    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 102.6k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      @jql said:
      Thea has viewport rendering which, for single monitors brings sketchup to life. Your plugin, as it is realtime, would be amazing with viewport rendering.
      Yeah. There is an expensive workaround: to buy several monitors. πŸ˜† More seriously, I will try to find a way to synchronize PBR Viewport with SketchUp.
      • filibisF Offline
        filibis
        @samuel_t said:
        • Plugin comes with a tiny PBR materials library. Donate to make it grow!
        Take a look at these websites for free (CC0) textures: Pixel-Furnace, CC0Textures, freepbr. You can provide link to these sites maybe?
        I think you should indicate that we need to open a collection to use PBR materials you provided. People may not find PBR folder you generated easily.
        In addition to 'saving, opening and creating' a model, when we "apply all changes" in the PBR material editor, Chromium pops-up and updates the view as well.
        HDR images working fine πŸ‘ Can we rotate them somehow? That would be cool πŸ™‚
        • samuel_tS Offline
          samuel_t
          Hello filibis, thanks a lot for these links.
          I added following sentence in official README:
          Additionally, you should have a new "PBR" materials collection in "Materials" tray. Enjoy! πŸ˜‰
          You are right. I forgot to mention this case.
          I don't understand. You want to rotate HDRi?
          • filibisF Offline
            filibis
            Yes. Rotating the HDRi 360Β° will change the lighting directions since HDRis gather light intensity from the brightness of pixel colours. Thus normal maps will behave accordingly.
            Something like this:
            https://snakehillgames.files.wordpress.com/2013/10/stonewall_twoprofiles.gif
            Or simply to change background view:
            https://i.stack.imgur.com/mx02K.gif
            • samuel_tS Offline
              samuel_t
              I understand now. Thanks for the trick!
              • samuel_tS Offline
                samuel_t
                A new version is available, 1.3.2.
                • Add macOS support. Test n' report.
                • Add 2 new materials in PBR library.
                • samuel_tS Offline
                  samuel_t
                  A new version is available, 1.3.3.
                  • Add exposure control in Viewport.
                  Exposure
                  • Add one material to "PBR" library.
                  • Disable Viewport update on save.
                    It was too slow. I recommend to set a shortcut for menu entry "Force Viewport Update".
                  Shortcut
                    peerman
                    Hi, I really want to test this plugin but when I install the plugin (or after restarting SU) I get the message that Chromium cannot be found "Get latest". I'm working on a Mac. I can change materials but force viewport update crashed SU. I'm also not sure how I can start a render? Is that the force viewport update or am I missing something. The help page on github is not really helping as well.
                    I hope you can help/fix. The plugin looks promissing! Thanks!
                    Best,
                    Peter
                    iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                    • samuel_tS Offline
                      samuel_t
                      Best,
                      Peter
                      Hi Peter,
                      Viewport use Chromium. Viewport opens automatically.
                      I don't have a Mac, this is why its support may be buggy.
                      It seems you have a problem related to path or chmod.
                      Please open Ruby Console in SketchUp and paste this:
                      PBR;;Chromium.executable
                      Then give me back console answer with a screenshot.
                      Thanks! πŸ˜‰
                      • samuel_tS Offline
                        samuel_t
                        Hello. PBR plugin version 1.3.1 is available. πŸ˜„
                        What's new?
                        • Plugin comes with a tiny PBR materials library. Donate to make it grow! πŸ˜‰
                        • When you save, open or create a model: Viewport is automatically updated.
                          Technically, nginx Web server has been replaced by Chromium Web browser.
                        ❗ As part of an update, remember to disable plugin before uninstalling-reinstalling it.
                        • samuel_tS Offline
                          samuel_t
                          The new PBR plugin version (1.3.4) :
                          • Keeps camera position in Viewport.
                          • Increases material library to 9 elem.
                          • Fixes an exposure issue in Viewport.
                            peerman
                            Hi Samuel,
                            I get this:
                            PBR::Chromium.executable
                            /Users/peter/Library/Application Support/SketchUp 2018/SketchUp/Plugins/pbr/Chromium/Mac/Chromium.app/Contents/MacOS/Chromium
                            I can get inside the plugin folder and find the chromium app but I can't start it. All priviliges are correct for the files read and write are set for all files within the pbr folder. Maybe if I replace the Chromium app with a newer one from the internet it works? I will try today.
                            Best,
                            Peter
                            Edit: OK, after replacing the chromium app with the latest from chromium.org the viewport is working!
                            • samuel_tS Offline
                              samuel_t
                              @peerman said:
                              Hi Samuel,
                              I get this:
                              Best,
                              Peter
                              Hello Peter,
                              File: exists. Read/Write: granted. OK. Now...
                              Open a Terminal in OS this time and paste this:
                              chmod +x '/Users/peter/Library/Application Support/SketchUp 2018/SketchUp/Plugins/pbr/Chromium/Mac/Chromium.app/Contents/MacOS/Chromium'
                              It should make Chromium file executable.
                              Best regards,
                              • samuel_tS Offline
                                samuel_t
                                @peerman said:
                                I'm also not sure how I can start a render? Is that the force viewport update or am I missing something. The help page on github is not really helping as well. [...]
                                I added a Workflow section in GitHub README: https://github.com/SamuelTS/SketchUp-PBR-Plugin#workflow
                                • samuel_tS Offline
                                  samuel_t
                                  Next PBR plugin version will include latest Chromium macOS stable version.
                                    peerman
                                    So I played around with it a bit. A couple of things I noticed. The suns position doesn't get exported and the UVs aren't coming through correct.
                                    I've added a screenshot. The house is exploded (was a component) but that didn't help.
                                    It looks promising!
                                    Best,
                                    Peter
                                    • samuel_tS Offline
                                      samuel_t
                                      @peerman said:
                                      the UVs aren't coming through correct. [...]
                                      This is a known issue and there is a workaround. πŸ˜„
                                      Texture looks weird with perpendicular lines around.
                                      With your preferred photo editing software, resize texture image to a power of 2 in height and width (e.g. 1024x2048, 2048x2048, 4096x4096). Reimport texture image in SketchUp.
                                      Source: https://github.com/SamuelTS/SketchUp-PBR-Plugin/blob/master/docs/help.md#in-pbr-viewport
                                        peerman
                                        Ah thank you! I should've read the documentation better... 😳
                                        I will try it again.
                                        Best,
                                        • samuel_tS Offline
                                          samuel_t
                                          Best,
                                          No problem, Peter.
                                          Best regards,
                                          Samuel
                                          • samuel_tS Offline
                                            samuel_t
                                            v1.3.5 of PBR plugin has just been released. πŸ˜„
                                            • Enhance macOS support.
                                            • Upgrade Chromium browsers.
                                            • Update sunlight direction. Beta ❗
                                            • Add two materials to library.
                                            • Clarify menu and Viewport UI.
                                            • Fix camera's orbit control damping.
                                            • 3 / 6
