    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 375.1k Views 57 Watching
      Penelope
      Please ignore my post of a few minutes ago. I finally got this plugin to work by restarting SU another time!
      • LucideL Offline
        Lucide
        Thanks Fredo for all your hard work.
        I want to ask you about a problem that i have with Curvizard 2.0a on sketchup 2016.
        Both Curvizard and Libfredo are updated. (i checked with the sketchucation store v3 and with your tool)
        Every time i clic on any button, sketchup acts as i clicked on "undo" (like ctrl+z).
        This hissue happens only on Curvizard, but with almost any button.
        Do you know what could be the problem? 😮
        Thanks,
        Lucide.
        ps. i don't speak english very fluently 😳
        • LucideL Offline
          Lucide
          **Update:**i reinstalled sketchup (actually, i reinstalled completely windows) and i replaced it with the 2017 edition, but this problem is still occurring! Help, it makes the entire tool unusable, and i was used to work so much with it...
            Did you install SketchUp 2017 as an administrator ?
            It is important to do this, otherwise weird things can happen.
            You do not need to uninstall to correct it.
            Close Sketchup 2017 if it's open.
            Find the SketchUp 2017 installer's exe file [Download Folder ?].
            Select its icon.
            Right-click.
            Context-menu.
            Run as administrator.
            If it is not a fresh install, then you can repair the existing installation by accepting a 'Repair' when prompted.
            Restart SketchUp 2017 to see if that helped.
            It is insufficient to have administrator powers and to install by double-clicking on the exe file, or or simple Run, you must explicitly use the 'Run as administrator' option...
            • fredo6F Offline
              It seems there is a bug coming from LibFredo6. I will republish tonight.
              • LucideL Offline
                Lucide
                Thank you TIG and Fredo6!
                I managed it to work by downloading the plugin from sketchucation store "manually" (search->download), instead of through the "bundle" menu as i was used to.
                Actually i don't know if it has really fixed the glitch, because sometimes the problem occurs again (it's sufficent to reload the model to get it working), or the interface vanishes during the "select" phase (this always happens on curviloft, more rarely on curvizard).
                Thank you for your your responses! 😄
                Lucide
                ps. i always run sketchup as administrator, and so i did with the installer.
                I tried to disable all the other plugins too, to prevent potential conflicts, but it didn't change anything. (i don't use particularly exotic plugins)
                • fredo6F Offline
                  @lucide
                  I just published LibFredo6 7.2e, which hopefully should fix your problem.
                  Thanks to advise the status, and also thanks for signaling the issue.
                  • LucideL Offline
                    Lucide
                    And here he is, Fredo6 😎
                    Lightning fast, with a new amazing update for one of the most used sketchup plugin in the entire community!
                    By the way, thank you
                    Lucide
                      littleche
                      Hi Fredo
                      Thanks for your principal And Amazing Plugins .
                      I have problem with smooth contours option in Curvizard . its not excluded sharp corner from smoothing .it means "smooth by section " and "Smooth Collinear Edges " not working for me. please see video on link if I could not Explain it . thanks .
                      https://www.mediafire.com/file/a8v93r6yrc43gx0/Curvizard.mp4
                        littleche
                        Hi again
                        No answer for me ?
                        • fredo6F Offline
                          @littleeche
                          Sorry for late answer. I missed your posted.
                          I think you need to put co-linear vertices on each side of the corner.
                          Anyway, That would help that you post the skp fil;e, so that I have a closer look.
                            littleche
                            Hi Again fredo and thanks for your Answer.
                            I uplode sample file . please look at it . in this file I showed points with A and B .
                            I would like to action fo "smooth contours " work On A point and Donot Work On B Points .
                            thanks from you in advance
                            Curvizard problem.skp
                            • fredo6F Offline
                              Not sure I got the issue you have. So, please have a look at the attached video and tell me.
                              Curvizard partial smooth.mov
                                littleche
                                Thanks for your video fredo . but your video is not my issue .
                                please select all edges and run "smooth contours " . Certainly i can select only A Points Too but My issue is "smooth by section" in "smooth contours "tool Does not work .
                                • fredo6F Offline
                                  [attachment=0:29goc5iu]<!-- ia0 -->233.png<!-- ia0 -->[/attachment:29goc5iu]
                                  That's why I was saying.
                                  To prevent a corner to smooth, you need to put 2 collinear vertices on each side (i.e. vertices in the middle of each segment). Otherwise there is no way that Curvizard knows you don't want to smooth them.
                                    littleche
                                    Ok ! its solved With Your hint to "put 2 collinear vertices on each side " .
                                    Thank You Fredo . Your plugins is excellent .
                                      Ahmed0007
                                      Watch This!
                                      https://www.youtube.com/watch?v=1OV_YF6jsQA
                                      • fredo6F Offline
                                        @ahmed0007 said:
                                        Watch This!
                                        Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
                                        In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
                                          CassieFlo
                                          I've downloaded this plugin using the SCF Plugin Store (and restarted Sketchup right after) and have LibFredo6 8.1. However I keep getting a message that pops up saying that I have to install LibFredo6 v6.9 or higher to run curvizard...any thoughts on what is going on or how I can get this plugin working?
                                          Thanks in advance!
                                          Cassie
                                            Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
                                            and you have restarted SketchUp completely...
                                            Then that error is indeed strange.
                                            You profile says: you have a MAC using SketchUp Pro - pre-v6 !
                                            Can you correct it and advise us on your current configuration...
                                            Help us to help you...
                                            • 8 / 10
