    Help! You're my only hope...
    20 Posts 4 Posters 3.8k Views 4 Watching
    • marvins_dadM Offline
      marvins_dad
      I'm beginning to think it is the Skatter plugin - I have 7 skatter/renderings on my list. Does anyone know how to kill them, I did try selecting and hitting the minus sign, but they are still showing up.
      Any thoughts on if that would cause a lag in opening or loading?
      I'll run off and search to see if I can find a thread on Skatter and the ins and outs...
      My Gallery
      • jujuJ Offline
        juju
        If you suspect Skatter, then it's probably best to contact the authors for assistance.
          marvins_dad
          I've posted over at Skatter...but I'm not 100% sure that that add-on is causing the issue. I suspect it because the file seems to load on a machine that doesn't have Thea or Skatter installed.
          Thea has never given me an issue in the past with the Not Responding on startup.
          Is there a way to see what SketchUp is hanging or loading when it sits and spins on startup and gives the (Not Responding) designation.
          I'm back to waiting on it to load. I left the file opening last night and remoted in to check on it and it finally had loaded...but this morning after looking at the Skatter setups it finally Bug Splatted on me.
          Processes show that Memory (3,841,--- K) and CPU of 13...with Memory varying slightly...so it looks like it isn't locked, just working on something in the background.
          Status under the Aplications Tab (Windows Task Manager) does show Not Responding...
          My Gallery
            marvins_dad
            It's now climbed to 6,062,---k Memory usage and flickering between 12-13% CPU usage.
            Still hasn't finished opening...or it is locked up and I just don't want to admit it.
            My Gallery
              marvins_dad
              On the semi-virgin machine (just loaded Thea and the trial for Skatter)...the same file that is still trying to load on my machine - loads in seconds and has only gotten up to 589,292k memory usage with 0% CPU currently (because it's not loading I would guess).
              What oddness....anyone have any ideas what is going on?
              My Gallery
                marvins_dad
                Finally Opened! 1 hour later!
                5,573,180K w/ 0% CPU...this sounds high in comparison.
                My Gallery
                  marvins_dad
                  Then I hit Render for Thea Render and it Bugsplatted... 😞
                  Not a good couple days in SketchUp land for me.
                  My Gallery
                    marvins_dad
                    Here are a couple shots of the model to show what I am working with...
                    My Gallery
                    • srxS Offline
                      srx
                      I am not an expert, but this looks like data transfer problem, which means it is connected with HDD, RAM and maybe GPU memory. So, I would check difference between two systems. It would be best to post your hardware profiles here. This is a good tool for that http://www.hwinfo.com/
                      www.saurus.rs
                        marvins_dad
                        Running it now.
                        My Gallery
                          marvins_dad
                          I finally got it open again and purged then "Fix Problems" and got this...
                          My Gallery
                            marvins_dad
                            Unsure what all would be useful, here is the short report...
                            Computer: DELL Precision WorkStation T5500
                            CPU: Intel Xeon E5520 (Nehalem-EP, D0)
                            2266 MHz (17.00x133.3) @ 2449 MHz (19.00x128.9)
                            2266 MHz (17.00x133.3) @ 2490 MHz (19.00x131.1)
                            Motherboard: DELL 0D883F
                            Chipset: Intel 5520 (Tylersburg 36D) + ICH10R
                            Memory: 12286 MBytes @ 515 MHz, 7.0-7-7-20
                            Graphics: EVGA e-GeForce GTX Titan
                            NVIDIA GeForce GTX TITAN, 6144 MB GDDR5 SDRAM
                            Drive: Samsung SSD 850 EVO 250GB, 244.2 GB, Serial ATA 6Gb/s @ 3Gb/s
                            Drive: WDC WD800HLFS-75G6U1, 78.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
                            Drive: WDC WD15EADS-22P8B0, 1465.1 GB, Serial ATA 3Gb/s @ 1.5Gb/s
                            Drive: PLDS DVD+/-RW DH-16AAS, DVD+R DL
                            Drive: WDC WD20NMVW-11AV3S2, 1953.5 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
                            Sound: Intel ICH10 - High Definition Audio Controller [A0]
                            Sound: NVIDIA GK110 - High Definition Audio Controller
                            Network: Broadcom BCM5761 NetXtreme Gigabit Ethernet PCIe
                            OS: Microsoft Windows 7 Professional (x64) Build 7601
                            My Gallery
                              marvins_dad
                              And...it crashed again...damnit!
                              Will see if I can get an old version to work while trying to bring that one back up.
                              I had purged out all the unused Skatter setups and purged and fixed the file...still bugsplatted.
                              My Gallery
                              • jiminy-billy-bobJ Offline
                                jiminy-billy-bob
                                Check my answer : http://getskatter.com/support/topic/deleting-a-skatter-setup/#post-782
                                  marvins_dad
                                  Thanks! Was able to rule one plug-in out of the problem that I am having.
                                  My Gallery
                                  • srxS Offline
                                    srx
                                    Wow!
                                    1 The hardware is more than enough...
                                    2 Will have to remove all the plugins, than add them one by one to find the cause..Just to remind you 😄
                                    www.saurus.rs
                                      marvins_dad
                                      The issue popped up again recently.
                                      Found it to be a Skatter issue after all.
                                      I could pull it up on a machine without Skatter plug in installed with ease...would hang forever on my machines that had Skatter installed.
                                      Went in and purged/deleted the Skatter reference on the non-Skatter machine....saved then opened in my Skatter machine (no problem) - then redefined the Skatter perimeters...and works like a charm.
                                      Unsure what the hang up is and once redefined the problem hasn't occurred again.
                                      My Gallery
