    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 0.7.9b - 06.18.2018
      • Sub-groups within wall panels can be made persistent by naming these groups or component instances to (custom1, custom2, custom3, etc...), also all other user defined geometry (ie. faces, text, lines and dimensions) are also retained when the wall panel is regenerated by the plugin.
      The naming of these persistent groups does not need to be in any order or even follow any particular naming convention, the key thing is that the instance name contains the word "custom" in it. The name is also not case sensitive.
      All other geometry and annotations do not require anything special to be retained, only groups and components.
      I've tested this out a bit this afternoon but it is quite new so I'm hoping everyone can work it over and see if they can break it or at least find any flaws in it.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Does anyone have a preference on what 2D symbol you would like to use to represent Simpson Strong-Walls.
        There are two types: Wood and Steel
        I can represent each type with a different symbol or use the same symbol for both.
        Catalog for both types is here for those interested:
        Strong-Wall Shearwalls Catalog
        Download our Strong-Wall® Shearwalls catalog that includes product data, engineering design information, and installation and anchorage details.
        (www.strongtie.com)
        I can also include other pre-fab shearwall panels from other manufacturers if requested, I'm only familiar with Simpson's products.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 0.8.0 - 06.21.2018
          • Added the ability to draw, move and delete pre-fab shear wall panels with the SSW Toolset.
          • Added a parameter in the global settings (General tab) in order to toggle SSW annotations independent of window, door and column annotations.
          • SSW annotations and representative geometry added to the 2D and 3D (no framing) modes.
          http://design.medeek.com/resources/images/wall_su109_800.jpg
          http://design.medeek.com/resources/images/wall_su110_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM Offline
            medeek
            The first thing you may notice with the SSW tool is that the current selection of sizes (widths and heights) of the pre-fab shearwalls is limited to 24" wide and between 8' and 12' in height. I also do not have any metric sizes or manufacturers other than these two (Hardy Frame HFX (Mitek) and Simpson Strong-Tie).
            I will roll out the full line of both manufacturers lines in the next few days however I have a few more smaller but hotter items that I would like to address first.
            The first item is to allow the user the ability to toggle the placement of windows/doors/columns/SSWs from their center to left or right. I'm considering using the SHIFT key to make this toggle unless there are any specific objections.
            Once I have this feature up and running I would like to make a tutorial video for both columns and SSW's since both of these items are fairly mature as they currently stand and a video would go along way in explaining some of the the parameters for each of these items.
            For the WSW (wood) series of Simpson Strong-Walls I have the trim feature now enabled and it seems fairly robust. This particular trim module is now primed for shed and gable wall situations where a WSW panel might be trimmed at some arbitrary incline rather than 90 degrees.
            The next major item is the external wainscoting or dual cladding configuration for exterior walls. Now that I have a firm handle on a decent trim method I will employ this same technique in dealing with ext. wainscoting which will alleviate the need for a complex algorithm in dealing with openings bisected by a change in cladding or sheathing. I should be able to wrap this one up in the next 24 hours.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.8.0b - 06.21.2018
              • Added the ability to toggle between center, left or right positioning (by pressing the CTRL key) while drawing windows, doors, columns or SSWs.
              This was a highly requested update and did not require any significant code changes. I strongly suggest everyone upgrade to this latest release to take advantage of the convenience of being able to toggle the position of these elements, a small upgrade but a large functional increase.
              design.medeek.com
              • medeekM Offline
                medeek
                Some progress is being made:
                http://design.medeek.com/resources/images/wall_su111_800.jpg
                I've got to work on the following to finish this up:
                • Wainscot ledge (this is typical for brick [rowlock])
                • Add in two additional parameters for trim above the wainscot (typical for stucco installations)
                • Logic to trim back window and door exterior trim as well as corner trim.
                • Logic to check for wainscoting with annotation placement.
