    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      Version 1.1.0 - 04.14.2017
      • Added polygon outline tool for slab-on-grade and slab.
      • Enabled perimeter rebar, anchor bolts, and slab reinforcement for (polygon) slab-on-grade foundations.
      • Enabled slab reinforcement for (polygon) slabs.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • facerF
        facer
        Medeek,
        Thank you for the Foundation Plugin update "Easter Egg", enjoy your Easter break πŸ˜„
        • medeekM
          medeek
          Using the rectangular floor primitives I was able to manually create the floor on the previous foundation in about 30 minutes:
          http://design.medeek.com/resources/images/foundation_su39_800.jpg
          If I create the polygon floor tool I will be able to accomplish the same thing in under 10 seconds. The polygon floor tool in the truss plugin is next...
          design.medeek.com
          • medeekM
            medeek
            Polygon stemwall foundation with post and beam interior supports.
            Note that the smaller segments of the interior footing assemblies were created by copying the larger assembly and then trimming it to size with the Trim tool in the truss plugin.
            design.medeek.com
            • medeekM
              medeek
              Version 1.1.1 - 04.23.2017
              • Added polygon outline tool for stemwall foundation.
              • Enabled perimeter rebar, anchor bolts, vents, and internal footings for (polygon) stemwall foundations.
              http://design.medeek.com/resources/images/foundation_su37_800.jpg
              http://design.medeek.com/resources/images/foundation_su38_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              The next improvement would be a web_dialog input so that more than one internal footing can be specified at a time.
              design.medeek.com
              • medeekM
                medeek
                I just realized that there may be a few items I missed in the last update with respect to the polygon stemwall tool and metric templates. I will do some more bug testing tonight to verify that all of the issues are addressed. I usually do all of my own work in standard US imperial units so sometimes in my rush to get a release out I forget to check all of the options and possible permutations using a metric template. I apologize for any inconvenience this may have caused. If you do notice an error please feel free to post here or notify me directly. Please give as much specifics as possible, that always helps.
                design.medeek.com
                • medeekM
                  medeek
                  The trim tool in the Truss Plugin comes in quite handy when dealing with more complex foundation geometry:
                  https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=a2e9a8ec-3df7-44e3-a89e-7011cdd79d3b
                  For this foundation I used the stemwall (rectangle and polygon) function and the slab (polygon) function. I had to trim the garage stemwall and also manually create the smaller interior post/beam assemblies. I also adjusted the position of some of anchor bolts once I cut the doors into the garage stemwall.
                  View model here:
                  3D Warehouse
                  Throwing a roof onto this foundation is fairly straightforward:
                  https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=0893714a-0a63-41f4-acc8-6efc2a837efc
                  View model here:
                  3D Warehouse
                  design.medeek.com
                  • medeekM
                    medeek
                    Recently I've received a number of requests for concrete columns to be added to the foundation plugin:
                    https://courses.cit.cornell.edu/arch264/calculators/example7.5/01.jpg
                    I'm still trying to figure out how to best add a concrete column module, I think it could gain some serious traction. This would cater more to the industrial rather than the residential side.
                    I'll use ASDIP Concrete Software as a guide in establishing the various options to include:
                    https://media.licdn.com/mpr/mpr/shrinknp_800_800/AAEAAQAAAAAAAAgkAAAAJDM0YTFiNDVkLTc2MjMtNDFkMy1hZjQ2LTAwOGE2NjU1NWRlYQ.png
                    design.medeek.com
                    • jujuJ
                      juju
                      This is a very interesting development. However, here is something to think about...
                      You need to consider if you want to expose yourself (or the persons using the extension) to possible legal action. Soil and load conditions differ from place to place and instance to instance. This would require the input a structural engineer to certify the correct steel choice and configuration. This would then mean that the steel reinforcing in the extension is really reduced to "for illustrative purposes only".
                      Which begs the question, just how much effort is thus justified with steel reinforcing options? Do you have a section for regular (non structural engineer) users with a "for illustrative purposes" type of output and a separate section (with all the "bells and whistles") you can only access with the completion / agreement of an indemnity?
