    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 96.9k Views 14 Watching
    • N Offline
      nlipovac
      @nlipovac said:
      This is Thea rendering in SU window, the same thing Vray have also.
      • N Offline
        nlipovac
        It was just an idea, thank you for this that you already accomplished with this plugin. πŸ˜„
        • samuel_tS Offline
          samuel_t
          Overlay feature request is out of my skills for now. Maybe another dev can, since code is open-source.
          • samuel_tS Offline
            samuel_t
            Thank you for your idea. πŸ˜„
            • JQLJ Offline
              JQL
              I will talk about this case with someone...
              www.casca.pt
              Visit us on facebook!
              • samuel_tS Offline
                samuel_t
                @jql said:
                Thea has viewport rendering which, for single monitors brings sketchup to life. Your plugin, as it is realtime, would be amazing with viewport rendering.
                Yeah. There is an expensive workaround: to buy several monitors. πŸ˜† More seriously, I will try to find a way to synchronize PBR Viewport with SketchUp.
                • filibisF Offline
                  filibis
                  @samuel_t said:
                  • Plugin comes with a tiny PBR materials library. Donate to make it grow!
                  Take a look at these websites for free (CC0) textures: Pixel-Furnace, CC0Textures, freepbr. You can provide link to these sites maybe?
                  I think you should indicate that we need to open a collection to use PBR materials you provided. People may not find PBR folder you generated easily.
                  In addition to 'saving, opening and creating' a model, when we "apply all changes" in the PBR material editor, Chromium pops-up and updates the view as well.
                  HDR images working fine πŸ‘ Can we rotate them somehow? That would be cool πŸ™‚
                  • samuel_tS Offline
                    samuel_t
                    Hello filibis, thanks a lot for these links.
                    I added following sentence in official README:
                    Additionally, you should have a new "PBR" materials collection in "Materials" tray. Enjoy! πŸ˜‰
                    You are right. I forgot to mention this case.
                    I don't understand. You want to rotate HDRi?
                    • filibisF Offline
                      filibis
                      Yes. Rotating the HDRi 360Β° will change the lighting directions since HDRis gather light intensity from the brightness of pixel colours. Thus normal maps will behave accordingly.
                      Something like this:
                      https://snakehillgames.files.wordpress.com/2013/10/stonewall_twoprofiles.gif
                      Or simply to change background view:
                      https://i.stack.imgur.com/mx02K.gif
                      • samuel_tS Offline
                        samuel_t
                        I understand now. Thanks for the trick!
                        • samuel_tS Offline
                          samuel_t
                          A new version is available, 1.3.2.
                          • Add macOS support. Test n' report.
                          • Add 2 new materials in PBR library.
                          • samuel_tS Offline
                            samuel_t
                            A new version is available, 1.3.3.
                            • Add exposure control in Viewport.
                            Exposure
                            • Add one material to "PBR" library.
                            • Disable Viewport update on save.
                              It was too slow. I recommend to set a shortcut for menu entry "Force Viewport Update".
                            Shortcut
                              peerman
                              Hi, I really want to test this plugin but when I install the plugin (or after restarting SU) I get the message that Chromium cannot be found "Get latest". I'm working on a Mac. I can change materials but force viewport update crashed SU. I'm also not sure how I can start a render? Is that the force viewport update or am I missing something. The help page on github is not really helping as well.
                              I hope you can help/fix. The plugin looks promissing! Thanks!
                              Best,
                              Peter
                              iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                              • samuel_tS Offline
                                samuel_t
                                Best,
                                Peter
                                Hi Peter,
                                Viewport use Chromium. Viewport opens automatically.
                                I don't have a Mac, this is why its support may be buggy.
                                It seems you have a problem related to path or chmod.
                                Please open Ruby Console in SketchUp and paste this:
                                PBR;;Chromium.executable
                                Then give me back console answer with a screenshot.
                                Thanks! πŸ˜‰
                                • samuel_tS Offline
                                  samuel_t
                                  Hello. PBR plugin version 1.3.1 is available. πŸ˜„
                                  What's new?
                                  • Plugin comes with a tiny PBR materials library. Donate to make it grow! πŸ˜‰
                                  • When you save, open or create a model: Viewport is automatically updated.
                                    Technically, nginx Web server has been replaced by Chromium Web browser.
                                  ❗ As part of an update, remember to disable plugin before uninstalling-reinstalling it.
                                  • samuel_tS Offline
                                    samuel_t
                                    The new PBR plugin version (1.3.4) :
                                    • Keeps camera position in Viewport.
                                    • Increases material library to 9 elem.
                                    • Fixes an exposure issue in Viewport.
                                      peerman
                                      Hi Samuel,
                                      I get this:
                                      PBR::Chromium.executable
                                      /Users/peter/Library/Application Support/SketchUp 2018/SketchUp/Plugins/pbr/Chromium/Mac/Chromium.app/Contents/MacOS/Chromium
                                      I can get inside the plugin folder and find the chromium app but I can't start it. All priviliges are correct for the files read and write are set for all files within the pbr folder. Maybe if I replace the Chromium app with a newer one from the internet it works? I will try today.
                                      Best,
                                      Peter
                                      Edit: OK, after replacing the chromium app with the latest from chromium.org the viewport is working!
                                      • samuel_tS Offline
                                        samuel_t
                                        @peerman said:
                                        Hi Samuel,
                                        I get this:
                                        Best,
                                        Peter
                                        Hello Peter,
                                        File: exists. Read/Write: granted. OK. Now...
                                        Open a Terminal in OS this time and paste this:
                                        chmod +x '/Users/peter/Library/Application Support/SketchUp 2018/SketchUp/Plugins/pbr/Chromium/Mac/Chromium.app/Contents/MacOS/Chromium'
                                        It should make Chromium file executable.
                                        Best regards,
                                        • samuel_tS Offline
                                          samuel_t
                                          @peerman said:
                                          [...] I'm also not sure how I can start a render? Is that the force viewport update or am I missing something. The help page on github is not really helping as well. [...]
                                          I added a Workflow section in GitHub README: https://github.com/SamuelTS/SketchUp-PBR-Plugin#workflow
                                          • samuel_tS Offline
                                            samuel_t
                                            Next PBR plugin version will include latest Chromium macOS stable version.
                                            • 4 / 6