                Not sure what to do with the bottom of the window location where it cuts out the wainscoting (brick, cultured stone etc...) this should also receive a ledge (ie. rowblock) as well.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Wainscot ledge:
                  http://design.medeek.com/resources/images/wall_su113_800.jpg
                  http://design.medeek.com/resources/images/wall_su114_800.jpg
                  The dimensions show the following parameters:
                  1.) Ledge Depth or Projection
                  2.) Ledge Height
                  3.) Wainscot Thickness
                  4.) Wainscot Air Gap
                  Notice that the ledge extends beyond the air gap to the sheathing or framing (if sheathing disabled).
                  Also note that wainscoting and ledge are able to bisect curved windows or doors as shown.
                  This additional feature is fairly complex so I am sure there may be some situations that I have not yet encountered and may be some cause for geometrical errors, only further testing will tell.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I've got a few small fires to put out this morning, but other than that what should be next on the list?
                    Current List:
                    • Interior Trim
                    • Garage Doors
                    • Int-int door casing
                    • Gypsum wrap for interior openings (without doors or windows installed)
                    • Wall Split Tool
                    • Wall Join Tool
                    • Gable Wall Tool
                    • Shed Wall Tool
                    • Wall Grouping
                    • Wall Paint Brush Tool (Transfer wall settings)
                    • Interior (Gypsum) Painting Tool
                    • More Windows, more doors (ie. sliding glass doors, french doors etc...)
                    • Beam Tool
                    • Add parameter for (glass) grille spacing both horz. and vert.
                    • Enable Material Library (skm files).
                    • Implementation of preset system into draw wall tool (with HTML menus)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 0.8.1 - 06.24.2018
                      • Enabled exterior wainscoting for Ext-Int walls.
                      • Added additional parameters to the wainscot menu for window and wall ledges.
                      • Wainscot "cut" parameter added to the exterior trim menu in order to optionally cut corner trim at the wainscot height.
                      http://design.medeek.com/resources/images/wall_su115_800.jpg
                      There are still a few more parameters and features that I feel needed to be added to this new feature class. I am also willing to take suggestions on how to make this more useful. Please give it a go and let me know what you think.
                      The wainscoting has also been added into the wall preset system.
                      Which brings me to a new idea I just had as I was applying presets to a few walls this morning. The wall preset feature is quite handy but rather tedious to use if one wants to apply a specific preset to a number of walls (granted the wall grouping feature would come in handy here but that is still in development).
                      What would be really handy is to have a "paintbrush" tool, where one could select any given wall panel and then all of its settings could then be transferred to any other wall panel with a single click of the mouse. Essentially treating the initially selected wall as a "preset" and then applying that preset to any walls selected. This would greatly speed up any changes one might need to make to a bunch of walls. I also think it would useful to have the tool differentiate between exterior and interior wall types. In other words if you initially select an exterior wall (ext-int) to copy those settings could not be applied to an interior wall (int-int).
                      I don't know that I should call it the paintbrush tool though since I was thinking about creating a tool that allows the user to apply a color (paint) to the interior gypsum. It would kind of be like the eye dropper tool in Photoshop, how about "Wall Dropper"?
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Tutorial Video 1 - Plugin Overview:
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Six Panel and Solid Double Doors:
                          http://design.medeek.com/resources/images/wall_su116_800.jpg
                          http://design.medeek.com/resources/images/wall_su117_800.jpg
                          I will add the full glass and half glass later today and then roll out a new sub-rev.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 0.8.1b - 06.25.2018
                            • Added the following double door types: solid, six panel, half glass, full glass.
                            http://design.medeek.com/resources/images/wall_su118_800.jpg
                            Choosing LH or RH places the door hardware on the indicated side of the double door. I should probably add an additional option "LRH" that places the hardware on both doors.
                            The image shows all as in-swing doors but they can also be drawn as out-swing as well.
                            I have not shown an astragal for any of the double doors but if someone would like that option added please indicate and also send me details on how you would like it modeled.