                      • facerF
                        facer
                        It looks like the "engineer" in medeek has taken over!
                        I agree with "juju's" thread of thinking.
                        The depth of detail suggested may be useful in medeek's engineering practice but have less value
                        for I guess the majority of users and prospective users.
                        My suggestion would be these proposed changes are at the edge of "the bell curve".
                        It may be more prudent to stay within the "bulk" of users and prospective users requirements.
                        Food for thought! πŸ˜„
                        • medeekM
                          medeek
                          A couple of things:
                          1.) Based on a conversation in the other forum I will be adding a global setting that allows one to specify the number of segments in the circular arcs that make up the rebar/mesh. This will allow a more lightweight model. The anchor bolts are pre-modeled and then dropped into the model as components. I will need to create some light weight versions of them for this purpose.
                          2.) So far this foundation plugin has been mostly geared toward the residential designer/architect. Concrete columns, beams, and more complicated footings and retaining walls are typically more the area of the commercial and industrial market.
                          It might make more sense to create a separate plugin that deals specifically with these reinforced concrete elements (Medeek RC). My engineering side wants to also integrate the calcs inside the plugin as well, so yes that element of me comes out sooner or later.
                          design.medeek.com
                          • pbacotP
                            Great work. I'd say we use a lot of conc. piers, columns and retaining walls in residential work, probably more than some, due to the soils and topography. Also because the buildings might be larger and less conventional, but still wood framed.
                            • medeekM
                              medeek
                              Version 1.1.2 - 05.06.2017
                              • Added "Circle Segments" option within the global settings, rebar and mesh polygon counts can now be controlled.
                              http://design.medeek.com/resources/images/foundation_su42_800.jpg
                              In this example I set the segment number to "5".
                              The global setting circle segment number will default to 24.
                              design.medeek.com
                              • medeekM
                                medeek
                                The foundation of the that goofy donut house:
                                http://design.medeek.com/resources/images/foundation_su41_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Some common configurations of concrete columns:
                                  http://design.medeek.com/resources/images/foundation_su43_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    A slightly darker version with shading pops out a little more:
                                    http://design.medeek.com/resources/images/foundation_su44_800.jpg
                                    design.medeek.com
                                      db11
                                      In our Passivhaus builds, this is the preferred foundation type for several reasons.
                                      I think you would be surprised at the EPS insulation thickness under-slab... up to 14". Of course, this varies considerably with different climate zones. (We are in Quebec with winters where -40Β° is not unexpected)
                                      There are modular slab insulation systems for FPSF. Iso-Slab is a Quebec-based one: http://www.iso-slab.com. Their web-site has technical info on these systems that may be of interest to you.
                                      • medeekM
                                        medeek
                                        I've had a request for adding the option of insulation around a slab on grade, in short a frost protected shallow foundation (FPSF).
                                        This should not be too hard to add in. There are a number of resources online I will study to come up with the most standard configuration as possible.
                                        Are there any particular things anyone would like to see with regards to FPSF insulation.
                                        The typical installation per the 2015 IRC:
                                        The NAHB has an upated publication at this link:
                                        http://liteform.com/wp-content/uploads/2017/04/FPSF-Guide-Revised.pdf
                                        XPS vs. EPS? Not that this will affect the plugin but I am curious which is preferred by those who commonly install these types of systems.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          An FPSF with 2" foam insulation along the wall and vertically. 2.5" foam insulation at the corners with the following horizontal dimensions:
                                          A = 12"
                                          B = 24"
                                          C = 40"
                                          http://design.medeek.com/resources/images/foundation_su45_800.jpg
                                          The rectangle foundation is easy, the polygon shaped foundation will be more challenging.
                                          View model here:
                                          3D Warehouse
                                          One thing to note is that if dimensions A or B exceed 24" then some form of protection for the horizontal insulation is required (ie. conc. slab, pavement, PT plywood).
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            An irregular shaped FPSF, note the 135 deg. corners. Once this angle becomes greater than 135 degrees I would probably just treat it the same as a straight wall.
                                            http://design.medeek.com/resources/images/foundation_su46_800.jpg
                                            View model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 7 / 23
