    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 144.5k Views 84 Watching
      Is the Install button there ? [red]
      Does it 'click' ?
      Are you on Win10 ?
      [It would help us to help you if you filled in your user's profile...]
      Are you using SketchUp v2017 ?
      When you installed v2017 did you do it the proper way ?
      Select the installer's exe file icon > right-click > context-menu > "Run as administrator"
      You can try and 'repair' the current installation by doing the above steps and then choosing the "Repair" option when it is offered...
      If you have not installed it in this way weird issues can surface - like missing permissions etc...
      You also need an up to date version of Internet Explorer installed [v11], many of SketchUp's dialogs use it on PCs [Safari on MAC]
      Before restarting SketchUp also clear your Internet Explorer cache [Open IE and use Ctrl+Shift+Delete]
      Sometimes its cache can go wrong...
      Report back...
        Billygo
        With the extension Store Plugin How do you know what you're looking at before downloading or does one have to look them up first in the extension warehouse?
        thanks, Billy
          Stretch the dialog wider. Or click the little triangle next to the Authors name.
          • F Offline
            felixgrebretuar
            Hello everybody
            I would like to share my Extension Store plugin bundle with my colleagues in the office.
            How do I use the Sketchucation Tools / Extension Store3 to install a 'bundle' across multiple PC's?
            As every person logs in with their own 'profile' on their PC in our office, it seems not possible to install plugins on their PC via my login, as the installation is 'profile based'.
            I hope this makes sense.
            Or is the only way, that each user creates their own Sketchucation (and extension warehouse) login profile in order to install plugins? Can I share a bundle with other profiles?
            Many thanks in advance. Any ideas are much appreciated.
              Bundle sharing isn't possible.
              You would need a scenario where all PCs log in using one account and changes are synced to all devices.
              I think Pixero has a build of the ExtensionStore where we trialed this type of scenario. Where one person had managerial rights in an office environment. All other PCs could not install extensions only the manager could.
              Don't know if he uses it though?
              We revisit the Extension this summer to fix the issues and add new sparkles and knobs.
              • PixeroP Offline
                Pixero
                No I'm not. It was too strict as the end user could not add their own favorite plugins.
                I ended up using a "multi" login to one account for those who wished to use the predefined bundles.
                Not ideal though. I wish there was a "corporate" version where the admin could set levels of strictness. and maybe even force updates.
                I'd happily elaborate on this if you are considering doing something like that.
                • ludnidL Offline
                  ludnid
                  New version of sketchucation tools increases loading time for sketchup significantly.
                  Opening and closing the plugin's interface now has a loading time too before I can continue with my work. Reverting to the previous version had everything back at normal.
                  If you don't ask, the answer will always be no.
                    Do you mean 3.1.3 has increased startup time? Which version are you reverting to?
                    • ludnidL Offline
                      ludnid
                      I reverted back to Sketchucation 2.0
                        jtri
                        I am trying to install and when I open Sketch up Preferences I do not have the extensions option
                        What is my next step?
                          Go to Window > Extension Manager to install after SketchUp 2016
                            jtri
                            Got it!! thanks so much
                            • GD3DesignG Offline
                              GD3Design
                              Just wanted to share -
                              I had to disable most of my plugins due to a conflict with Vray 3.6.01. After update to Vray 3.6.02, most conflicts were fixed, but it seems that it still isn't getting along with Sketchucation Tools. After installing Sketchucation Tools, getting bugsplat while SU file is loading. Had to delete from Plugins folder to get SU file to open.
                              Hope they get all the conflicts worked out, I really miss Sketchucation Tools. 😞
                                Anything in the ruby console? Anyone else running into similar issue?
                                  GD3Design
                                  I didn't check...had a looming deadline that morning... Actually, i'm not sure I could check the ruby console....sketchup wouldn't open(bugsplat while file was opening.) Wouldn't I need SU open to check console?..(i don't know squat about programming..) Is there a log file that stores info in these cases?
                                    johnnygitarr
                                    hi,
                                    some questions:
                                    i there a solution how to delete the bundles under settings in the plugin?
                                    under favourites there are only 20 shown loved plugins and not all my loved.
                                    or do i understand it wrong! are there the most loved plugins from all users shown?
                                    i wished there are only my loved plugins and all of them!
                                    greetings
                                    johnny
                                      GΓ‘bor
                                      @johnnygitarr said:
                                      is there a solution how to delete the bundles under settings in the plugin?
                                      At the moment the only way to do this is to PM me and I can manually erase the bundles. There are plans to implement this function it is not in the current release.
                                      Your suggestion to show only all the loved plugins of the user makes sense. We'll do the modification of the code and let you know when it is ready / available.
                                        johnnygitarr
                                        hi Gabor,
                                        thnx for your answer.
                                        im looking forward to the modified version!
                                        hope you implement all my (user) loved plugins not only the first 20 of them.
                                        PM ist on the way.
                                        Greetings
                                        Johnny
                                        • ludnidL Offline
                                          ludnid
                                          @tig said:
                                          I'll PM you an old RBZ...
                                          Hi TIG,
                                          Any chance you can shoot me the same rbz? i.e the 2.0/2.6 version that is.
                                          Thanks.
                                            TBoy
                                            Info in plugin store say:
                                            .....<=v8 stick with v2.6...
                                            Please upload old versions 2.0/2.6 if possible!
                                            • 19
                                            • 20
                                            • 7 / 20
