    [Request] Edge loop Selection
    19 Posts 13 Posters 13.8k Views 13 Watching
      Jim
      Probably a gross over-simplification, but can't you grab the next connected edge whose angle between the current edge is less than a specified angle?
      As you say, regular geometry is required. It would not work so well on sub-divided mesh.
      • ken28875K Offline
        ken28875
        Hi TIG,
        You're correct, "ThomThom's Selection Toys only selected face loops, that is loops composed of faces".
        Hopefully someone will manage to figure out a script for that plugin.
        Thanks,
        _KN
        Follow Your Dreams.
        • ken28875K Offline
          ken28875
          @ken28875 said:
          Hi TIG,
          Oops, I meant to reply to mitcorb, not TIG. 😄
          Follow Your Dreams.
            It's pretty easy to switch to wire-frame or Xray mode and position your camera to view 'side on' and then use select by fence with left-right drag so only things that are wholly inside the fence get picked [as opposed to right-left drag fence making which selects everything that has just a part of itself inside the fence]
            Voila! you have the loops edges selected in 'one foul swoop'.
            If you do select something that's not wanted then remove it from the selection-set by holding down shift+ctrl and re-picking it... ❓ 💭
            • EarthMoverE Offline
              EarthMover
              Fredo's Hover Select has an option to "Extend selection to cofacial and aligned edges". It works to do a loop select on clean quads. Another option would be a script that I think Jim or TIG helped me with a while back called Select Edges by Z. You can pick an edge and run the script and it will pick all other edges on that Z coordinate.
              selectedgesbyZ.rb
              Content Creator at Skapeup
              • ken28875K Offline
                ken28875
                Hi TIG,
                Yes, that's a method I use sometimes, but it works on simple shape like the example I showed or on model with a few details. I was hoping for a plugin that will quickly help select edge loops on complex models.
                Thanks though.
                Have a great day! ☀
                _KN
                Follow Your Dreams.
                • ken28875K Offline
                  ken28875
                  Hey Adam,
                  Thanks for the tips. I tried it but did not work so well as my model is quite complex and has lots of details.
                  Take care,
                  _KN
                  Follow Your Dreams.
                    blindcop
                    I know this is an old post to bump, but in case someone finds it my new plugin was written to do this exactly:
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61884
                    • josephkim626J Offline
                      josephkim626
                      Thanks for the extension that you have included.
                      would it be possible to tweak it to just include "connected edges"?
                      • 5 Offline
                        5k18a
                        Any one know what plugin is it from this video https://www.youtube.com/watch?v=bA4tGgOFQJQ&t=553s It's great for selecting edges in a loop.
                          SketchUV and Profile Builder have this tool
                          • cengiziletenC Offline
                            cengizileten
                            On the quadface tools, there is select loop button.
                              Bruce Watt
                              Brilliant!, I have quad tools 'select' set on a shortcut. Just right click on the line and select 'selection'-> 'select loop'.
                              Many thanks, cengizileten
                              SKUP PRO 2021 latest version / update
                              Windows 10 Pro
                              Dell Alienware Aurora R10 AMD
                              AMD Ryzen™ 9 3900X
                              NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                              • starshipS Offline
                                starship
                                I´m a bit late to the party, but... While Twilight render has other main purpose, looks like in the Pro version it has tools that allows to select edge loops: https://www.twilightrender.com/index.php/component/content/article?id=187:twilight-render-tutorials-tools
                                Hope that helps.
