    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Version 2.1.6 - 03.02.2018
      • Added Soffit Cut within Advanced Options for Hip Rafter Roofs.
      http://design.medeek.com/resources/images/truss_su348_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.1.6b - 03.02.2018
        • Added Soffit Cut within Advanced Options for all Shed type Rafter Roofs.
        • Added gutters for all Shed type Rafter Roofs.
        http://design.medeek.com/resources/images/truss_su349_800.jpg
        design.medeek.com
        • medeekM
          medeek
          The edit feature is slowly coming to fruition. I've added so many advanced options to the common truss type that it is quite an ordeal to even put together the HTML form that fully encompasses all of this information and does it in an organized and neat manner. There is a possibility of 72 unique (user entered) parameters for a common truss assembly. Some of these are dependent on others, its an interesting web of dependencies (spaghetti) that must be taken into account for the edit feature to work properly. I've probably got another week just in debugging before I am ready to release the first version of this feature.
          design.medeek.com
          • pbacotP
            Models look high quality. I hope you have ability for multiple Presets so that a type of roof that users use all the time can be saved.
            • medeekM
              medeek
              A number of presets can be set by the user in the global settings however I have not fully implemented a "store" function that will take an entire roof configuration and store it as a preset roof assembly. This may be another feature that I add.
              design.medeek.com
              • facerF
                facer
                Medeek,
                ..."take an entire roof configuration and store it as a preset roof assembly."
                I think this will be very popular, looking forward to this function! ๐Ÿ‘
                • medeekM
                  medeek
                  Version 2.1.7 - 03.06.2018
                  • Enabled the "Edit Truss Assembly" function for all common roof trusses (imperial units only).
                  To edit a roof truss assembly just right click on the assembly and select the "Edit Truss Assembly" option.
                  Note, that this function is only available for common trusses with imperial units (template). Metric will be next.
                  It seems to be working fairly robustly but I'm sure there will be some minor bugs that pop up considering the complexity of the code and the sheer numbers of variables that I am working with.
                  Please report any errors by using the ruby console to record the error and email it to me.
                  Once this feature has been out for a while and I know it is running fairly stable I will then work on updating all rafter and truss assemblies so that the user can edit them. I can already see that this will be a very useful upgrade to the plugin.
                  design.medeek.com
                  • medeekM
                    medeek
                    Realize that the entire roof assembly is being redrawn from scratch so any manual customization will disappear. It is actually quite a bit faster than I thought it might be so Iโ€™m fairly happy with that.
                    I did notice that when you initially create a truss assembly without any advanced options and then enable advanced options in the edit panel it does not auto populate the various advanced option fields, I think this could use some attention.
                    Below is a screenshot of the edit panel:
                    http://design.medeek.com/resources/images/truss_su350_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.1.7b - 03.10.2018
                      • Enabled the "Edit Truss Assembly" function for all common roof trusses (metric units).
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 7, Edit Function and some changes to the global settings:
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.1.7c - 03.11.2018
                          • Added ceiling gypsum and ceiling battens to cathedral trusses.
                          http://design.medeek.com/resources/images/truss_su351_800.jpg
                          http://design.medeek.com/resources/images/truss_su352_800.jpg
                          View model here:
                          3D Warehouse
                          (3dwarehouse.sketchup.com)
                          design.medeek.com
                          • jujuJ
                            juju
                            Not on your home website yet?
                            • medeekM
                              medeek
                              Should be up now.
                              design.medeek.com
                              • medeekM
                                medeek
                                I've been giving some thought to framed openings in floors, see image below:
                                http://design.medeek.com/resources/images/truss_su353_800.jpg
                                Generally, at least from what I've seen most holes in floors are either rectangular, L-shaped or U-shaped, but I guess any outline is possible.
                                What I've shown in the image above is LSL or LVL framing out the opening however the actual framing might be significantly different depending on what is supporting the floor below.
                                In some cases the rectangular opening might not be supported by bearing walls from below, in that case the two LSL boards running parallel to the joists would probably be larger beams and the headers would be hangered from these beams and would also probably be more substantial.
                                The point is how to make this feature flexible enough to accommodate most framed openings but at the same time keeping it as simple as possible so the user is not overwhelmed with parameters.
                                View model here:
                                3D Warehouse
                                Any ideas would be greatly appreciated.
                                P.S. I am also going to make this feature editable so that the actual hole can be altered after the fact. This should be an interesting programming challenge.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Alternatively that same opening could be framed as below:
                                  For the size of the opening one would probably use some PSL Beams rather than a couple of I-Joists but the concept is the same, compare with the previous example where the opening would probably be supported from below by bearing walls.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Here is an example of a L-shaped opening in a floor to allow for a stairway.
                                    https://cdn.instructables.com/FXK/LIS1/ITXTNPWV/FXKLIS1ITXTNPWV.LARGE.jpg
                                    Probably not the best example but I think it helps get the idea across.
                                    Note the bearing walls supporting perimeter of the opening.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.1.7d - 03.14.2017
                                      • Addresses a minor bug with the UI menu for common trusses. The overhang of the truss could be rounded to an integer value upon recreation of another truss set.
                                      I wonder why no one else has noticed the overhang rounding issue. I just realized it is an artifact from when I had it setup to use a integer value for the overhang, which I eventually changed but I must have forgot to update the rounding function (or remove it) so that non integer values could be input.
                                      It appears this bug only affected common trusses but I will need to go through and check each truss type to make sure the same issue was not replicated elsewhere.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I am trying to get my hands on some shop drawings for a dutch gable truss set. I would like to work on adding this truss set into the plugin this weekend if possible.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Two different ways to truss out a dutch gable roof:
                                          http://design.medeek.com/resources/images/truss_su354_800.jpg
                                          http://design.medeek.com/resources/images/truss_su355_800.jpg
                                          The first method involves a wailing plate attached to the side of the girder truss. This appears to be the preferred method of construction in Australia.
                                          The second method employs vertical studs on the gable end portion (upper half) of the girder truss. What is not entirely clear to me is how the joint comes together at the top chord where the horizontal member (at the top of the jacks) meets the vertical and diagonal web of the girder truss.
                                          I could really use a shop drawing (2D) of this particular configuration.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.1.8 - 03.18.2018
                                            • Enabled the "Edit Floor Assembly" function for all I-Joist floors (imperial and metric units): TJI, BCI, LPI, Red-I, PKI.
                                            http://design.medeek.com/resources/images/truss_su356_800.jpg
                                            Now I just need to get the floor framed opening feature working and then this module might actually be useful.
                                            Realize that any manual edits made to the floor assembly are blown away when you use the edit function. It is essentially re-drawing the entire floor assembly, the same goes for the roof truss assembly edit feature.
                                            design.medeek.com
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 76
                                            • 77
                                            • 54 / 77
