    Help! You're my only hope...
    20 Posts 4 Posters 4.1k Views 4 Watching
    • marvins_dadM
      marvins_dad
      Finally Opened! 1 hour later!
      5,573,180K w/ 0% CPU...this sounds high in comparison.
      My Gallery
      • marvins_dadM
        marvins_dad
        Then I hit Render for Thea Render and it Bugsplatted... 😞
        Not a good couple days in SketchUp land for me.
        My Gallery
        • marvins_dadM
          marvins_dad
          Here are a couple shots of the model to show what I am working with...
          My Gallery
          • srxS
            srx
            I am not an expert, but this looks like data transfer problem, which means it is connected with HDD, RAM and maybe GPU memory. So, I would check difference between two systems. It would be best to post your hardware profiles here. This is a good tool for that http://www.hwinfo.com/
            www.saurus.rs
            • marvins_dadM
              marvins_dad
              Running it now.
              My Gallery
              • marvins_dadM
                marvins_dad
                I finally got it open again and purged then "Fix Problems" and got this...
                My Gallery
                • marvins_dadM
                  marvins_dad
                  Unsure what all would be useful, here is the short report...
                  Computer: DELL Precision WorkStation T5500
                  CPU: Intel Xeon E5520 (Nehalem-EP, D0)
                  2266 MHz (17.00x133.3) @ 2449 MHz (19.00x128.9)
                  2266 MHz (17.00x133.3) @ 2490 MHz (19.00x131.1)
                  Motherboard: DELL 0D883F
                  Chipset: Intel 5520 (Tylersburg 36D) + ICH10R
                  Memory: 12286 MBytes @ 515 MHz, 7.0-7-7-20
                  Graphics: EVGA e-GeForce GTX Titan
                  NVIDIA GeForce GTX TITAN, 6144 MB GDDR5 SDRAM
                  Drive: Samsung SSD 850 EVO 250GB, 244.2 GB, Serial ATA 6Gb/s @ 3Gb/s
                  Drive: WDC WD800HLFS-75G6U1, 78.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
                  Drive: WDC WD15EADS-22P8B0, 1465.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
                  Drive: PLDS DVD+/-RW DH-16AAS, DVD+R DL
                  Drive: WDC WD20NMVW-11AV3S2, 1953.5 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
                  Sound: Intel ICH10 - High Definition Audio Controller [A0]
                  Sound: NVIDIA GK110 - High Definition Audio Controller
                  Network: Broadcom BCM5761 NetXtreme Gigabit Ethernet PCIe
                  OS: Microsoft Windows 7 Professional (x64) Build 7601
                  My Gallery
                  • marvins_dadM
                    marvins_dad
                    And...it crashed again...damnit!
                    Will see if I can get an old version to work while trying to bring that one back up.
                    I had purged out all the unused Skatter setups and purged and fixed the file...still bugsplatted.
                    My Gallery
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Check my answer : http://getskatter.com/support/topic/deleting-a-skatter-setup/#post-782
                      • marvins_dadM
                        marvins_dad
                        Thanks! Was able to rule one plug-in out of the problem that I am having.
                        My Gallery
                        • srxS
                          srx
                          Wow!
                          1 The hardware is more than enough...
                          2 Will have to remove all the plugins, than add them one by one to find the cause..Just to remind you 😄
                          www.saurus.rs
                          • marvins_dadM
                            marvins_dad
                            The issue popped up again recently.
                            Found it to be a Skatter issue after all.
                            I could pull it up on a machine without Skatter plug in installed with ease...would hang forever on my machines that had Skatter installed.
                            Went in and purged/deleted the Skatter reference on the non-Skatter machine....saved then opened in my Skatter machine (no problem) - then redefined the Skatter perimeters...and works like a charm.
                            Unsure what the hang up is and once redefined the problem hasn't occurred again.
                            My Gallery
