    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • PixeroP Offline
      Pixero
      @fredo6 said:
      Corners made of quads, as opposed to triangles (for tri-border corners) are possible. However, even in orthogonal cases, each quad may be triangulated. So this increases the number of facets.
      But it would make it possible to texture better with UV's as for example QuadFaceTools can interpret pairs of those triangles as a quad.
      @fredo6 said:
      For a Proxy of RoundCorner, this is independent. Actually, any script doing an object transformation could (or should) have a proxy to enable / disable. Sketchup does not provide a standard method for that, so I guess it has to be simulated, via copy, invisible layers or simply parameterization.
      Maybe you could check with Thomthom how he does it in SubD?
      When I have thought about this I was thinking of saving the original geometry information in an attribute, but that is perhaps a bad idea?
      Or how does a modify stack work in for example Max?
      I'm sure a system for history would benifit a lot of SU plugins.
      If it would be possible with a on/off switch it would be a great addition to SU. 👍
      • DATAKASHD Offline
        DATAKASH
        @fredo6 said:
        @datakash said:
        Round Corner has minor problems with rendering. Subdivision is much smoother.
        Subdivision can be turned off and mesh corrected.
        That's interesting! and it would be useful to understand why?
        • Is it because the rounding is circular?
        • or too regular?
        • of for other reasons related to the Rendering parameters
        I think this is due to the fact that subdivision affects the whole object
        And yes, his grid is also triangulated.
        As I see, creating offset by selecting each face manually
        (If this is a reasonable solution?)
        • fredo6F Offline
          What I see at least as a true difference is that, with SubDivision, the edges and corners are not rounded with circle (as in RoundCorner), but with other types of curves (Catmull-Clark splines). So the transition for the flat part to the rounding is different.
          The other difference in your example is that the flat face is also 'quadified' with co-planar facets, triangular. So here too, for rendering there may a difference between this set of facets versus a single big face, even if geometrically, the two situations are identical.
          I don't know if anyone has some opinions on all this, in relation with renering.
          • PixeroP Offline
            Pixero
            Maybe this thinking is applicable?
            https://hackernoon.com/apples-icons-have-that-shape-for-a-very-good-reason-720d4e7c8a14
            • fredo6F Offline
              Pixero,
              Interesting indeed.
              I made a few trials, which are illustrated in the attached model (SU2015), with 6 types of rounding, each generated with 6 segments. I also made a quick rendering with Thea.
              Could any one advise on what is the 'best' for Rendering.
              Corner iphone.skp
              • kimi kimiK Offline
                kimi kimi
                Hi Fredo, hi everyone,
                I made an update to my Round Corner plugin this morning, and now I can't see the toolbar with all the options when I activate the command. Is this a problem only on my computer, or does someone else have it too?
                As you can see on screenshot, the command is active, there is text in bottom left and right, but I don't see the toolbar. I tried erasing it, erasing and reinstalling Fredo6 library, but still same result.
                • PixeroP Offline
                  Pixero
                  @fredo:
                  Thats a tough one... not number 2 or 2,5 but the rest I have a hard time deciding which look best when rendered. Maybe if you commented on what the difference between them are?
                  • fredo6F Offline
                    Could you open the RUBY console and advise on any error message you would observe.
                    • fredo6F Offline
                      @pixero said:
                      @fredo:
                      The number is a factor of blending between a circle and a square (Squircle or super-circle).
                      • 2 is a pure circle
                      • 2.5, 3, 4, 5, 6 are blended curve, the higher the number, the closer to a square.
                      I least I witness that you think a squircle is better than a pure circular profile for rendering.
                      Since another common utilisation of RoundCorner is for 3D-printing, it remains to be decided if this is also the case.
                        kimi kimi
                        Thanks for your response,
                        I'm not sure what to look for in Ruby Console, so I just copied text from it.
                        I suppose this might point to something.
                        Error: #<NoMethodError: undefined method `view_line_width=' for G6:Module>
                        round corner ruby console.txt
                        • fredo6F Offline
                          @kimi kimi
                          Simple. You need to upgrade LibFredo6 to the latest version (v7.7c).
                            CREAIMMO
                            Bonjour,
                            Merci pour Roundcorner, c'est un plugin sympa.
                            Est ce qu'il serait possible dans une futur mise a jour de prévoir des chanfreins avec 2 cotes différentes
                            que x soit different de Y
                            actuellement si je donne une valeur de chanfrein de 1mm il va faire 1 mm de chque coté de l'arrete principale
                            sauf que j'aimerai que l'on puisse choisir 1mm en y et 0,5mm en x exemple
                            Cordialement
                            creaimmo
                            • fredo6F Offline
                              Asymmetric rounding is indeed an interesting features, requested by very few users however. With the current approach of RoundCorner, would be a little bit difficult. So It will have to wait for a full refresh.
                                countercharge
                                Hi, sorry for the noob question but I've installed this plugin and even after reading the documentation I can't figure out how to use it. I don't see any way to bring up the interface after selecting the edge I want to round.. nothing in the toolbar, nothing in the menu. The plugin is enabled but I'm totally at a loss as to how to use it.
                                edit: nevermind, the interface showed up
                                • fredo6F Offline
                                  Did you identify what was the problem (in case this happens to other users)?
                                    countercharge
                                    I did not, but I think it appeared when I closed and re-opened sketchup. I assumed it would load once the plugin was loaded and enabled.
                                    Loving it so far but I can't figure out how to round edges that are on the inside/interior of an object. If I try to do that, it covers the opening. I'm sure that's somewhere in this long thread.. any idea what page to look at?
                                    • fredo6F Offline
                                      Just erase the cover face(s). The rounding is underneath.
                                      • fredo6F Offline
                                        NEW RELEASE: RoundCorner v3.2e - 25 Oct 17
                                        RoundCorner 3.2e is a maintenance release. It fixes a weird issue on French platforms, preventing the plugin to launch (in relation with decimal separator differences)..
                                        Home Page of RoundCorner for information and Download.
                                        Main post of this thread.
                                          jtri
                                          I am working on knife and when I use the round over tool I loose faces. A copy of the handle is at 1000x as I wanted to show that scaling up does not fix the issue I have. My model is at the origin original size and it has a volume.
                                          I have used this wonderful tool many times before but I seem to have developed this model in a way that is not compatible with the round over tool.
                                          I used Cuviloft to skin if that is a factor. Also I welded all the perimeter lines hoping that might help, it did fix some issues.
                                          Jeff
                                          Test.skp
                                            Even scaled up, the tiny radius on the round overs creates some bad geometry. Make a reasonable radius and it works. I used 10 in.
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 74
                                            • 75
                                            • 62 / 75
