    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      So this has nothing to do with FredoScale.
      • fredo6F Offline
        @gudio83 said:
        Any idea how to resolve this bug?
        SU2017 x64, Win10
        SU2017 has changed a few things in the dimensioning of web dialogs.
        Normally, you should be able to resize and adjust the size, which would be kept for the next use.
        I just have one doubt: not sure I released the fix in FredoTools 3.0a (i.e. the capability to resize the dialog box).
        • E Offline
          elfis
          First of all that you for the best plugin in sketchup. Enginsh is not my native language so I record this short clip to explain my problem.
          When I copy group of objects and start to stretching one of them I'm getting this conflict.
          I know there is problem with components when they all not unique but why with groups ?
          It was fine before format of windows with different versions of plugin.
          For now i'm using Sketchup 2016 and latest plugin with libs.
          Kind Regards
          Patrick
          ps. Sorry if this is noob question.
          • fredo6F Offline
            In Sketchup, a group just copied behaves like Components...
            ...unless you just edit (i.e. double click) the group you copied.
            This is probably for optimization.
            • E Offline
              elfis
              Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
              Group Tree
              • array81A Offline
                array81
                I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
                  They don't show even after you enabled them and restarted SketchUp?
                    georgeoakblaster
                    Is there a way to get the dimension tags to update after you resize using the 'box stretching' feature? At the moment I re-add them manually to get them to update to the correct measurement.
                    Thanks for this great plugin Fredo.
                      @georgeoakblaster said:
                      Like this?
                        georgeoakblaster
                        Thanks,
                        I should have mentioned this is when using 'enter new dimensions' which is on the right click dialogue box.
                        George
                          Maybe you could post a screen shot of what you are trying to describe because it isn't clear.
                          The New Dimension window is intended to allow you to type in the new dimension.
                          What is the "dimension tag" you refer to?
                            kevsterman
                            Hey guys. I've recently discovered radial bend and its just brilliant. Its really helping me with some illustrations I'm doing. I was wondering if there's a way for the materials to bend as well as the model. So far the materials either stay the same or go a bit skew-whiff, they don't bend in the same directions as the face they're on. Any way of doing this?
                            "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                            • fredo6F Offline
                              Unfortunately, Radial Bend creates a lot of new faces and triangulation due to slicing. So, reconstructing the original texturing would be kind of big headache!
                              In general, texturing should be done on final shapes.
                                kevsterman
                                Ok thanks Fredo. That's good to know πŸ‘
                                  kevsterman
                                  Hi guys. I have another question regarding radial bend. As you can see from the image all of the lines denoting brickwork haven't bended as I was expecting. I'm not sure why. Is it a parameter problem or maybe something to do with the model? Its probably something really easy I'm missing πŸ˜•
                                  • robertWanR Offline
                                    robertWan
                                    Why? 😞
                                    https://youtu.be/FgNyfpZPVfA
                                    Robert
                                    • fredo6F Offline
                                      @robertwan said:
                                      Why? 😞
                                      Robert
                                      'By default', FredoScale Stretching makes the component unique before operating on it.
                                      The issue is that I did not provision an option to apply to all instances instead.
                                        Is there any way around it? I expect so. Upload your SKP so we can see what you've got so far.
                                          Lorand
                                          File attached.
                                          FScale test.skp
                                            Lorand
                                            Hi all,
                                            Great plugin like all Fredo6 ones, thank you sir.
                                            Problem: Imagine a simple Chinese lamp - equilateral triangles at the top and bottom and FredoScale TWIST for elegantly getting the surfaces between them - but the TWIST function twists around the axis of the boundary box not the axis through the centers of the bottom and top triangles and the result is skewed. Same goes for any odd sided polygons: those two centers are different. Is there any way to use TWIST and get the "expected" result?
                                            Thank you in advance,
                                            Lorand
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 56
                                            • 57
                                            • 31 / 57
