    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • fredo6F
      NEW RELEASE: Curvizard v1.9a - 19 Oct 14
      Curvizard 1.9a is required for the support of usernames with non-ascii characters in Sketchup 2014
      See main post of this thread for Download of Curvizard.
      • P
        Penelope
        Help! I just used the SCF Plugin tool to install both Curvizard and LibFredo06 (in SU 2015 Pro).
        Get the following error: Curvizard 1.9a: Error starting up plugin (creating menus and icons) undefined method 'declare_topmenu' for #<Traductor::Plugin: etc. etc.
        Please help. I need to use this plugin for a project I'm doing this weekend.
        Thanks very much in advance!
        • P
          Penelope
          Please ignore my post of a few minutes ago. I finally got this plugin to work by restarting SU another time!
          • LucideL
            Lucide
            Thanks Fredo for all your hard work.
            I want to ask you about a problem that i have with Curvizard 2.0a on sketchup 2016.
            Both Curvizard and Libfredo are updated. (i checked with the sketchucation store v3 and with your tool)
            Every time i clic on any button, sketchup acts as i clicked on "undo" (like ctrl+z).
            This hissue happens only on Curvizard, but with almost any button.
            Do you know what could be the problem? 😮
            Thanks,
            Lucide.
            ps. i don't speak english very fluently 😳
            • LucideL
              Lucide
              **Update:**i reinstalled sketchup (actually, i reinstalled completely windows) and i replaced it with the 2017 edition, but this problem is still occurring! Help, it makes the entire tool unusable, and i was used to work so much with it...
                Did you install SketchUp 2017 as an administrator ?
                It is important to do this, otherwise weird things can happen.
                You do not need to uninstall to correct it.
                Close Sketchup 2017 if it's open.
                Find the SketchUp 2017 installer's exe file [Download Folder ?].
                Select its icon.
                Right-click.
                Context-menu.
                Run as administrator.
                If it is not a fresh install, then you can repair the existing installation by accepting a 'Repair' when prompted.
                Restart SketchUp 2017 to see if that helped.
                It is insufficient to have administrator powers and to install by double-clicking on the exe file, or or simple Run, you must explicitly use the 'Run as administrator' option...
                • fredo6F
                  It seems there is a bug coming from LibFredo6. I will republish tonight.
                  • LucideL
                    Lucide
                    Thank you TIG and Fredo6!
                    I managed it to work by downloading the plugin from sketchucation store "manually" (search->download), instead of through the "bundle" menu as i was used to.
                    Actually i don't know if it has really fixed the glitch, because sometimes the problem occurs again (it's sufficent to reload the model to get it working), or the interface vanishes during the "select" phase (this always happens on curviloft, more rarely on curvizard).
                    Thank you for your your responses! 😄
                    Lucide
                    ps. i always run sketchup as administrator, and so i did with the installer.
                    I tried to disable all the other plugins too, to prevent potential conflicts, but it didn't change anything. (i don't use particularly exotic plugins)
                    • fredo6F
                      @lucide
                      I just published LibFredo6 7.2e, which hopefully should fix your problem.
                      Thanks to advise the status, and also thanks for signaling the issue.
                      • LucideL
                        Lucide
                        And here he is, Fredo6 😎
                        Lightning fast, with a new amazing update for one of the most used sketchup plugin in the entire community!
                        By the way, thank you
                        Lucide
                        • L
                          littleche
                          Hi Fredo
                          Thanks for your principal And Amazing Plugins .
                          I have problem with smooth contours option in Curvizard . its not excluded sharp corner from smoothing .it means "smooth by section " and "Smooth Collinear Edges " not working for me. please see video on link if I could not Explain it . thanks .
                          https://www.mediafire.com/file/a8v93r6yrc43gx0/Curvizard.mp4
                          • L
                            littleche
                            Hi again
                            No answer for me ?
                            • fredo6F
                              @littleeche
                              Sorry for late answer. I missed your posted.
                              I think you need to put co-linear vertices on each side of the corner.
                              Anyway, That would help that you post the skp fil;e, so that I have a closer look.
                              • L
                                littleche
                                Hi Again fredo and thanks for your Answer.
                                I uplode sample file . please look at it . in this file I showed points with A and B .
                                I would like to action fo "smooth contours " work On A point and Donot Work On B Points .
                                thanks from you in advance
                                Curvizard problem.skp
                                • fredo6F
                                  Not sure I got the issue you have. So, please have a look at the attached video and tell me.
                                  Curvizard partial smooth.mov
                                  • L
                                    littleche
                                    Thanks for your video fredo . but your video is not my issue .
                                    please select all edges and run "smooth contours " . Certainly i can select only A Points Too but My issue is "smooth by section" in "smooth contours "tool Does not work .
                                    • fredo6F
                                      [attachment=0:29goc5iu]<!-- ia0 -->233.png<!-- ia0 -->[/attachment:29goc5iu]
                                      That's why I was saying.
                                      To prevent a corner to smooth, you need to put 2 collinear vertices on each side (i.e. vertices in the middle of each segment). Otherwise there is no way that Curvizard knows you don't want to smooth them.
                                      • L
                                        littleche
                                        Ok ! its solved With Your hint to "put 2 collinear vertices on each side " .
                                        Thank You Fredo . Your plugins is excellent .
                                          Ahmed0007
                                          Watch This!
                                          https://www.youtube.com/watch?v=1OV_YF6jsQA
                                          • fredo6F
                                            @ahmed0007 said:
                                            Watch This!
                                            Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
                                            In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
                                            • 8 / 10
