    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
    • F
      felixgrebretuar
      Hello everybody
      I would like to share my Extension Store plugin bundle with my colleagues in the office.
      How do I use the Sketchucation Tools / Extension Store3 to install a 'bundle' across multiple PC's?
      As every person logs in with their own 'profile' on their PC in our office, it seems not possible to install plugins on their PC via my login, as the installation is 'profile based'.
      I hope this makes sense.
      Or is the only way, that each user creates their own Sketchucation (and extension warehouse) login profile in order to install plugins? Can I share a bundle with other profiles?
      Many thanks in advance. Any ideas are much appreciated.
        Bundle sharing isn't possible.
        You would need a scenario where all PCs log in using one account and changes are synced to all devices.
        I think Pixero has a build of the ExtensionStore where we trialed this type of scenario. Where one person had managerial rights in an office environment. All other PCs could not install extensions only the manager could.
        Don't know if he uses it though?
        We revisit the Extension this summer to fix the issues and add new sparkles and knobs.
        • PixeroP
          Pixero
          No I'm not. It was too strict as the end user could not add their own favorite plugins.
          I ended up using a "multi" login to one account for those who wished to use the predefined bundles.
          Not ideal though. I wish there was a "corporate" version where the admin could set levels of strictness. and maybe even force updates.
          I'd happily elaborate on this if you are considering doing something like that.
          • ludnidL
            ludnid
            New version of sketchucation tools increases loading time for sketchup significantly.
            Opening and closing the plugin's interface now has a loading time too before I can continue with my work. Reverting to the previous version had everything back at normal.
            If you don't ask, the answer will always be no.
              Do you mean 3.1.3 has increased startup time? Which version are you reverting to?
              • ludnidL
                ludnid
                I reverted back to Sketchucation 2.0
                  jtri
                  I am trying to install and when I open Sketch up Preferences I do not have the extensions option
                  What is my next step?
                    Go to Window > Extension Manager to install after SketchUp 2016
                      jtri
                      Got it!! thanks so much
                      • GD3DesignG
                        GD3Design
                        Just wanted to share -
                        I had to disable most of my plugins due to a conflict with Vray 3.6.01. After update to Vray 3.6.02, most conflicts were fixed, but it seems that it still isn't getting along with Sketchucation Tools. After installing Sketchucation Tools, getting bugsplat while SU file is loading. Had to delete from Plugins folder to get SU file to open.
                        Hope they get all the conflicts worked out, I really miss Sketchucation Tools. 😞
                          Anything in the ruby console? Anyone else running into similar issue?
                          • GD3DesignG
                            GD3Design
                            I didn't check...had a looming deadline that morning... Actually, i'm not sure I could check the ruby console....sketchup wouldn't open(bugsplat while file was opening.) Wouldn't I need SU open to check console?..(i don't know squat about programming..) Is there a log file that stores info in these cases?
                              johnnygitarr
                              hi,
                              some questions:
                              i there a solution how to delete the bundles under settings in the plugin?
                              under favourites there are only 20 shown loved plugins and not all my loved.
                              or do i understand it wrong! are there the most loved plugins from all users shown?
                              i wished there are only my loved plugins and all of them!
                              greetings
                              johnny
                              • G
                                GΓ‘bor
                                @johnnygitarr said:
                                is there a solution how to delete the bundles under settings in the plugin?
                                At the moment the only way to do this is to PM me and I can manually erase the bundles. There are plans to implement this function it is not in the current release.
                                Your suggestion to show only all the loved plugins of the user makes sense. We'll do the modification of the code and let you know when it is ready / available.
                                  johnnygitarr
                                  hi Gabor,
                                  thnx for your answer.
                                  im looking forward to the modified version!
                                  hope you implement all my (user) loved plugins not only the first 20 of them.
                                  PM ist on the way.
                                  Greetings
                                  Johnny
                                  • ludnidL
                                    ludnid
                                    @tig said:
                                    I'll PM you an old RBZ...
                                    Hi TIG,
                                    Any chance you can shoot me the same rbz? i.e the 2.0/2.6 version that is.
                                    Thanks.
                                    • T
                                      TBoy
                                      Info in plugin store say:
                                      .....<=v8 stick with v2.6...
                                      Please upload old versions 2.0/2.6 if possible!
                                        After some searching through archives...
                                        Here's an old version RBZ [2.6.2] that should work with v8 - BUT please remember that ALL other users with a newer SketchUp versions should always use the latest version 3... RBZ from the PluginStore.
                                        SketchUcationToolset_v2.6.2-b11.rbz
                                        No promises that it's perfect !
                                        • T
                                          TBoy
                                          Thank you Mr. TIG,
                                          This version give some errors.
                                          Anyway it is enough for me as I'll use only Plugin Manager.
                                          (So I removed extra .rbs files in main folder and Error disappeared.)
                                          Thank you again.
                                          (Why SketchUp 8 - I decided to make a backup copy of SketchUP-8 with useful plugins inside - may be a stupid task, but it will stay in my archives.
                                          And for information only - v8 is a lot faster at startup.)
                                          • K
                                            kinesis
                                            Hi everyone
                                            How can I install a plugin into a custom folder through ExtensionStore v3.18 which the plugin info clearly says I can.
                                            "Install SketchUp plugins or extensions into custom folder locations" from https://sketchucation.com/plugin/696-sketchucationtools
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
