    Help! You're my only hope...
    20 Posts 4 Posters 4.0k Views 4 Watching
    • marvins_dadM
      marvins_dad
      Here are a couple shots of the model to show what I am working with...
      My Gallery
      • srxS
        srx
        I am not an expert, but this looks like data transfer problem, which means it is connected with HDD, RAM and maybe GPU memory. So, I would check difference between two systems. It would be best to post your hardware profiles here. This is a good tool for that http://www.hwinfo.com/
        www.saurus.rs
        • marvins_dadM
          marvins_dad
          Running it now.
          My Gallery
          • marvins_dadM
            marvins_dad
            I finally got it open again and purged then "Fix Problems" and got this...
            My Gallery
            • marvins_dadM
              marvins_dad
              Unsure what all would be useful, here is the short report...
              Computer: DELL Precision WorkStation T5500
              CPU: Intel Xeon E5520 (Nehalem-EP, D0)
              2266 MHz (17.00x133.3) @ 2449 MHz (19.00x128.9)
              2266 MHz (17.00x133.3) @ 2490 MHz (19.00x131.1)
              Motherboard: DELL 0D883F
              Chipset: Intel 5520 (Tylersburg 36D) + ICH10R
              Memory: 12286 MBytes @ 515 MHz, 7.0-7-7-20
              Graphics: EVGA e-GeForce GTX Titan
              NVIDIA GeForce GTX TITAN, 6144 MB GDDR5 SDRAM
              Drive: Samsung SSD 850 EVO 250GB, 244.2 GB, Serial ATA 6Gb/s @ 3Gb/s
              Drive: WDC WD800HLFS-75G6U1, 78.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
              Drive: WDC WD15EADS-22P8B0, 1465.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
              Drive: PLDS DVD+/-RW DH-16AAS, DVD+R DL
              Drive: WDC WD20NMVW-11AV3S2, 1953.5 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
              Sound: Intel ICH10 - High Definition Audio Controller [A0]
              Sound: NVIDIA GK110 - High Definition Audio Controller
              Network: Broadcom BCM5761 NetXtreme Gigabit Ethernet PCIe
              OS: Microsoft Windows 7 Professional (x64) Build 7601
              My Gallery
              • marvins_dadM
                marvins_dad
                And...it crashed again...damnit!
                Will see if I can get an old version to work while trying to bring that one back up.
                I had purged out all the unused Skatter setups and purged and fixed the file...still bugsplatted.
                My Gallery
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Check my answer : http://getskatter.com/support/topic/deleting-a-skatter-setup/#post-782
                  • marvins_dadM
                    marvins_dad
                    Thanks! Was able to rule one plug-in out of the problem that I am having.
                    My Gallery
                    • srxS
                      srx
                      Wow!
                      1 The hardware is more than enough...
                      2 Will have to remove all the plugins, than add them one by one to find the cause..Just to remind you 😄
                      www.saurus.rs
                      • marvins_dadM
                        marvins_dad
                        The issue popped up again recently.
                        Found it to be a Skatter issue after all.
                        I could pull it up on a machine without Skatter plug in installed with ease...would hang forever on my machines that had Skatter installed.
                        Went in and purged/deleted the Skatter reference on the non-Skatter machine....saved then opened in my Skatter machine (no problem) - then redefined the Skatter perimeters...and works like a charm.
                        Unsure what the hang up is and once redefined the problem hasn't occurred again.
                        My Gallery
