    3D Truss Models
    1.5k Posts 31 Posters 976.6k Views 30 Watching
      dpaul
      Excellent. Been waiting for this......... 👍
      • facerF Offline
        facer
        Save parameters of truss type for later use (modification)
        Ideally one could save the parameters for a truss type and then
        install in future for another project with similar or slight variations.
        Hence a library of truss types and associated detailscould be
        created by the user for repeative projects.
        This would be ideal for builders constructing repeative building types
        with sight variations.
        • medeekM Offline
          medeek
          I like the idea of saved config files or templates, I will give this some more thought.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • medeekM Offline
            medeek
            Making some good progress on the "edit" function. I will initially start with the common trusses and then once I am satisfied that those trusses are running stable I will begin to make this feature available for all other truss, rafter and floor assemblies.
            I'm a little bogged down with the advanced options (there are too many) but it is just a matter of putting in the time and slogging through all of the data entry and HTML and javascript. Probably by the end of the week I should have something ready to go and I will roll a release so everyone can begin testing it.
            design.medeek.com
            • medeekM Offline
              medeek
              Has anyone had much experience with SIP walls? I've been looking at the product offering of Eco Panel:
              Eco-Panels - Strong and Efficient Building Panels | Homepage
              Building a new home? Eco-Panels offers modular building panels that are stronger & safer than stud frame construction for about the same price.
              Eco-Panels (www.eco-panels.com)
              and I am fairly curious about this product.
              design.medeek.com
                KrisM
                I'm quite familiar with SIPs. They definitely have their pluses and minuses. They certainly aren't cheap but can be quite effective if installed properly. The key here is that contrary to the suggestion from Eco Panels that low priced labour can erect their product, there better be someone on site who really knows what they are doing. I have seen some bad installs (not Eco Panel's products) and the long term implications are quite serious. While I have been a promoter of SIPs in the past, I think there are easier and cheaper ways to get good R values.
                • medeekM Offline
                  medeek
                  Version 2.1.6 - 03.02.2018
                  • Added Soffit Cut within Advanced Options for Hip Rafter Roofs.
                  http://design.medeek.com/resources/images/truss_su348_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.1.6b - 03.02.2018
                    • Added Soffit Cut within Advanced Options for all Shed type Rafter Roofs.
                    • Added gutters for all Shed type Rafter Roofs.
                    http://design.medeek.com/resources/images/truss_su349_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      The edit feature is slowly coming to fruition. I've added so many advanced options to the common truss type that it is quite an ordeal to even put together the HTML form that fully encompasses all of this information and does it in an organized and neat manner. There is a possibility of 72 unique (user entered) parameters for a common truss assembly. Some of these are dependent on others, its an interesting web of dependencies (spaghetti) that must be taken into account for the edit feature to work properly. I've probably got another week just in debugging before I am ready to release the first version of this feature.
                      design.medeek.com
                      • pbacotP Offline
                        Models look high quality. I hope you have ability for multiple Presets so that a type of roof that users use all the time can be saved.
                        • medeekM Offline
                          medeek
                          A number of presets can be set by the user in the global settings however I have not fully implemented a "store" function that will take an entire roof configuration and store it as a preset roof assembly. This may be another feature that I add.
                          design.medeek.com
                          • facerF Offline
                            facer
                            Medeek,
                            ..."take an entire roof configuration and store it as a preset roof assembly."
                            I think this will be very popular, looking forward to this function! 👍
                            • medeekM Offline
                              medeek
                              Version 2.1.7 - 03.06.2018
                              • Enabled the "Edit Truss Assembly" function for all common roof trusses (imperial units only).
                              To edit a roof truss assembly just right click on the assembly and select the "Edit Truss Assembly" option.
                              Note, that this function is only available for common trusses with imperial units (template). Metric will be next.
                              It seems to be working fairly robustly but I'm sure there will be some minor bugs that pop up considering the complexity of the code and the sheer numbers of variables that I am working with.
                              Please report any errors by using the ruby console to record the error and email it to me.
                              Once this feature has been out for a while and I know it is running fairly stable I will then work on updating all rafter and truss assemblies so that the user can edit them. I can already see that this will be a very useful upgrade to the plugin.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Realize that the entire roof assembly is being redrawn from scratch so any manual customization will disappear. It is actually quite a bit faster than I thought it might be so I’m fairly happy with that.
                                I did notice that when you initially create a truss assembly without any advanced options and then enable advanced options in the edit panel it does not auto populate the various advanced option fields, I think this could use some attention.
                                Below is a screenshot of the edit panel:
                                http://design.medeek.com/resources/images/truss_su350_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.1.7b - 03.10.2018
                                  • Enabled the "Edit Truss Assembly" function for all common roof trusses (metric units).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 7, Edit Function and some changes to the global settings:
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.1.7c - 03.11.2018
                                      • Added ceiling gypsum and ceiling battens to cathedral trusses.
                                      http://design.medeek.com/resources/images/truss_su351_800.jpg
                                      http://design.medeek.com/resources/images/truss_su352_800.jpg
                                      View model here:
                                      3D Warehouse
                                      (3dwarehouse.sketchup.com)
                                      design.medeek.com
                                      • jujuJ Offline
                                        juju
                                        Not on your home website yet?
                                        • medeekM Offline
                                          medeek
                                          Should be up now.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I've been giving some thought to framed openings in floors, see image below:
                                            http://design.medeek.com/resources/images/truss_su353_800.jpg
                                            Generally, at least from what I've seen most holes in floors are either rectangular, L-shaped or U-shaped, but I guess any outline is possible.
                                            What I've shown in the image above is LSL or LVL framing out the opening however the actual framing might be significantly different depending on what is supporting the floor below.
                                            In some cases the rectangular opening might not be supported by bearing walls from below, in that case the two LSL boards running parallel to the joists would probably be larger beams and the headers would be hangered from these beams and would also probably be more substantial.
                                            The point is how to make this feature flexible enough to accommodate most framed openings but at the same time keeping it as simple as possible so the user is not overwhelmed with parameters.
                                            View model here:
                                            3D Warehouse
                                            Any ideas would be greatly appreciated.
                                            P.S. I am also going to make this feature editable so that the actual hole can be altered after the fact. This should be an interesting programming challenge.
                                            design.medeek.com
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 75
                                            • 76
                                            • 46 / 76
