    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    712 Posts 165 Posters 809.0k Views 165 Watching
      alpro
      Looks awesome.....off to get it now
        Anton_S
        Here is a higher resolution simulation of an American Flag.
        A roughly 100cm X 170cm rectangle was drawn for the flag and applied a grid with spacing of 4cm.
        The pole was assigned a collider state. Pins were attached at upper and lower right corners of the flag.
        Using ClothWorks UI, flag thickness was increased to 20mm to prevent self-overlaps.
        After simulation, I applied loop subdivision and followed with 2 Laplacian smoothing iteration to eliminate rounded corners formed by loop subdivision.
        A texture was assigned at the end, utilizing the Toggle Draped option.
        UnitedStatesFlag.skp
          More play
            Beautiful drapé! 😎
              alpro
              Just purchased....great plugin
                This is with one of the SUC fabrics.
                • l_breaultL Offline
                  l_breault
                  Looking forward to trying this out! Too much work going on for awhile is going to put a damper on this. Where's the examples of comforters?
                  Thanks,
                  Leo Breault
                  http://www.breaultdesignstudio.com
                  • soloS Offline
                    I hear ya, I too bought this but too much work right now to play, I have been anticipating this for a while.
                    • ArcA Offline
                      Arc
                      Is this license a permanent license? How many computers with one license support?
                      • HornOxxH Offline
                        HornOxx
                        @rich o brien said:
                        Use Extensions > ClothWorks > License...
                        Thanks Rich and Fredo - I didn´t had installed SketchUcation Tools so this required window for licensing was not available - Well, now I got it 😄
                        never trust a skinny cook
                        • PixeroP Offline
                          Pixero
                          It's 3 computers.
                            Anton_S
                            @pixero said:
                            Possible BUG: In the Time step drop down there are two 1/840.
                            Yes, that's just a typo in the dialog. When you use the second 1/840 option, the actual timestep set is 1/960. Already fixed and will be updated in next release.
                            @pixero said:
                            It's 3 computers.
                            Additionally, the way SCFLicense works is that if you release (deactivate) a licence you can use the licence on another device or reactivate it on the same device. So, there is no limit to the number of times the licence can be activated/deactivated, as long as it is on up to 3 devices.
                            • Bob JamesB Offline
                              Bob James
                              Sold ❗
                                marvsweden
                                Purchased. It's going to be exciting using it.
                                I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
                                  Anton_S
                                  Thanks for an important report! I will fix this by as soon as tomorrow (if possible).
                                    marvsweden
                                    Sure, no problem. Looking forward to using it.
                                    • PepetrucciP Offline
                                      Pepetrucci
                                      Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
                                      Thanks so much for making sketchup even more fun!
                                      Here my first attempt with clothworks, the export frames option is veeery cool!
                                      https://media.giphy.com/media/d5E1Lofnq4ZUTr79Gp/giphy.gif
                                      • jujuJ Offline
                                        juju
                                        I know this is OT, but don't forget SKALP!
                                          Pepetrucci
                                          Of course of course! So many great plugins out there 😆
                                            kenancakir
                                            It took about a minute to calculate because of the hedgehog model, but works..
                                            • 35
                                            • 36
                                            • 3 / 36
