    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 323.0k Views 57 Watching
    • LucideL Offline
      Lucide
      And here he is, Fredo6 😎
      Lightning fast, with a new amazing update for one of the most used sketchup plugin in the entire community!
      By the way, thank you
      Lucide
        littleche
        Hi Fredo
        Thanks for your principal And Amazing Plugins .
        I have problem with smooth contours option in Curvizard . its not excluded sharp corner from smoothing .it means "smooth by section " and "Smooth Collinear Edges " not working for me. please see video on link if I could not Explain it . thanks .
        https://www.mediafire.com/file/a8v93r6yrc43gx0/Curvizard.mp4
          littleche
          Hi again
          No answer for me ?
          • fredo6F Offline
            @littleeche
            Sorry for late answer. I missed your posted.
            I think you need to put co-linear vertices on each side of the corner.
            Anyway, That would help that you post the skp fil;e, so that I have a closer look.
              littleche
              Hi Again fredo and thanks for your Answer.
              I uplode sample file . please look at it . in this file I showed points with A and B .
              I would like to action fo "smooth contours " work On A point and Donot Work On B Points .
              thanks from you in advance
              Curvizard problem.skp
              • fredo6F Offline
                Not sure I got the issue you have. So, please have a look at the attached video and tell me.
                Curvizard partial smooth.mov
                  littleche
                  Thanks for your video fredo . but your video is not my issue .
                  please select all edges and run "smooth contours " . Certainly i can select only A Points Too but My issue is "smooth by section" in "smooth contours "tool Does not work .
                  • fredo6F Offline
                    [attachment=0:29goc5iu]<!-- ia0 -->233.png<!-- ia0 -->[/attachment:29goc5iu]
                    That's why I was saying.
                    To prevent a corner to smooth, you need to put 2 collinear vertices on each side (i.e. vertices in the middle of each segment). Otherwise there is no way that Curvizard knows you don't want to smooth them.
                      littleche
                      Ok ! its solved With Your hint to "put 2 collinear vertices on each side " .
                      Thank You Fredo . Your plugins is excellent .
                        Ahmed0007
                        Watch This!
                        https://www.youtube.com/watch?v=1OV_YF6jsQA
                        • fredo6F Offline
                          @ahmed0007 said:
                          Watch This!
                          Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
                          In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
                            CassieFlo
                            I've downloaded this plugin using the SCF Plugin Store (and restarted Sketchup right after) and have LibFredo6 8.1. However I keep getting a message that pops up saying that I have to install LibFredo6 v6.9 or higher to run curvizard...any thoughts on what is going on or how I can get this plugin working?
                            Thanks in advance!
                            Cassie
                              Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
                              and you have restarted SketchUp completely...
                              Then that error is indeed strange.
                              You profile says: you have a MAC using SketchUp Pro - pre-v6 !
                              Can you correct it and advise us on your current configuration...
                              Help us to help you...
                                CassieFlo
                                I have indeed installed both latest versions and restarted SU completely multiple times.
                                And oops! I am not sure why that was listed as such, I am using SU 2018.
                                • fredo6F Offline
                                  Cassie,
                                  I just published an update to Curvizard (v2.1a), as I realized the published version was quite old (2015).
                                  Can you tell me if you still get an error.
                                  • fredo6F Offline
                                    NEW RELEASE: Curvizard v2.1a - 28 Mar 18
                                    Curvizard 2.1a is a maintenance release to keep the plugin on par with latest LibFredo6 versions. So upgrade is strongly suggested[/b][/color][/size].
                                    Requirement: LibFredo6 8.1 or above
                                    See main post of this thread for Download of Curvizard.
                                      CassieFlo
                                      Fredo-
                                      Yes! That worked, thank you so much!
                                        bambutec
                                        Hi Fredo,
                                        actually ´m using your palette tools a lot. Not the Curvizard yet, but wonder if it would be possible to draw a real spatial contour.
                                        The tutorial did not refer on a spatial type of editing the vertices.
                                        My desire is related to an intuitive process creating contour lines of a hull, which is not yet defined , means from scratch.
                                        The strategy follows many times to find a resulting spatial contour from two related planar contours.
                                        Do you have an idea in terms of Plugin for this ?
                                        Thank you for your work its really great .
                                        Uli
                                        • BoxB Offline
                                          Hi Fredo I'm getting a repeatable error when using Curvizard Convert Edges to Guides.
                                          It happens with any edge, even a single straight line.
                                          This is with 2018 pro all plugins up to date, Libfredo6 8.4g
                                          It works correctly in 2017.
                                          I've attached the error text.
                                          Ruby Error - Curvizard#convert_to_guide - 04-Jul-18 00_03_59.txt
                                          • fredo6F Offline
                                            NEW RELEASE: Curvizard v2.1c - 03 Jul 18
                                            Curvizard 2.1c is a maintenance release fixing a small bug signaled by Box.
                                            • 8 / 10
