedback in this regard will determine if I pursue this further.
                                        http://seblog.strongtie.com/wp-content/uploads/2014/05/Hanger-Install.jpg
                                        Another thing to note with beams is that you can move them around just like any other object in SketchUp using the SU move tool, unlike the walls. Technically you can move the walls with he SU move tool as well its just they won't stay connected if you do.
                                        Another advanced option for beams would be a hanger library which can be added to or modified by the user. I am already doing this sort of thing for window and door components so it isn't a big stretch for beam hangers.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 0.8.2c - 06.29.2018
                                          • Added a hanger library (customizable) and the ability to place hangers at the start and/or end of a beam.
                                          Hangers shown are: HU612, LUC26Z and LUS26
                                          http://design.medeek.com/resources/images/wall_su123_800.jpg
                                          The hanger library is located in the "hangers" sub-folder of the library folder of the plugin.
                                          I have a few Simpson Hangers included but any of these can be modified and additional SKP files can be put into this folder. The plugin will automatically allow the selection of any components found within this sub-folder when selecting hangers for beams within the draw and edit menus.
                                          I have contacted Simpson Strong-Tie in an effort to get a few more of their more common hangers that I can then simplify and include in the plugin. I am particularly interested in the HUCQ series.
                                          In order to minimize polygon count I typically eliminate most of the holes in the hangers and also any curved surfaces, the goal is to keep the file size below 50 kb if possible.
                                          I should also add that one could also include column caps in this sub-folder, like the CCQ/ECCQ/ECCLQ/CCTQ series.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            @bob james said:
                                            As of 0.8.2c the only thing in
                                            C:\Users\Bob\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins*medeek_wall_ext\library*
                                            is one window and one door. πŸ˜• : πŸ˜• :
                                            You'll need to download 0.8.2d, I'll roll it out tomorrow.
                                            design.medeek.com
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 79
                                            • 80
                                            • 16 / 80
