    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 790.4k Views 121 Watching
    • E Offline
      Elster32
      Is it possible to increase the size of the dialog box? On my screen it is so small it is almost impossible to see the buttons! I wondered whether there was an option but because of the small size I was unable to see it? Thank you
      • fredo6F Offline
        NEW RELEASE: FredoTools v3.0a - 20 Oct 16
        FredoTools 3.0a is a release mainly related to FredoTools::ThruPaint with the introduction of a Purge feature.
        • fredo6F Offline
          NEW RELEASE: FredoTools v3.0b - 31 Oct 16
          FredoTools 3.0b fixes a major bug bug preventing FredoTools to load properly for SU versions < 2014. So, if you run SU6, SU7, SU8 or SU2013, please upgrade to v3.0b.
            SpookyChick1013
            Hi Fredo,
            Thanks for continuing to update your tools.
            I'm having an issue with ThruPaint where I invoke the tool and it promptly does nothing. Nothing shows in the error console, it just refuses to come up.
            EDIT:]Woops! Mybad. There is something in the Ruby console.
            (eval):1: warning: already initialized constant T7
            Hope this helps.
            It was working fine for me prior to me updating things over the last two days. I'm using the latest downloads of FredoTools, and FredoLib, right out of the SU Plugin store.
            I have double-checked the plugin footprint, and it looks like it should look.
            Still on SU7.1.6860, Win7Prox64
            Second update.
            I have no idea why this worked but I unchecked Fredo Tools in the extensions, restarted and now Thrupaint is working just fine, as is everything else. The weird thing is, I did not re-enable The Fredo6 Fredo Tools extension, yet things are working fine. 😲 😕
            Update weirdness makes my head hurt, 😆
            I guess there's nothing to worry about after all.
            Thanks in advance,
            Cathryn
            https://kuromatsudriveyards.com
            Fo-su to tomo ni aran koto o...
              bharralure
              Bonjour Fredo
              Puisque c'est ma journée "réclamations", après LibFredo6, je reviens avec FredoTools.
              Depuis un certain temps, je ne me souviens plus trop quand d'ailleurs (peut-être depuis ma migration vers Windows 10, il y a seulement quelques mois), la fenêtre qui s'affiche à l'écran après avoir lancé l'outil "Étiqueter les Surfaces" se trouve réduite en hauteur tel que montré sur la capture d'écran qui suit.
              Ce n'est pas un gros problème, mais dans sa taille d'origine, je suis pas obligé de jouer de l'ascenseur.
              • fredo6F Offline
                This is due to SU2017, which is messing up dimensions in web dialogs.
                Can you tell me if you can resize the dialog box?
                Fred
                  bharralure
                  Non, la boîte de dialogue n'est pas redimensionnable.
                  • fredo6F Offline
                    NEW RELEASE: FredoTools v3.0c - 13 Feb 17
                    FredoTools 3.0c fixes sizing issues for some dialog boxes in SU2017
                    • V Offline
                      vlad_s
                      Good day, does not work markvertex with fredolib 7.3 and 7.5 in windows xp. In fredolib 6.4 worked.
                      Sorry for the English language, computer translation from Russian.
                        cadmunkey
                        Hi Fredo, any reason the Sold Volume calculator would report a solid back as a minus figure?
                        I took volume calc from my marble model and thought something was strange with the result. So checked individual pieces and some are reporting a minus figure, which of course deducts itself from the final overall result.
                          Cadmunkey, is it possible the faces are reversed on the volume?
                            cadmunkey
                            Hi Dave, no I did check for this. I cant see a reason for it at all.
                              How about copying and pasting that volume into a new file and sharing it so we can see it?
                                cadmunkey
                                Dave, happy to send it to you privately for a look? its a 12mb file.
                                • fredo6F Offline
                                  @cadmunkey
                                  You are right. Actually, the result is correct mathematically. In the algorithm, negative volumes are normally used for holes in solids. But intuitively, we are not used to negative volumes.
                                  So, I fixed it, and it will go in the next release.
                                    cadmunkey
                                    @fredo6 said:
                                    @cadmunkey
                                    These are not holes in solids, if you want I can email you my model for analysis.
                                    Its a marble stone cut list, and some of the stones are reporting back as negative volumes.
                                    • fredo6F Offline
                                      I mean that when you flip along a group or component instances, you actually transform their axes and mathematically, this gives a negative volume, as it does for holes in the solid.
                                      Anyway, many thanks for signalling the problem.
                                        rv1974
                                        I wish Curvishear could be become way more usable by
                                        letting user 'in-vivo' move a vertex (and thus setting desired height and slope direction)
                                          bharralure
                                          Bonjour Dave
                                          Je confirme que "Volume Solides" affiche une valeur négative pour toute instance crée en miroir.
                                          Ce problème n'est pas spécifique à SU 2017, l'ayant déjà constaté sous SU 2016 et SU 2015.
                                          Je joint un Gif crée sous SU 2017.
                                          • fredo6F Offline
                                            NEW RELEASE: FredoTools v3.1a - 09 Jul 17
                                            Requirement: LibFredo6 v7.7a
                                            FredoTools 3.1a introduces a new plugin, called DivideEdges. It also supports hi-resolution screens and fixes some bugs.
                                            See FredoTools home page for Download.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 23
                                            • 24
                                            • 13 / 24
