    [Plugin] Q JS ALIGN TOOLBAR
    63 Posts 35 Posters 113.3k Views 35 Watching
      micdidi
      CAN'T SEE THE ICON???
      • Bob JamesB
        Bob James
        This is one of my most frequently used plugins since Jan Sandstrom (Pixero) first created it in 2009 (and then with CadFather's welcome addition of the toolbar).
        I still wish there was some way to choose which one is the one you want to stay fixed 😎
        • pbacotP
          This plugin works fine for me. Thanks! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ Really speeds things up in some situations. SU should have this natively as does any CAD package.
          I am also looking for an align plugin that would work with the current context axes. For example if you are in a component it would use the component axes as reference.
          Also I wonder whether the plugin could be made to respect one locked object. Then the alignment would keep a locked object in place, and align the others to it. (It would have to reject operations with more than one locked object selected.)
          • CadFatherC
            CadFather
            i will look into this, though i can already predict a higher climb than my skills might allow..
            meantime there are a few good scripts around: didier 2d align, su4you align and sd mitch A&D - and probably others i forget.
            • C
              cesaro36
              Is it possible to make this align plugin to work within a component/group? I usually have nested components and frequently rotated, the align plugin doesn't seem to work when the container has been rotated, so I assume that it needs to work with local coordinates instead of global ones.
              πŸ˜•
                Try s4u8 Align Toolsby SuForYou πŸ˜‰
                  Milo
                  Thanks you for this plugin πŸ˜„
                  FaceBook
                  • C
                    cesaro36
                    If anyone interested, another tool for that matter.
                    http://www.eltallerconstructor.com/distribute-objects-sketchup-plugin/
                    http://www.eltallerconstructor.com/wp-content/uploads/2016/01/Captura_de_pantalla_012616_075350_PM-300x147.jpg
                    • L
                      Luisfon
                      Don't see plugin folder just ifcplugin with DLL files, exe files and config files in it.
                        Install it from here: https://sketchucation.com/pluginstore?pln=Q_JS_Align
                        • MatteM
                          Matte
                          Hi All, before I spend many hours playing with this cool plugin.. Could someone with experience with it give me their advice if this plug in will "solve my problem"? My present problem is that I have hundreds and hundreds of rectangular faces (There all suppose to be at the same Z height). The problem is many of them are rotated ( + or - ) .01 degrees from each other (For Example). So when I make a rectangle that connects between the four corners of 4 different rectangles... It does not make a rectangle. Could I make one of these existing rectangles "Perfect" where all 4 corners are at the same Z height.... And then use this plug in to Pick "bad" rectangle and "say" align to good rectangle and all the corner Z heights of the "bad" triangle will now match the "good" triangle?
                          Thanks !!! Mattee
                          (PS right now the OCD has taken over and I am manually fixing each rectangle one at a time !!!!)
                          • pbacotP
                            It sounds like your rectangles are not all parallel to the ground plane?
                            If you are talking about 2d rectangles, yet rotated slightly in the z axis, you may want a plugin like "flatten vertices", I forget if that's the right name. But the objects would have to be ungrouped and they would not be true rectangles when flattened out.
                            If they are grouped rectangles, This tool will not change their orientation, It would only align top bottom or middle of each group.
                            If all the geometry is ungrouped, I don't see how this plugin would give a useful result.
                            • MatteM
                              Matte
                              Thanks, you just saved me hours of time traveling down a dead end road!
                              PS there are no blocks, all lines and surfaces are all on the same layer,
                              so nothing to explode, just no consistent z height for all rectangles.
                              • ArckadiaA
                                Arckadia
                                Thanks, works perfectly, πŸ‘ i test it on sketchup make 2017 to align 2 circles. I started a longtime ago on another 3D software so, maybe i am more attentive on this kind of tool.
                                Q JS Align is definitely that you must have to be precise. I make a vase, an amphora : an object where circumference is necessary.
                                Maybe i get lost a bit but i discovered by chance Sketchup when i was on Hammer, ( another 3D Soft). I would like to build house or something like that. But quickly i get started in a crazy project with 17 century architecture. I don't know if i'm gonna integrate it in a level design... etc... πŸ˜›
                                Have a nice day users from Sketchup and thanks to CadFather.
                                • E
                                  Einstein
                                  Hello!
                                  I'd love to have a version of this plugin which respects group's local axes over world's (model's or global axes or whatever it's called).
                                  Currently, if I select nested geometry and try to align it, it will align according to world's axes. In my opinion, more logical (and useful too!) would be relying on group's axes, because right now, if the whole group is rotated (so its axes don't match world axes) and I open it and align nested entities, they will be aligned incorrect in relation to group's bounds.
                                  Also, when aligning groups it would be nice to have choice whether aligning takes geometry into account (current behaviour) or just origins of groups.
                                  This plugin also has a problem with losing selection after performing UNDO.
                                  I know this is an old script but perhaps somebody would take it and include any of these improvements.
                                    ricdach
                                    there is or will be a version for Sketchup 2026? Appreciated, thanks
                                      It's almost certainly OK on v2026 as far as it did with recent versions already - which was 'not faultlessly'.
                                      But why not try it...
                                      • 3 / 4
