    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 790.4k Views 121 Watching
      bharralure
      Bonjour Fredo
      Puisque c'est ma journée "réclamations", après LibFredo6, je reviens avec FredoTools.
      Depuis un certain temps, je ne me souviens plus trop quand d'ailleurs (peut-être depuis ma migration vers Windows 10, il y a seulement quelques mois), la fenêtre qui s'affiche à l'écran après avoir lancé l'outil "Étiqueter les Surfaces" se trouve réduite en hauteur tel que montré sur la capture d'écran qui suit.
      Ce n'est pas un gros problème, mais dans sa taille d'origine, je suis pas obligé de jouer de l'ascenseur.
      • fredo6F Offline
        This is due to SU2017, which is messing up dimensions in web dialogs.
        Can you tell me if you can resize the dialog box?
        Fred
          bharralure
          Non, la boîte de dialogue n'est pas redimensionnable.
          • fredo6F Offline
            NEW RELEASE: FredoTools v3.0c - 13 Feb 17
            FredoTools 3.0c fixes sizing issues for some dialog boxes in SU2017
            • V Offline
              vlad_s
              Good day, does not work markvertex with fredolib 7.3 and 7.5 in windows xp. In fredolib 6.4 worked.
              Sorry for the English language, computer translation from Russian.
                cadmunkey
                Hi Fredo, any reason the Sold Volume calculator would report a solid back as a minus figure?
                I took volume calc from my marble model and thought something was strange with the result. So checked individual pieces and some are reporting a minus figure, which of course deducts itself from the final overall result.
                  Cadmunkey, is it possible the faces are reversed on the volume?
                    cadmunkey
                    Hi Dave, no I did check for this. I cant see a reason for it at all.
                      How about copying and pasting that volume into a new file and sharing it so we can see it?
                        cadmunkey
                        Dave, happy to send it to you privately for a look? its a 12mb file.
                        • fredo6F Offline
                          @cadmunkey
                          You are right. Actually, the result is correct mathematically. In the algorithm, negative volumes are normally used for holes in solids. But intuitively, we are not used to negative volumes.
                          So, I fixed it, and it will go in the next release.
                            cadmunkey
                            @fredo6 said:
                            @cadmunkey
                            These are not holes in solids, if you want I can email you my model for analysis.
                            Its a marble stone cut list, and some of the stones are reporting back as negative volumes.
                            • fredo6F Offline
                              I mean that when you flip along a group or component instances, you actually transform their axes and mathematically, this gives a negative volume, as it does for holes in the solid.
                              Anyway, many thanks for signalling the problem.
                                rv1974
                                I wish Curvishear could be become way more usable by
                                letting user 'in-vivo' move a vertex (and thus setting desired height and slope direction)
                                  bharralure
                                  Bonjour Dave
                                  Je confirme que "Volume Solides" affiche une valeur négative pour toute instance crée en miroir.
                                  Ce problème n'est pas spécifique à SU 2017, l'ayant déjà constaté sous SU 2016 et SU 2015.
                                  Je joint un Gif crée sous SU 2017.
                                  • fredo6F Offline
                                    NEW RELEASE: FredoTools v3.1a - 09 Jul 17
                                    Requirement: LibFredo6 v7.7a
                                    FredoTools 3.1a introduces a new plugin, called DivideEdges. It also supports hi-resolution screens and fixes some bugs.
                                    See FredoTools home page for Download.
                                    • JClementsJ Offline
                                      JClements
                                      Divide Edges (DE) is a nice new addition to your toolset. Thank you!
                                      Perhaps a version of DE could be adapted to produce dashed lines? When selected only an ODD number of segments would be available, then every-other-segment after the first segment would be deleted or hidden (not sure which would be the best to go). Maybe it could be "parametric" in the sense that the user could restore the original at later time and apply and different number of segments.
                                      • fredo6F Offline
                                        NEW RELEASE: FredoTools v3.1b - 11 Jul 17
                                        FredoTools 3.1b fixes a bug in FredoTools::SolidVolume, as signaled by Alex37550. See this post.
                                        See FredoTools plugin home page for Download.
                                        See also main post of this thread for User Discussion.
                                          rv1974
                                          MoveAlong question:
                                          How difficult would it be to implement
                                          a Multiple objects move (rotate?) by their local axes?
                                          • fredo6F Offline
                                            @rv1974 said:
                                            MoveAlong question:
                                            Should be a dedicated tool.
                                            MoveAlong is already complex, and I did not add the move along local axes (there are inferences however), as I did in Animator.
                                            That's not a matter of programming ; Putting too many features in a plugin defeats the purpose, as then it is judged cluttered with options that nobody really uses.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 23
                                            • 24
                                            • 13 / 24
