    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 223.0k Views 84 Watching
    • ludnidL Offline
      ludnid
      New version of sketchucation tools increases loading time for sketchup significantly.
      Opening and closing the plugin's interface now has a loading time too before I can continue with my work. Reverting to the previous version had everything back at normal.
      If you don't ask, the answer will always be no.
        Do you mean 3.1.3 has increased startup time? Which version are you reverting to?
        • ludnidL Offline
          ludnid
          I reverted back to Sketchucation 2.0
            jtri
            I am trying to install and when I open Sketch up Preferences I do not have the extensions option
            What is my next step?
              Go to Window > Extension Manager to install after SketchUp 2016
                jtri
                Got it!! thanks so much
                • GD3DesignG Offline
                  GD3Design
                  Just wanted to share -
                  I had to disable most of my plugins due to a conflict with Vray 3.6.01. After update to Vray 3.6.02, most conflicts were fixed, but it seems that it still isn't getting along with Sketchucation Tools. After installing Sketchucation Tools, getting bugsplat while SU file is loading. Had to delete from Plugins folder to get SU file to open.
                  Hope they get all the conflicts worked out, I really miss Sketchucation Tools. ๐Ÿ˜ž
                    Anything in the ruby console? Anyone else running into similar issue?
                      GD3Design
                      I didn't check...had a looming deadline that morning... Actually, i'm not sure I could check the ruby console....sketchup wouldn't open(bugsplat while file was opening.) Wouldn't I need SU open to check console?..(i don't know squat about programming..) Is there a log file that stores info in these cases?
                        johnnygitarr
                        hi,
                        some questions:
                        i there a solution how to delete the bundles under settings in the plugin?
                        under favourites there are only 20 shown loved plugins and not all my loved.
                        or do i understand it wrong! are there the most loved plugins from all users shown?
                        i wished there are only my loved plugins and all of them!
                        greetings
                        johnny
                          Gรกbor
                          @johnnygitarr said:
                          is there a solution how to delete the bundles under settings in the plugin?
                          At the moment the only way to do this is to PM me and I can manually erase the bundles. There are plans to implement this function it is not in the current release.
                          Your suggestion to show only all the loved plugins of the user makes sense. We'll do the modification of the code and let you know when it is ready / available.
                            johnnygitarr
                            hi Gabor,
                            thnx for your answer.
                            im looking forward to the modified version!
                            hope you implement all my (user) loved plugins not only the first 20 of them.
                            PM ist on the way.
                            Greetings
                            Johnny
                            • ludnidL Offline
                              ludnid
                              @tig said:
                              I'll PM you an old RBZ...
                              Hi TIG,
                              Any chance you can shoot me the same rbz? i.e the 2.0/2.6 version that is.
                              Thanks.
                                TBoy
                                Info in plugin store say:
                                .....<=v8 stick with v2.6...
                                Please upload old versions 2.0/2.6 if possible!
                                  After some searching through archives...
                                  Here's an old version RBZ [2.6.2] that should work with v8 - BUT please remember that ALL other users with a newer SketchUp versions should always use the latest version 3... RBZ from the PluginStore.
                                  SketchUcationToolset_v2.6.2-b11.rbz
                                  No promises that it's perfect !
                                    TBoy
                                    Thank you Mr. TIG,
                                    This version give some errors.
                                    Anyway it is enough for me as I'll use only Plugin Manager.
                                    (So I removed extra .rbs files in main folder and Error disappeared.)
                                    Thank you again.
                                    (Why SketchUp 8 - I decided to make a backup copy of SketchUP-8 with useful plugins inside - may be a stupid task, but it will stay in my archives.
                                    And for information only - v8 is a lot faster at startup.)
                                      kinesis
                                      Hi everyone
                                      How can I install a plugin into a custom folder through ExtensionStore v3.18 which the plugin info clearly says I can.
                                      "Install SketchUp plugins or extensions into custom folder locations" from https://sketchucation.com/plugin/696-sketchucationtools
                                        If you have more than one plugins folder defined for that version of SketchUp, then you are prompted with a dialog to choose the alternative destination - the standard Plugins folder is the default.
                                        Some users get caught out by this dialog initially being sized to small to show the whole dropdown list - if so resize it by dragging a corner... its new size should then be remembered across sessions.
                                        Obviously if you don't have any alternative plugins folders defined the choice dialog is skipped...
                                        You can also have an additional Plugins folder set up if you have installed some complex app that used its own installer - often a rendering app.
                                        This is often not installed in your user's Plugins folder, but a shared Plugins folder in the ProgramData path - install in there if you want all users to have that extension loading into their equivalent version of SketchUp...
                                        If there's no ProgramData Plugins folder it's not listed.
                                        Another way to create your own extra Plugins folders is to use an extension - typically Fredo's 'Additional Plugins Folders' available from the PluginStore - this lets you define your own destination folder[s] which is then added to SketchUp's installation-destinations list as SketchUp starts.
                                        You typically use this tool to load your preferred extensions from your own special plugins folder[s], perhaps having it shared across several versions of SketchUp [all running Fredo's 'Additional Plugins Folders'].
                                        With an additional folder set up, the choice dialog should list it as an alternative to the main Plugins folder...
                                          johnnygitarr
                                          i recently updated to SKP 2021.
                                          In my running SKP 2020 i got the update to sketchucation store 4.0
                                          and i installed it.
                                          Since this update i got massive problems and freezes with SKP 2020
                                          when i want to load the context menu (right mouse click).
                                          SKP 2020 got a neverending beachball of death and i have to
                                          do a hard shutdown of SKP 2020.
                                          I tried to activate/deactivate all of my plugins (i have many).
                                          no plugin makes problems, but when i activate sketchucation store,
                                          the freezes in context menu starts.
                                          the problem is definitely the sketchucation store 4.0 plugin in SKP 2020.
                                          Can i somewhere download the older version to try, if it works.
                                          Better would be to fix the plugin for SKP 2020.
                                          Greetings
                                          Johnny
                                            Thanks for the report.
                                            It's been tested on >=2017 so it should be OK on PC and MAC.
                                            Obviously you have a problem that you suspect might be related to v4.0.0
                                            If you have the RBZ for the earlier version try installing that instead... see if that helps...
                                            If not Gรกbor, then can give you a link to get the older version RBZ... suitable on all current versions
                                            Although in v2021 the SCF-licensing is then out of date...
                                            Using it in v2020 should be OK.
                                            However, it'd be useful to work out what your issue is in case others are getting the problem.
                                            So some more info please...
                                            What OSx are you using exactly ?
                                            What version[s] of SketchUp are you using exactly ?
                                            What context-menu issues happen - exactly ?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
