    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 752.2k Views 163 Watching
    • dereiD Offline
      derei
      @Box
      @box said:
      Ooops, I think I made my cargo net just a bit too flexible!
      I didn't really understand all controls for Cloth, how do you control the elasticity of a material without making the cloth stiffer?
      For example, in your case, for the ball to not slip through the holes in the net, but the net to fall naturally?
      • jo-keJ Offline
        jo-ke
        that's it. Thank you
        http://www.zz7.de
        • HornOxxH Offline
          HornOxx
          ... with ClothWorks you can catch a lot of animals - but not a fish - a bug? πŸ˜„ πŸ˜„ πŸ˜„
          never trust a skinny cook
            smashor
            @dave r said:
            This is with one of the SUC fabrics.
            [attachment=1:2ig71rmb]<!-- ia1 -->AC desk plaid cu.png<!-- ia1 -->[/attachment:2ig71rmb]
            [attachment=0:2ig71rmb]<!-- ia0 -->AC desk plaid.png<!-- ia0 -->[/attachment:2ig71rmb]
            How did you do those wrinkles? Looks very cool!
              Anton_S
              Haven't checked but fish can be one of Known Limits and Limitations. And of course, I'm going to improve contact generation in a major release, which could fix the issue. We'll see.
                Anton_S
                @solo said:
                Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
                I may have to add this as a workflow feature. Should be very simple.
                  Anton_S
                  @jo-ke said:
                  I have problems with textures. what did I wrong?
                  @box said:
                  Make sure the texture is applied to the faces not the group.
                  In addition to Box's response, to apply a texture to a simulated cloth, follow the step below:
                  1. Select the simulated cloth
                  2. Click on the undrape icon. This should reset the layout of the cloth
                  3. Enter the context of the cloth
                  4. Apply a desired texture directly to the front and/or back faces
                  5. Exit the context of the cloth
                  6. Click on the toggle draped icon again to renew the layout of the cloth
                  Here is the part of the Draping Sphere video performing these steps (starts at 1:25):
                  https://youtu.be/u-DZ17Nls9k?t=1m25s
                    Anton_S
                    @boofredlay said:
                    @solo said:
                    I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
                    Yep.
                    Draw a line, divide it and drape.
                    And if you apply Loop Subdivision to the simulated edges group, the edges would subdivide just like cloth.
                    • I Offline
                      imabzeous
                      I tried to buy the plugin but unfortunately i can only buy it via paypal which isn't supported in my country. only master cards visa cards works. so if author or sketchucation admins can help me out?
                      • FrederikF Offline
                        Frederik
                        @pixero said:
                        Doesn't Bezier spline Polyline divider for Animation do what you want?
                        @solo said:
                        bezier spline worked like a charm.
                        Perhaps you should read all posts before posting a reply...
                        Cheers
                        Kim Frederik
                        • PixeroP Offline
                          Pixero
                          @solo said:
                          [Too bad there is no plugin that can divide a welded line into equal segments.
                          Draw any curve or use the Freehand tool or weld lines. Right click. Convert to Polyline divider for animation and set max length.
                          (That was once made on my request when I was making advanced animation paths in SketchUp.)
                          Sometimes, if the curve doesn't fit with the Max length, there can be one edge with different length at the end.
                          • BoxB Offline
                            Actually Frederik, Pixero was answering the question/statement that Solo made after he said it worked like a charm.
                            • BoxB Offline
                              Here's a bit of a summer print skirt made by dropping a cloth with a hole in it over a rudimentary waist. A sphere with a pulled top and scaled to an oval.
                              • PixeroP Offline
                                Pixero
                                @Frederik:
                                In his reply he asked for a way of dividing lines into equal segments and my reply answered that.
                                  sofie9536
                                  clothwork is a great tool to create models in sketchup and to use in iclone. Here is a little example:
                                  coll. objects
                                  in iclone
                                  • HornOxxH Offline
                                    HornOxx
                                    @sofie9536 said:
                                    ...Here is a little example
                                    πŸ‘ this upper Collider is a good isea !
                                    • FrederikF Offline
                                      Frederik
                                      All good...
                                      I interpreted it as if you hadn't read all posts...
                                      Cheers
                                      Kim Frederik
                                        Anton_S
                                        Announcing version 1.1.0: https://sketchucation.com/pluginstore?pln=ClothWorks
                                        1. Fixed toolbar and dialogs on Mac OS X. Now dialogs are no longer displayed as modal dialogs and toolbars can be updated.
                                        2. Improved UI slider performance when simulation is active.
                                        3. Added a feature to split edges. Now in addition to Weld Edges option there is a Split Edges option, allowing you to assign maximum spacing.
                                        • alsomarA Offline
                                          alsomar Extension Creator
                                          I really love this extension. Thank you so much Anton! πŸ˜„
                                          Here's my last test using ClothWorks and Thea Render. The statue I've used is "Le Transi de Rene de Chalon" from Three D Scans
                                          https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_skp.jpg
                                          https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_thea.png
                                          Alejandro Soriano Visuals Β· All my links
                                          • BoxB Offline
                                            Somewhat reminiscent of Priscilla queen of the desert......
                                            • 35
                                            • 36
                                            • 6 / 36
