    [Plugin] CenterPointAll.rb
    34 Posts 18 Posters 47.4k Views 18 Watching
    • JClementsJ
      JClements
      When I have time, I often draw over "apparent" arcs and circles because I can then use Entity Info to verify radii of piping and to facilitate the extrusion of smoothed-surfaces and improve exporting .SKP's to other formats.
      I think the bottom line is you'd need a basic script (using the model context or selection) to find series of contiguous segments, then analyze them to determine if they have the characteristics of an arc.
      For instance: are all segments of equal length and are all of their common angles equal (there may be more conditions that I haven't thought of)? If all segments touch one another, then are they a polygon or a circle?
      If such a script can be developed, then it could be used as a common routine called by other scripts such as pipe-along-path or used on intersected geometry. Once the script qualifies the segments, it could then automatically redraw them, make centerpoint guides, etc.
      • david_hD
        david_h
        Yeah. . .what he just said. .. uh Huh. I think
        Anyway. .. I just want to find the Radius point of any curve be it arc or no. anything else, above that . . ..Gravy.
        • plot-parisP
          plot-paris
          JClements, that would be a damn handy tool and a wonderful addition to the weld-script...
          • W
            watkins
            Dear David_H
            You can use the protractor to find the centre of an arc or circle. Snap the tool to the mid-point of a segment and then click on the end of that segment (you have a choice of two points). Rotate the protractor 90 degrees to create a construction line along the segment's normal (located at mid-point). Repeat for a second segment. The centre point is marked by the crossing of the construction lines.
            A ruby script might work in the same way.
            Activate the tool, and moving either clockwise or anticlockwise (but not both):
            Click first end point, segment 1
            Click second end point, segment 1
            Click third end point, segment 2
            Click fourth end point of segment 2
            Ruby computes equations of normals at mid-points of segments 1 and 2
            Ruby computes coincident point to yield x,y,z value of centre point
            Variations:
            Segments 1 and 2 are start and end segments of arc = redraw arc (input = number of segments)
            Segments 1 and 2 are connected = redraw circle (input = number of segments)
            I am not a script writer, but the above would seem do-able.
            • david_hD
              david_h
              Watkins. Yeah, I had been doing that. I was just hoping for a one-click solution. Cuz I ain't no Ruby Writer Neither. . .sigh! 😒 But thanks for the input.
                Jim
                Dave,
                You might have more luck if you start a new request thread in the Ruby forum.
                  rosbourne
                  Thanks.. Now more easier to make center point
                    ship69
                    Does this video have sound? It's coming out silent on my PC.
                      No. It's a silent video.
                      • E
                        Einstein
                        Thanks TIG 😄
                        This simple tool helps me rotating components around their centerpoints which is quite complicated in SU.
                        It would be even more handy if a created centerpoint was interactive, I mean: changed with scaling and moving component or group it's based on. But I realise that would be also much more complicated code.
                        • BoxB
                          To rotate about the midpoint of a group or component, use the rotation handles that appear when you use the Move tool.
                            sarkarshomit
                            Can't get it working in sketchup 2018.working fine in skup16, but not in 18...any help if i am doing something wrong!!
                              Evidently you are doing something wrong. I just installed it in SU2018 and ran it. It works fine. How did you install it? Where did you install it? Do you have Guides set to show in the View menu?
                              Result of CenterPointAll
                                sarkarshomit
                                [attachment=0:9qktjmkx]<!-- ia0 -->Screenshot - 5_16_2018 , 5_31_16 AM.png<!-- ia0 -->[/attachment:9qktjmkx]
                                Thanks for the help.
                                Strangely in skup16, the plugin shows up in plugins menu named as "set centerpoint".
                                And in skup18 it shows up in extensions menu as "Add centerpoint".
                                So finally its working for me. Thanks again.
                                • BoxB
                                  Sounds like you may have had a different extension installed in 2016. There is one called Set Centerpoint.
                                  Tig's shows for me in 2016 as Add Centerpoint.
                                    Rastus
                                    Hate to appear thick but I can't install CenterPointAll in 2018 (vs 8.0.1...). Where do I need to place the plugin?
                                    Thanks!!
                                      Look here
                                      https://sketchucation.com/pluginstore?pln=CenterPointAll
                                      which gives you an RBZ which can be installed in v2018 using Window > Extension Manager > Install... [red-button]
                                      No need to find the Plugins folder etc...
                                      Almost all Plugins which include an old RB file in their thread will have an entry in the PluginStore, giving an easily installed RBZ for use in all current versions of SketchUp...
                                      Even the now often unsupported v8 had these RBZ capabilities in later MRs,,,
                                        Rastus
                                        Been a while since I've used Sketchup. You made an invaluable plugin!
                                        • kachuppK
                                          kachupp
                                          For those who dislike using the plugin (Extensions) menu I've modified TIGs version to use
                                          the context menu. I find it much faster than moving the mouse all the way too
                                          the top menu bar click and click.
                                          pick, right click, click "Point at Center" done.
                                          UI.add_context_menu_handler {|menu|
                                          	menu.add_item("Point at Center") {
                                            	model=Sketchup.active_model
                                            	entities=model.active_entities
                                            	selection=model.selection
                                            	model.start_operation("Add Centerpoint")
                                            	selection.to_a.each{|e|entities.add_cpoint(e.bounds.center)}
                                            	model.commit_operation
                                            Michalis Barmpavasiloglou
                                            Hallo, wie bekomme ich dies Plugin in das Scetchup Programm instaliert. Herunter geladen habe ich es schon aber ich sehe es nicht bei den Plugins nicht...ich würde mich echt freuen, wenn mir jemand helfen könnte.
                                            Beste Grüße MB
                                            • 2 / 2