                            View model here:
                            3D Warehouse
                            design.medeek.com
                              Charlie__V
                              Nathaniel, all
                              Draw wall......exterior trim = yes....Draw wall in +X direction 10' long....Draw wall in +Y direction 10' long....Draw wall in +X direction 10' long, and new wall segment begins to draw over first wall segment drawn in +X direction.
                              Can you replicate this? (anyone else?)
                              V 0.8.1b 06_25_18
                              Thanks,
                              Charlie
                              X10ft_Y10ft_X10ft_Fail_06_26_2018.skp
                              • medeekM Offline
                                medeek
                                @charlie__v said:
                                Nathaniel, all
                                V 0.8.1b 06_25_18
                                Thanks,
                                Charlie
                                Can you replicate the error with ruby console open? then post or email me the error codes (nathan@medeek.com). I'm not seeing this error but you may have some setting or parameter set a certain value which could be causing this behavior.
                                When you get a wall being drawn at the origin like this (and its all exploded) it means the plugin is encountering an error during the draw phase of the operation and has aborted mid-stream.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Since I've got the beam icons already active on the beams/columns toolbar I've decided to try and put together the beam module. The HTML edit menu (draw tool menu is very similar):
                                  http://design.medeek.com/resources/images/wall_su119_800.jpg
                                  Initially I will start with wood beams only: Sawn Lumber, Timber, Glulam, SCL (LVL, PSL, LSL)
                                  Similar to the truss plugin the beams created within the wall plugin will be able to be analyzed directly with the beam calculator on my website via the engineering tools (engineering icon). This chunk of code is already fairly well tested and is simply a matter of recycling some of it from the Truss Plugin.
                                  Later on I would also like to add steel beams (W, C, L, and HSS) but this will be based on user demand.
                                  I would also like to bring the engineering calcs directly within the plugin so that the user can run the numbers even if they are offline, something for the long term todo list.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    @charlie__v said:
                                    Nathaniel, all
                                    V 0.8.1b 06_25_18
                                    Thanks,
                                    Charlie
                                    Figured it out. The plugin is assuming that both the ext. and int. corner trim pieces will be six sided L-shaped polygon profiles. However with a thickness equal to width of the trim the resulting profile should then be a square. A simple fix and also a check for the situation where the thickness is greater than the width. When the thickness = width then the profile is a square and only four points are needed to describe the face to generate the profile.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 0.8.1c - 06.26.2018
                                      • Fixed a bug where wall corner trim thickness equals trim width.
                                      This will now allow the user to specify a 1.5" x 1.5" interior corner trim.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Just about to wrap up the beam tool this morning and then I got thinking about the end treatment of beams:
                                        http://fdratlanta.com/images/gallery/pergolas/all-wood-custom-end-cut-rafter-pergola-vegas-style-garden.jpg
                                        I don't know what the technical term is for this but I call it the Start Cut and End Cut of a beam.
                                        http://www.tidewaterlumber.com/v/vspfiles/photos/End Cuts-2.jpg
                                        There could be any number of possibilities for the end cut profile:
                                        https://www.trexpergola.com/wp-content/uploads/2015/11/Trex-Pergola-Vision-Slight-End-Detail1.jpg
                                        I think I will just start with two options:
                                        • None
                                        • 45 deg (to mid height of beam)
                                        design.medeek.com
                                          Charlie__V
                                          Thank you Nathaniel, this resolves the issue.
                                          And for the sake of clarity as to what the description means/is.....see pic below
                                          • medeekM Offline
                                            medeek
                                            Thank-you for providing the additional clarification.
                                            Inevitably I'm going to miss things, didn't even consider a square corner trim on an interior corner, funny thing is I've seen this sort of thing a million times though.
                                            Please keep sending in the bugs and feature requests, I know there is more out there. Please also post up your models you create with the plugin I am curious as to how the plugin is actually being utilized.
                                            design.medeek.com
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 79
                                            • 80
                                            • 16 / 80
