    Transparent material in preview, not transparent in render
    renderpluginsextensions
    4 Posts 2 Posters 2.5k Views 2 Watching
      makro88
      Hi everyone,
      I'm encountering a problem with an emissive material. Using vray 3.4 on sketchup 2017.
      Basically, in the material preview I see the correct material, with transparency correctly displayed.
      But in the frame buffer, it shows the updated texture with plain white colour in place of the transparency.
      https://i.imgur.com/fh7MXHP.png
      Any thoughts? Thanks!
      • filibisF Offline
        filibis
        Can you share your texture and opacity map (transparency)?
        Here is a working example:
        Note that it might not work with GPU acceleration or interactive mode.
        Check this for more information about Emissive Material.
          makro88
          Hi filibis,
          Thank you very much - disabling the gpu acceleration, the opacity map worked as supposed to.
          I wonder if it's a bug or a limitation.
          • filibisF Offline
            filibis
            I think it's because GPU rendering is fairly new technology comparing to CPU rendering, so i believe it's just a matter of time that will support every feature like in CPU.
