    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    712 Posts 165 Posters 811.3k Views 165 Watching
    • jujuJ Offline
      juju
      @solo said:
      I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails.
      I saw that "Rope Fall" is also subscription these days, very inspiring...
      • boofredlayB Offline
        boofredlay
        @solo said:
        I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
        Yep.
        Draw a line, divide it and drape.
        Before
        After
        • soloS Offline
          @boofredlay said:
          Yep.
          Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
          • BoxB Offline
            Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
            • jujuJ Offline
              juju
              Have you tried welding the complex line?
              • soloS Offline
                bezier spline worked like a charm.
                Too bad there is no plugin that can divide a welded line into equal segments.
                • BoxB Offline
                  Both will, particularly Fredo Tools, Divide Edges.
                  Unless I'm not understanding what you want. But after 4am need sleep now.
                  • dereiD Offline
                    derei
                    @Box
                    @box said:
                    Ooops, I think I made my cargo net just a bit too flexible!
                    I didn't really understand all controls for Cloth, how do you control the elasticity of a material without making the cloth stiffer?
                    For example, in your case, for the ball to not slip through the holes in the net, but the net to fall naturally?
                    DESIGNER AND ARTIST DEREI.UK
                    • jo-keJ Offline
                      jo-ke
                      that's it. Thank you
                      http://www.zz7.de
                      • HornOxxH Offline
                        HornOxx
                        ... with ClothWorks you can catch a lot of animals - but not a fish - a bug? πŸ˜„ πŸ˜„ πŸ˜„
                        never trust a skinny cook
                          smashor
                          @dave r said:
                          This is with one of the SUC fabrics.
                          [attachment=1:2ig71rmb]<!-- ia1 -->AC desk plaid cu.png<!-- ia1 -->[/attachment:2ig71rmb]
                          [attachment=0:2ig71rmb]<!-- ia0 -->AC desk plaid.png<!-- ia0 -->[/attachment:2ig71rmb]
                          How did you do those wrinkles? Looks very cool!
                            Anton_S
                            Haven't checked but fish can be one of Known Limits and Limitations. And of course, I'm going to improve contact generation in a major release, which could fix the issue. We'll see.
                              Anton_S
                              I may have to add this as a workflow feature. Should be very simple.
                                Anton_S
                                @jo-ke said:
                                I have problems with textures. what did I wrong?
                                @box said:
                                Make sure the texture is applied to the faces not the group.
                                In addition to Box's response, to apply a texture to a simulated cloth, follow the step below:
                                1. Select the simulated cloth
                                2. Click on the undrape icon. This should reset the layout of the cloth
                                3. Enter the context of the cloth
                                4. Apply a desired texture directly to the front and/or back faces
                                5. Exit the context of the cloth
                                6. Click on the toggle draped icon again to renew the layout of the cloth
                                Here is the part of the Draping Sphere video performing these steps (starts at 1:25):
                                https://youtu.be/u-DZ17Nls9k?t=1m25s
                                  Anton_S
                                  @boofredlay said:
                                  Yep.
                                  And if you apply Loop Subdivision to the simulated edges group, the edges would subdivide just like cloth.
                                  • I Offline
                                    imabzeous
                                    I tried to buy the plugin but unfortunately i can only buy it via paypal which isn't supported in my country. only master cards visa cards works. so if author or sketchucation admins can help me out?
                                    • FrederikF Offline
                                      Frederik
                                      @pixero said:
                                      Doesn't Bezier spline Polyline divider for Animation do what you want?
                                      Perhaps you should read all posts before posting a reply...
                                      Cheers
                                      Kim Frederik
                                      • PixeroP Offline
                                        Pixero
                                        @solo said:
                                        [Too bad there is no plugin that can divide a welded line into equal segments.
                                        Draw any curve or use the Freehand tool or weld lines. Right click. Convert to Polyline divider for animation and set max length.
                                        (That was once made on my request when I was making advanced animation paths in SketchUp.)
                                        Sometimes, if the curve doesn't fit with the Max length, there can be one edge with different length at the end.
                                        • BoxB Offline
                                          Actually Frederik, Pixero was answering the question/statement that Solo made after he said it worked like a charm.
                                          • BoxB Offline
                                            Here's a bit of a summer print skirt made by dropping a cloth with a hole in it over a rudimentary waist. A sphere with a pulled top and scaled to an oval.
                                            • 35
                                            • 36
                                            • 6 / 36
