    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      The group you created as a guide is getting in the way of letting the tool work properly.
      I copied the top edge of the cylinder down to give me a base line for the arcs and set a few guidelines to locate the ends of the arcs. The Arc on Surface tool works just fine.
      Click to animate
        applemango85
        think that my guides were drawn wrong so I redraw I but now I have the problem that the ellipses round is made up of many little lines not the one line which is a tad of a problem when trying to use jointpushpull on the cylinder surface
          applemango85
          thank you dave - ill see if that works now
            It's hard to tell what you have going on now without seeing the file.
              applemango85
              well I'm getting a solid line but my arc isn't happening - its either a mess or something like the attachment
              tools on surface.pdf
                applemango85
                oh my goodness, I think I got it to work - I deleted a few of the guidelines and zoomed out - not the prettiest looking object but it does the job
                thank you for sparing the time to help
                the key seems to be to note where the blue/purple dots appear and keep guides to a minimum
                test 1.skp
                  Good for you. If you use the inferencing tools you really shouldn't need much in the way of guides.
                    aofaofaof
                    thanks
                    • T
                      tonamu
                      Thanks for share.
                      tonamu
                      • fredo6F
                        NEW RELEASE: Tools on Surface 2.3a- 06 Oct 17
                        This maintenance release is required for:
                        • the support of usernames with non-ascii characters
                        • the compatibility for High Sierra for Mac users
                        • the support for hi-resolution screens
                        • the certification for SU2017
                        You will need to migrate to LibFredo6 7.7g or higher
                        Please see main post for download
                          rv1974
                          Fredo would it be hard to add fillet tool please?
                          • fredo6F
                            What do you mean?
                            This is a set of tools "on Surface".
                              rv1974
                              I mean fillet on 3d surface. See attached:
                              Say you have AB and CD lines. The red fillet connectig AB abd CD is demanded.
                              fil.skp
                                rv1974
                                Street - underground parking ramp junction. Example from real life (VERY common an tedious task).
                                ca.skp
                                • fredo6F
                                  @rv1974
                                  Somehow, you are asking if I could implement teh equivalent of BezierSpline 'on surface', of which the filetting is just one tool.
                                  That's probably possible, but non trivial.
                                  Actually the real difficulty with TOS is to handle the sharp changes in surface, because this is where directions may change abruptly. If everything was on a smooth surfce it would be simpler.
                                  I'll think about it.
                                    rv1974
                                    I'd gladly use this 3d fillet on more or less 'calm' surfaces and get an error report on sharp ones. no problem.
                                    • E
                                      Einstein
                                      Hi!
                                      As you can see in the screenshot, I selected two neighbouring surfaces. Offset on Surface creates one big offset for them both, together. I was thinking, if it's possible that offsets would be created separately, independently for each surface?
                                      • fredo6F
                                        @einstein said:
                                        Hi!
                                        Why don't you select each face for individual offset?
                                        • E
                                          Einstein
                                          Because in another model I have tones of surfaces to offset and selecting them one by one would be haaard.
                                            rv1974
                                            Use one of lattisizers and then intersect it
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 28 / 32
