    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.3k Views 170 Watching
    • boofredlayB
      boofredlay
      Yep
      Click image to see gif.
        alpro
        Looks awesome.....off to get it now
          Anton_S
          Here is a higher resolution simulation of an American Flag.
          A roughly 100cm X 170cm rectangle was drawn for the flag and applied a grid with spacing of 4cm.
          The pole was assigned a collider state. Pins were attached at upper and lower right corners of the flag.
          Using ClothWorks UI, flag thickness was increased to 20mm to prevent self-overlaps.
          After simulation, I applied loop subdivision and followed with 2 Laplacian smoothing iteration to eliminate rounded corners formed by loop subdivision.
          A texture was assigned at the end, utilizing the Toggle Draped option.
          UnitedStatesFlag.skp
            More play
              Beautiful drapé! 😎
                alpro
                Just purchased....great plugin
                  This is with one of the SUC fabrics.
                  • l_breaultL
                    l_breault
                    Looking forward to trying this out! Too much work going on for awhile is going to put a damper on this. Where's the examples of comforters?
                    Thanks,
                    Leo Breault
                    http://www.breaultdesignstudio.com
                    • soloS
                      I hear ya, I too bought this but too much work right now to play, I have been anticipating this for a while.
                      • ArcA
                        Arc
                        Is this license a permanent license? How many computers with one license support?
                        • HornOxxH
                          HornOxx
                          @rich o brien said:
                          Use Extensions > ClothWorks > License...
                          Thanks Rich and Fredo - I didn´t had installed SketchUcation Tools so this required window for licensing was not available - Well, now I got it 😄
                          never trust a skinny cook
                          • PixeroP
                            Pixero
                            It's 3 computers.
                              Anton_S
                              @pixero said:
                              Possible BUG: In the Time step drop down there are two 1/840.
                              Yes, that's just a typo in the dialog. When you use the second 1/840 option, the actual timestep set is 1/960. Already fixed and will be updated in next release.
                              @pixero said:
                              It's 3 computers.
                              Additionally, the way SCFLicense works is that if you release (deactivate) a licence you can use the licence on another device or reactivate it on the same device. So, there is no limit to the number of times the licence can be activated/deactivated, as long as it is on up to 3 devices.
                              • Bob JamesB
                                Bob James
                                Sold ❗
                                  marvsweden
                                  Purchased. It's going to be exciting using it.
                                  I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
                                    Anton_S
                                    Thanks for an important report! I will fix this by as soon as tomorrow (if possible).
                                      marvsweden
                                      Sure, no problem. Looking forward to using it.
                                      • PepetrucciP
                                        Pepetrucci
                                        Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
                                        Thanks so much for making sketchup even more fun!
                                        Here my first attempt with clothworks, the export frames option is veeery cool!
                                        https://media.giphy.com/media/d5E1Lofnq4ZUTr79Gp/giphy.gif
                                        • jujuJ
                                          juju
                                          I know this is OT, but don't forget SKALP!
                                          • PepetrucciP
                                            Pepetrucci
                                            Of course of course! So many great plugins out there 😆
                                            • 36
                                            • 37
                                            • 3 / 37
