    Double-Cut - Cut through double-sided walls
    extensions
    44 Posts 19 Posters 24.2k Views 19 Watching
    • srxS Offline
      srx
      This is because the wall is not a solid. Faces on the side belongs to window group I guess.
      www.saurus.rs
      • utilerU Offline
        utiler
        Whether its a solid or not surely the skalp tool should be able to work similar to the SU native tool??
        Just Curious...
        • srxS Offline
          srx
          SU native tool doesn't make faces inside the wall.
          www.saurus.rs
          • JQLJ Offline
            JQL
            The problem is related with hole cutting components.
            They are not creating new geometry as they are not actually cutting away the face, they're just displaying it differently... actually they are hiding it. But the face is still there.
            Sectioncut face doesn't usually draw the face on the section but draws the edges of the faces that have been cut by hole cutting components.
            This requires some manual cleaning on Section cut face side, which is usually not that hard to do. For folks using skalp, it might ruin the workflow... I don't use it.
            www.casca.pt
            Visit us on facebook!
            • facerF Offline
              facer
              Whaat,
              Could you please post your instruction gif files at 1/2 the speed.
              This will make it easier to follow each step.
              Regards,
              Ray
              • minimalexM Offline
                minimalex
                @jql said:
                ...it might ruin the workflow... I don't use it.
                Oh no! I was so excited that double cut was going to save me huge amounts of time, and now I have to pick whether I am more invested in double-cut or Skalp. Super bummed about this.
                Anyone think this has a chance of changing ever?
                • JQLJ Offline
                  JQL
                  I see two ways:
                  • Either Trimble exposes something in their API for section plugins to aknowledge the openning as true geometry and not a hidden face.
                  • Or Skalp finds a workaround for that. Skalp is, itself a plugin built on incredibly well thought workarounds so they might find a way if you ask them.
                  The good news is that there are other plugins that suffered from this issue in the past and solved it.
                  The first one I noticed was Fredotools Report on Area. If you would report on a wall with 2x2m it would report 4m2. If you'd glue a holecutting component to it, it would still report the 4m2 even if the window should have subtracted it's area from the 4m2. Fredo solved it at the time when I reported. I don't know how he did it, of course.
                  Blendup was exporting faces with holecutting components without holes. After reporting the "bug" the fix was to explode the components, export the model, undo the explosion. It works very fast and everything looks as it was before.
                  Probably there are many more examples that I'm not aware of.
                  I don't use skalp, but if you report that to the developers probably they will take a look.
                  www.casca.pt
                  • halroachH Offline
                    halroach
                    Thanks Dale for a great plugin!
                    Purchased as soon as I saw it was out.
                    An issue I'm having, is when placing a cutting door on an inside wall. I place it of course on the very bottom of the wall. What happens is that there is Z-fighting/Overlapping faces between three different elements:
                    1. The bottom face of the wall.
                    2. The newly generated double-cut reveals geometry.
                    3. The Flooring component.
                    Easiest is to hide the bottom face of the wall, but then there is still Z-fighting between the the double-cut reveals and the flooring.
                    Deleting faces from the flooring is not an option.
                    Deleting/hiding the reveals is possible, but it's very cumbersome at the moment - unlocking the reveals element, finding the face and deleting/hiding. If the component is then moved, have to redo this procedure again because the reveals are regenerated. This makes it very difficult for a dynamic design process.
                    Would it be possible to have an option for hiding the bottom reveal? And an option for hiding all the reveals all together?
                    (With some components the reveals are already part of the cutting component)
                    Triple Z-Fighting
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • W Offline
                      Whaat
                      Thanks for your input, halroach.
                      Yes, this is a known issue. We hope to be able to improve it in the future. The recommended workflow is to use the Double-cut explode locked groups option (right-click menu) after you have finalized the position of your door. Then, you can easily erase the un-wanted faces at the base of the door.
                        rv1974
                        I had to disable this tool because itit tends to connect to opposite facade of the bldng (I work wich thin walls). Some kind of depth value must be added.
                        • pbacotP Offline
                          What do you mean, you work with thin walls?
                          • jujuJ Offline
                            juju
                            rv1974 probably only models the outer shell, not wall thicknesses, etc.
                              rv1974
                              yep, a I need this tool locally (say for arcades), not as general treatment.
                              • utilerU Offline
                                utiler
                                Yes this has always been an issue with components cutting a solid at the edge... in this case a sill.
                                I've thought for ages that any any attempt at solving the puzzle of cutting through walls [ie solids] would be done with .... eh, solid tools. The subtract tool removes the section of wall to make the opening and when the opening is removed the subtract tool is reversed.
                                I am no programmer so wouldn't know if that can even be done but it just seems logical to me.
                                Just Curious...
                                • V Offline
                                  valerostudio
                                  10 YEARS I have been asking for this tool and its finally here!!! TAKE MY MONEY!!!!
                                  • W Offline
                                    Whaat
                                    UPDATE: Double-cut now offers a 15 day free trial.
                                    https://mindsightstudios.com/double-cut/
                                    • halroachH Offline
                                      halroach
                                      I think I found a bug which causes Sketchup to crash. I seem to have narrowed it down to double-cut, and specific dynamic components. It happened to me on 3 different PCs with windows 10 and Sketchup 2017.
                                      To recreate the crash:
                                      1. pull into the model attached dynamic component. It's a table from Sketchup's Dynamic Components Training collection.
                                      2. right click > save as > save it to the desktop
                                      3. Drag and drop the newly saved component into the same sketchup model where the original is in.
                                      4. scale the new component > Crash!
                                      Best if more people check to be sure it's this plugin and not something else...
                                      Cafe Table.skp
                                      • W Offline
                                        Whaat
                                        1. right click > save as > save it to the desktop
                                        2. Drag and drop the newly saved component into the same sketchup model where the original is in.
                                        3. scale the new component > Crash!
                                        Thank you very much for the report! We will check it out
                                          snowz
                                          Nice but Is this possible insert windows into the wall, not on the wall ?
                                          • pbacotP Offline
                                            If you mean to recess the window frame more in the wall, I think that really depends on how you make the component. In the video you see a simple cutting rectangle component makes a simple 3d hole. The geometry for the window frame that you create in the component could be anywhere in relation to the cutting plane.
                                            • 2 / 3
