    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 372.6k Views 57 Watching
    • fredo6F Offline
      @lucide said:
      **Update:**i reinstalled sketchup (actually, i reinstalled completely windows) and i replaced it with the 2017 edition, but this problem is still occurring! Help, it makes the entire tool unusable, and i was used to work so much with it...
      It seems there is a bug coming from LibFredo6. I will republish tonight.
      • LucideL Offline
        Lucide
        Thank you TIG and Fredo6!
        I managed it to work by downloading the plugin from sketchucation store "manually" (search->download), instead of through the "bundle" menu as i was used to.
        Actually i don't know if it has really fixed the glitch, because sometimes the problem occurs again (it's sufficent to reload the model to get it working), or the interface vanishes during the "select" phase (this always happens on curviloft, more rarely on curvizard).
        Thank you for your your responses! 😄
        Lucide
        ps. i always run sketchup as administrator, and so i did with the installer.
        I tried to disable all the other plugins too, to prevent potential conflicts, but it didn't change anything. (i don't use particularly exotic plugins)
        • fredo6F Offline
          @lucide
          I just published LibFredo6 7.2e, which hopefully should fix your problem.
          Thanks to advise the status, and also thanks for signaling the issue.
          • LucideL Offline
            Lucide
            And here he is, Fredo6 😎
            Lightning fast, with a new amazing update for one of the most used sketchup plugin in the entire community!
            By the way, thank you
            Lucide
              littleche
              Hi Fredo
              Thanks for your principal And Amazing Plugins .
              I have problem with smooth contours option in Curvizard . its not excluded sharp corner from smoothing .it means "smooth by section " and "Smooth Collinear Edges " not working for me. please see video on link if I could not Explain it . thanks .
              https://www.mediafire.com/file/a8v93r6yrc43gx0/Curvizard.mp4
                littleche
                Hi again
                No answer for me ?
                • fredo6F Offline
                  @littleeche
                  Sorry for late answer. I missed your posted.
                  I think you need to put co-linear vertices on each side of the corner.
                  Anyway, That would help that you post the skp fil;e, so that I have a closer look.
                    littleche
                    Hi Again fredo and thanks for your Answer.
                    I uplode sample file . please look at it . in this file I showed points with A and B .
                    I would like to action fo "smooth contours " work On A point and Donot Work On B Points .
                    thanks from you in advance
                    Curvizard problem.skp
                    • fredo6F Offline
                      Not sure I got the issue you have. So, please have a look at the attached video and tell me.
                      Curvizard partial smooth.mov
                        littleche
                        Thanks for your video fredo . but your video is not my issue .
                        please select all edges and run "smooth contours " . Certainly i can select only A Points Too but My issue is "smooth by section" in "smooth contours "tool Does not work .
                        • fredo6F Offline
                          [attachment=0:29goc5iu]<!-- ia0 -->233.png<!-- ia0 -->[/attachment:29goc5iu]
                          That's why I was saying.
                          To prevent a corner to smooth, you need to put 2 collinear vertices on each side (i.e. vertices in the middle of each segment). Otherwise there is no way that Curvizard knows you don't want to smooth them.
                            littleche
                            Ok ! its solved With Your hint to "put 2 collinear vertices on each side " .
                            Thank You Fredo . Your plugins is excellent .
                              Ahmed0007
                              Watch This!
                              https://www.youtube.com/watch?v=1OV_YF6jsQA
                              • fredo6F Offline
                                @ahmed0007 said:
                                Watch This!
                                Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
                                In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
                                  CassieFlo
                                  I've downloaded this plugin using the SCF Plugin Store (and restarted Sketchup right after) and have LibFredo6 8.1. However I keep getting a message that pops up saying that I have to install LibFredo6 v6.9 or higher to run curvizard...any thoughts on what is going on or how I can get this plugin working?
                                  Thanks in advance!
                                  Cassie
                                    Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
                                    and you have restarted SketchUp completely...
                                    Then that error is indeed strange.
                                    You profile says: you have a MAC using SketchUp Pro - pre-v6 !
                                    Can you correct it and advise us on your current configuration...
                                    Help us to help you...
                                      CassieFlo
                                      I have indeed installed both latest versions and restarted SU completely multiple times.
                                      And oops! I am not sure why that was listed as such, I am using SU 2018.
                                      • fredo6F Offline
                                        Cassie,
                                        I just published an update to Curvizard (v2.1a), as I realized the published version was quite old (2015).
                                        Can you tell me if you still get an error.
                                        • fredo6F Offline
                                          NEW RELEASE: Curvizard v2.1a - 28 Mar 18
                                          Curvizard 2.1a is a maintenance release to keep the plugin on par with latest LibFredo6 versions. So upgrade is strongly suggested[/b][/color][/size].
                                          Requirement: LibFredo6 8.1 or above
                                          See main post of this thread for Download of Curvizard.
                                            CassieFlo
                                            Fredo-
                                            Yes! That worked, thank you so much!
                                            • 8 / 10
