    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.3k Views 92 Watching
      Thank you for the detailed explanation. Btw, any change you can provide a couple of screenshot of what type of mesh you work with? And some example of what desired result would be? (Helps me when filing features - as weeks down the line visual reminders helps a lot.)
      As got 2D scale - yes! Absolutely. I have that working in the dev build of V2 already. πŸ˜„
      Regarding your last question. You experience that vertices get selected with you do a quick-move?
      • O Offline
        optimaforever
        Here's an example of terrain mesh I made with VT and QFT.
        mesh example
        Here's the default align to world axis gizmo behaviour.
        by default align to word axis gizmo
        Here's how I would like the gizmo to behave.
        what it could be when 2 vertices are selected (red axis aligned to the 2 vertices and the green axis along an adjacent plane
        And for the last question, yes, sometimes in the move mode, some vertices end selected after moving.
        It happens when I select a vertice (after the white circle to be visible), move it and then move it again but this time without the white circle to be visible. the vertice remains red (selected) and I need to go to the select mode to deselect all to get rid of the selection. The simplest way to resolve the issue could be to be able to deselect all vertices by clicking in the empty space just like all tools in Sketchup.
          Thank you for posting these follow ups. Visuals like that helps me greatly to put it into context.
          • O Offline
            optimaforever
            you're welcome;
            it's the least I can do for my favourite dev πŸ˜„
              That's mighty kind of you to say. πŸ˜„
              I've logged both the feature request for the gizmo alignment and the quick-select issue.
              • E Offline
                Emily75
                Hello, I've just bought Vertex Tools. Everything seems to work fine, i'm on Sketchup PRO 2018 on Mac OSX, except one point :
                I'm unable to precisely control the distance or proportion using the vertex Gizmo. I can't access to the VCB to control that. (actually I just can control the soft selection radius).
                How can I do ? Thanks
                • O Offline
                  optimaforever
                  So far I don't think you can do it that way.
                  With Select Mode and the gizmo you can move freely some vertices but it can be precise if you use Sketchup's own length snapping (1mm, 1cm, 1m and so on; just choose a value that is pertinent in your model).
                  With Move mode, choose a vertex, a direction (vector),and type the desired length in the VCB.
                    There appear to have been a regression in V1.2. I have it logged. But no fix as of yet.
                    • O Offline
                      optimaforever
                      Thomas, you mean it was possible earlier?
                        You know what, I'm a little unsure to be honest. I might be confusing it with the non-gizmo Move tool...
                        • HieruH Offline
                          Hieru
                          I'm fairly certain it was a feature a while back, but was then lost in an update.
                          I've mentioned it before and seem to recall you saying that it was on your to-do list for Version 2, but I could be wrong.
                          www.davidhier.co.uk
                            Yea - that sounds familiar. The work on SUbD made me forget some of the details of existing Vertex Tools issues. Seeing how VT2 is taking longer to complete, I may have to do a bug patch to v1.2.
                            • N Offline
                              numerobis
                              As i said earlier i would prefer a simple edge constraint toggle like in max instead of having to align the gizmo first every time i want to move a vertex along an edge...
                                MichaelSiggers
                                Hi @thomthom
                                This is a genius plugin!
                                Purchased a couple of days ago and I love it.
                                Only thing is, I second the comment about being able to type in a distance when moving a selection with the Gizmo.
                                Brilliant work though. Thankyou.
                                Kind regards
                                Mike
                                  Version 1.2.11
                                  Improvements
                                  • Added Serbian translations.
                                  • Added Albanian translations.
                                  • Updated Spanish translations.
                                  Fixes
                                  • Fixed Gizmo VCB adjustments not working.
                                    MichaelSiggers
                                    Thank you Thomas πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                                    Mike
                                    • O Offline
                                      optimaforever
                                      Great!
                                      To be sure:
                                      1. select vertices
                                      2. use VT's select mode (gizmo) and begin moving the vertices along red, green or blue axis.
                                      3. WHILE keeping left mouse button down, type desired value in VCB. type enter.
                                      4. the vertices gets moved along axis
                                      5. RELEASE left mouse button.
                                      Once you release the LMB, VCB awaits for soft select radius value, so it doesn't work like the move tool of Sketchup, where you can change your mind afterwards and tweak the move value.
                                      Is it correct?
                                      PS I realized that this behaviour works also for scale and rotate. Type value in VCB while keeping LMB pressed down. Once you press enter, the vertices gets modified according to the value.
                                      It's just tricky for cases where I need to press Shift with my left hand while keeping the LMB pressed down. I noticed that you can release Shift after you began the scale movement and type a value in the VCB but you can't move the mouse otherwise the Shift indication gets lost.
                                        With 1.2.11 you should be able to adjust after releasing LMB.
                                        • O Offline
                                          optimaforever
                                          Thanks Thomas.
                                          It works indeed as you said.
                                          However I think I have a problem with the latest VT as it hangs SU at launch.
                                          And second, when I try to Ctrl+move an edge AND type a value in the VCB afterwards, it bugs.
                                          • Bob JamesB Offline
                                            Bob James
                                            Should I assume that "Make Planar to a custom plane" won't happen until V2?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
