    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      @cotty said:
      I do prefer ultra-clean... ๐Ÿ˜‰
      I recommend to enable Remove Duplicate Face only when you know there is an issue. It's extremely slow and not always reliable.
        @plot-paris said:
        I then used thomthom's trick and did a first run, just Merging Faces and then a second, full cleanup. This worked!
        That's strange... and troublesome. It means the issue stems from compound cleanup actions. hmm...
        • cottyC Offline
          cotty
          Thank you for the tip!
          my SketchUp gallery
            AirWindSolar
            Possibly the order of the operations? Sounds like removing duplicate faces simplified it enough that whatever was crashing could handle what was left after that specific operation.
            One thing I'm noticing is that, for example, the bicycles are 24 separate but apparently identical ~600kb groups. That adds a lot of complexity compared to having a couple dozen instances of a single component. Same thing with several doors, etc. How hard would it be to recognize identical groups/components/items, and replace all of the duplicates with instances of one? (Maybe with some minimum complexity and/or count so it's not making components of every triangle or rectangle that happens to have a single mate somewhere.)
              I had a stab at that a few years ago: http://sketchucation.com/forums/viewtopic.php?t=30143
              But I never got around to finish it. It quickly becomes non-trivial.
                AirWindSolar
                Another thought on this one; not sure how hard it would be to calculate without saving, but a before and after file size, or percent reduction of the file size in the info box would be a handy bit of bragging if a user is wondering how much this saved them.
                  That would not be realistically possible with any kind of accuracy. The fileformat changes from version to version and the filesize depend on how SU pack the bytes.
                  Also, the filesize is not a good indication for how complex or large the model is. You can have a model with millions of faces and tiny filesize due to using components. On the other hand, you could also have a huge filesize with only a cube in the model - if there are applied large textures, watermarks etc. Materials, attributes, styles, watermarks all skew the filesize.
                  CleanUp was never made for saving filesize - it was for making the model geometry cleaner and simpler, hopefully improving the performance of the model a little. (Some times you do notice a big filesize difference - which is most likely due to purging unused items, but that's just a bonus.)
                    Why Clean Up after a Lattice Maker (by TIG) don't Clean coplanar thing ? ๐Ÿ˜ฎ
                    Solid Solver by TIG make it ! ๐Ÿ˜Ž
                    Solid Inspector2 don't make it! ๐Ÿ˜ฎ (by ThomThom)
                    Protrude by Jim
                    Fredo Scale by Fredo6
                    What I miss ?
                    https://s6.postimg.org/vdfavuvpt/mini_tut.jpg
                    why_not_clean.skp
                      kaas
                      @Thom - I'm curious - when using CleanUp3, the operation collapses the Outliner-list. Its the same behavior as choosing 'collapse all' when right-clicking on the level entry (the file name). Do you know what causes this behavior?
                      • mariochaM Offline
                        mariocha
                        I like localizing plugins. Helps me learn ruby. I found this one well written and thus a good teacher.
                        So it is now localized with LanguageHandler. And french strings. v 3.4.3
                        Should I get it signed before posting it here, or send it to you, or what ?
                        Cookies to you.
                        p.s.: I had to change the tooltips heredocs to strings, of course.
                        oh, also, no progressbar or status on Mac.
                        %(#008000)[Mario C.
                          ataman811
                          Hi!
                          How can I translate your plugin into Russian?
                          • OxerO Offline
                            Oxer
                            I translated the plugin to Spanish language a long time ago for my own use but I made it translating the strings in the .rb files directly.
                            mariocha, can you share the strings file to translate it to Spanish? what did you do to give support to the .rb files to translate the plugin?
                              CleanUp doesn't support translation right now.
                              If you want to translate, add a comment in the issue tracker; https://bitbucket.org/thomthom/cleanup/issues/16/localize
                              Mention what language you can contribute with.
                              • OxerO Offline
                                Oxer
                                Done!!
                                P.S.: Thom, have you see your private messages, I sent you a message a week ago about UVToolKit plugin.
                                • H Offline
                                  highlander
                                  Hello,
                                  Can someone tell me why this menu does not work anymore??
                                  Sander Hoogland
                                  SketchUp 2018 pro - Vray
                                  Beeld3d
                                    Try clearing the computer's Internet Explorer cache and restarting SketchUp to see if that helps...
                                    • pbacotP Offline
                                      Does anyone have some alternative plugins to this tool? It's pretty much useless in v.2019 except in the smallest drawings. Cleanup just takes too long now.
                                      I'd like another plugin that can remove lines without a face and coplanar lines. One that handles lonely vertices fast too would be great, but could be a separate tool (Fredo's tool works but I like the way CleanUp did it).
                                      Used to be the greatest tool in earlier SketchUp versions.
                                        Mochanic
                                        As I was saying on Youtube, I get a blank menu like the one in the attachment. What am I doing wrong?
                                        Also can you recommend an easy fix for all the holes that are created (like the ones in the 2nd attachment) when I import an STL file. It takes me HOURS to manually fix all the holes!
                                        Thanks for your help!
                                        just get this dark gray blank menu for some reason...
                                        whats an easy way to fix these holes, I have tried just about every tool I can find!
                                          Mochanic
                                          @highlander said:
                                          Hello,
                                          [attachment=0:1ogdx1re]<!-- ia0 -->cleanup_white.PNG<!-- ia0 -->[/attachment:1ogdx1re]
                                          I have the exact same problem! It's been like this for over a year now. I wish someone could tell me how to fix it...
                                          • pbacotP Offline
                                            Hasn't anyone else had problems with this tool in v. 2019? It has slowed considerably as to be mostly useless (i.e. you can do the cleanup faster yourself). It seems to be related to file size though you are only working on a selection. The larger the file, the slower it is.
                                            It's too bad. It was one of the greatest tools!
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 47 / 49
