    [Request] Edge loop Selection
    19 Posts 13 Posters 14.4k Views 13 Watching
    • ken28875K Offline
      ken28875
      @ken28875 said:
      Hi TIG,
      You're correct, "ThomThom's Selection Toys only selected face loops, that is loops composed of faces".
      Oops, I meant to reply to mitcorb, not TIG. 😄
      Follow Your Dreams.
        It's pretty easy to switch to wire-frame or Xray mode and position your camera to view 'side on' and then use select by fence with left-right drag so only things that are wholly inside the fence get picked [as opposed to right-left drag fence making which selects everything that has just a part of itself inside the fence]
        Voila! you have the loops edges selected in 'one foul swoop'.
        If you do select something that's not wanted then remove it from the selection-set by holding down shift+ctrl and re-picking it... ❓ 💭
        • EarthMoverE Offline
          EarthMover
          Fredo's Hover Select has an option to "Extend selection to cofacial and aligned edges". It works to do a loop select on clean quads. Another option would be a script that I think Jim or TIG helped me with a while back called Select Edges by Z. You can pick an edge and run the script and it will pick all other edges on that Z coordinate.
          selectedgesbyZ.rb
          Content Creator at Skapeup
          • ken28875K Offline
            ken28875
            Hi TIG,
            Yes, that's a method I use sometimes, but it works on simple shape like the example I showed or on model with a few details. I was hoping for a plugin that will quickly help select edge loops on complex models.
            Thanks though.
            Have a great day! ☀
            _KN
            Follow Your Dreams.
            • ken28875K Offline
              ken28875
              Hey Adam,
              Thanks for the tips. I tried it but did not work so well as my model is quite complex and has lots of details.
              Take care,
              _KN
              Follow Your Dreams.
                blindcop
                I know this is an old post to bump, but in case someone finds it my new plugin was written to do this exactly:
                404 Not Found
                (sketchucation.com)
                • josephkim626J Offline
                  josephkim626
                  Thanks for the extension that you have included.
                  would it be possible to tweak it to just include "connected edges"?
                  • 5 Offline
                    5k18a
                    Any one know what plugin is it from this video https://www.youtube.com/watch?v=bA4tGgOFQJQ&t=553s It's great for selecting edges in a loop.
                      SketchUV and Profile Builder have this tool
                      • cengiziletenC Offline
                        cengizileten
                        On the quadface tools, there is select loop button.
                          Bruce Watt
                          Brilliant!, I have quad tools 'select' set on a shortcut. Just right click on the line and select 'selection'-> 'select loop'.
                          Many thanks, cengizileten
                          SKUP PRO 2021 latest version / update
                          Windows 10 Pro
                          Dell Alienware Aurora R10 AMD
                          AMD Ryzen™ 9 3900X
                          NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                          • starshipS Offline
                            starship
                            I´m a bit late to the party, but... While Twilight render has other main purpose, looks like in the Pro version it has tools that allows to select edge loops: https://www.twilightrender.com/index.php/component/content/article?id=187:twilight-render-tutorials-tools
                            Hope that helps.
