    Create layers by materials
    18 Posts 7 Posters 6.1k Views 7 Watching
      Thanks Didier!
      I thought it existed already... but I couldn't find it, so I wrote one of my own πŸ˜’
      • Didier BurD
        Didier Bur
        much more cleverly coded than mine btw... πŸ˜‰
        DB
        • Z
          zsotti
          Dear TIG and Didier !
          Thank you very much for your quick reply and of course solution.
          I have copied the script of TIG and I am going to try it as soon as possible. I will give you feedback for sure. Maybe funny for you, but it could be one of my most important plugins. I will share with you why, later on.
          PS. Dear Didier, I was not able to browse your site. Is it my fault or is it offline sometimes?
          • massimoM
            massimo Moderator
            http://forums.sketchucation.com/viewtopic.php?p=360023#p360023 πŸ˜‰
            • Didier BurD
              Didier Bur
              The site was down yesterday after the PC is was on burned out 😞
              I'm actually restoring the saved database copy of it...
              DB
              • Z
                zsotti
                Hi !
                What I have promised, my feedback:
                1 / TIG's script - surely my fault (I am a rookie in ruby scripting), copied the RB in plugins folder with the right file name, but I have not found the 'command' in any menu. I have tried to write a menu definition according other RB scripts but I did not succeed, sorry.
                2 / Didier's script - after his server came back to life I was shocked about how many scripts he has written. Congratulations! I have downloaded the right one and it does (in two steps) exactly what I need.
                Thank you for your support!
                Zsotti
                  My script does not have a menu entry.
                  It's usage as described is
                  TIG.faces2materiallayers
                  in the Ruby Console
                    rbg
                    Hi there,
                    is there a chance to make this script work for sketchup 2018?
                    The Tig version doesnt work
                    and the Didier makes the layers but doesnt put the faces in the layers.
                    kind regards
                    Richard
                      Edit the ancient RB file [in a plain-text editor, like Notepad++ or BBedit] and change the line:
                      def self
                      to read:
                      def self.faces2materiallayers
                      It should then work...
                      Then in the Ruby Console, to run it, you use:
                        rbg
                        Thanks for the quick reply TIG
                        I have tried your adjustment and then i get this error code:
                        Error: #<NameError: undefined local variable or method mat' for TIG:Module> C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/TIG-faces2materiallayers.rb:11:in block in faces2materiallayers'
                        C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/TIG-faces2materiallayers.rb:8:in each' C:/Users/richard/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/TIG-faces2materiallayers.rb:8:in faces2materiallayers'
                        <main>:in <main>' SketchUp:1:in eval'
                        do you have any suggestions?
                        kind regards
                        Richard
                          This is a very very ancient RB...
                          Try this alternative...
                          ### Copy/paste code into a file called
                          ### 'TIG-faces2materiallayers.rb' in the Plugins folder
                          module TIG
                          def self.faces2materiallayers()
                            model=Sketchup.active_model
                            model.active_entities.grep(Sketchup;;Face).each{|face|
                              next unless mat=face.material
                              name=mat.display_name
                              face.layer=model.layers.add(name)
                          ### Usage; TIG.faces2materiallayers
                          I think it'll work...
                          However, assigning layers to geometry, like faces and edges, is usually a very bad idea !!!!
                          They should almost always be given Layer0.
                            marcelp102
                            Dear TIG, after entering TIG.faces2materiallayers in ruby scriptbox I only get []. Any help?
                              For the avoidance of doubt, you must paste the whole of the code into the Ruby Console.
                              Then to run it use TIG.faces2materiallayers
                              For it to work there must be faces in the current active entities context, and they must have materials assigned to their fronts.
                              Faces within groups/components are NOT considered, unless you first edit the container to change the active entities context...
                              If those conditions are met, then any faces should be reassigned to a Layer named after their [front] material, which is made if it does not exist.
                              To reiterate my earlier comments, moving raw geometry to a layer other than Layer0 is generally not a good idea...
                              But if you want to do it then this way should work...
                                avanoppen
                                Hi TIG,
                                I'm dying to try the script. Question though: since Sketchup introduced tags as a replacement for layers, how would the script change? Looking forward to your reply, Gus
                                  It doesn't change much at all - under the hood the API still calls them 'layers'.
                                  Very similar to the way it still sees 'scenes' as 'pages' - changed because Layout arrived...
