    Foundation Plugin
    442 Posts 15 Posters 448.3k Views 15 Watching
    • medeekM Offline
      medeek
      I just realized that there may be a few items I missed in the last update with respect to the polygon stemwall tool and metric templates. I will do some more bug testing tonight to verify that all of the issues are addressed. I usually do all of my own work in standard US imperial units so sometimes in my rush to get a release out I forget to check all of the options and possible permutations using a metric template. I apologize for any inconvenience this may have caused. If you do notice an error please feel free to post here or notify me directly. Please give as much specifics as possible, that always helps.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The trim tool in the Truss Plugin comes in quite handy when dealing with more complex foundation geometry:
        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=a2e9a8ec-3df7-44e3-a89e-7011cdd79d3b
        For this foundation I used the stemwall (rectangle and polygon) function and the slab (polygon) function. I had to trim the garage stemwall and also manually create the smaller interior post/beam assemblies. I also adjusted the position of some of anchor bolts once I cut the doors into the garage stemwall.
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        Throwing a roof onto this foundation is fairly straightforward:
        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=0893714a-0a63-41f4-acc8-6efc2a837efc
        View model here:
        3D Warehouse
        design.medeek.com
        • medeekM Offline
          medeek
          Recently I've received a number of requests for concrete columns to be added to the foundation plugin:
          https://courses.cit.cornell.edu/arch264/calculators/example7.5/01.jpg
          I'm still trying to figure out how to best add a concrete column module, I think it could gain some serious traction. This would cater more to the industrial rather than the residential side.
          I'll use ASDIP Concrete Software as a guide in establishing the various options to include:
          https://media.licdn.com/mpr/mpr/shrinknp_800_800/AAEAAQAAAAAAAAgkAAAAJDM0YTFiNDVkLTc2MjMtNDFkMy1hZjQ2LTAwOGE2NjU1NWRlYQ.png
          design.medeek.com
          • jujuJ Offline
            juju
            This is a very interesting development. However, here is something to think about...
            You need to consider if you want to expose yourself (or the persons using the extension) to possible legal action. Soil and load conditions differ from place to place and instance to instance. This would require the input a structural engineer to certify the correct steel choice and configuration. This would then mean that the steel reinforcing in the extension is really reduced to "for illustrative purposes only".
            Which begs the question, just how much effort is thus justified with steel reinforcing options? Do you have a section for regular (non structural engineer) users with a "for illustrative purposes" type of output and a separate section (with all the "bells and whistles") you can only access with the completion / agreement of an indemnity?
            • facerF Offline
              facer
              It looks like the "engineer" in medeek has taken over!
              I agree with "juju's" thread of thinking.
              The depth of detail suggested may be useful in medeek's engineering practice but have less value
              for I guess the majority of users and prospective users.
              My suggestion would be these proposed changes are at the edge of "the bell curve".
              It may be more prudent to stay within the "bulk" of users and prospective users requirements.
              Food for thought! πŸ˜„
              • medeekM Offline
                medeek
                A couple of things:
                1.) Based on a conversation in the other forum I will be adding a global setting that allows one to specify the number of segments in the circular arcs that make up the rebar/mesh. This will allow a more lightweight model. The anchor bolts are pre-modeled and then dropped into the model as components. I will need to create some light weight versions of them for this purpose.
                2.) So far this foundation plugin has been mostly geared toward the residential designer/architect. Concrete columns, beams, and more complicated footings and retaining walls are typically more the area of the commercial and industrial market.
                It might make more sense to create a separate plugin that deals specifically with these reinforced concrete elements (Medeek RC). My engineering side wants to also integrate the calcs inside the plugin as well, so yes that element of me comes out sooner or later.
                design.medeek.com
                • pbacotP Offline
                  Great work. I'd say we use a lot of conc. piers, columns and retaining walls in residential work, probably more than some, due to the soils and topography. Also because the buildings might be larger and less conventional, but still wood framed.
                  • medeekM Offline
                    medeek
                    Version 1.1.2 - 05.06.2017
                    • Added "Circle Segments" option within the global settings, rebar and mesh polygon counts can now be controlled.
                    http://design.medeek.com/resources/images/foundation_su42_800.jpg
                    In this example I set the segment number to "5".
                    The global setting circle segment number will default to 24.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      The foundation of the that goofy donut house:
                      http://design.medeek.com/resources/images/foundation_su41_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Some common configurations of concrete columns:
                        http://design.medeek.com/resources/images/foundation_su43_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          A slightly darker version with shading pops out a little more:
                          http://design.medeek.com/resources/images/foundation_su44_800.jpg
                          design.medeek.com
                            db11
                            In our Passivhaus builds, this is the preferred foundation type for several reasons.
                            I think you would be surprised at the EPS insulation thickness under-slab... up to 14". Of course, this varies considerably with different climate zones. (We are in Quebec with winters where -40Β° is not unexpected)
                            There are modular slab insulation systems for FPSF. Iso-Slab is a Quebec-based one: http://www.iso-slab.com. Their web-site has technical info on these systems that may be of interest to you.
                            • medeekM Offline
                              medeek
                              I've had a request for adding the option of insulation around a slab on grade, in short a frost protected shallow foundation (FPSF).
                              This should not be too hard to add in. There are a number of resources online I will study to come up with the most standard configuration as possible.
                              Are there any particular things anyone would like to see with regards to FPSF insulation.
                              The typical installation per the 2015 IRC:
                              The NAHB has an upated publication at this link:
                              403 Forbidden
                              (liteform.com)
                              XPS vs. EPS? Not that this will affect the plugin but I am curious which is preferred by those who commonly install these types of systems.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                An FPSF with 2" foam insulation along the wall and vertically. 2.5" foam insulation at the corners with the following horizontal dimensions:
                                A = 12"
                                B = 24"
                                C = 40"
                                http://design.medeek.com/resources/images/foundation_su45_800.jpg
                                The rectangle foundation is easy, the polygon shaped foundation will be more challenging.
                                View model here:
                                3D Warehouse
                                One thing to note is that if dimensions A or B exceed 24" then some form of protection for the horizontal insulation is required (ie. conc. slab, pavement, PT plywood).
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  An irregular shaped FPSF, note the 135 deg. corners. Once this angle becomes greater than 135 degrees I would probably just treat it the same as a straight wall.
                                  http://design.medeek.com/resources/images/foundation_su46_800.jpg
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.1.3 - 06.03.2017
                                    • Added "FPSF" option to rectangular slab-on-grade foundations.
                                    • Added "FPSF" option to rectangular stemwall foundations.
                                    • Added an insulation layer in the global settings under the "Layers" tab.
                                    http://design.medeek.com/resources/images/foundation_su47_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      http://design.medeek.com/resources/images/foundation_su48_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Working on the square/rectangle spread footing tool:
                                        Post Footing
                                        I will start with wood posts as an option with the following sub-options for the wood post:
                                        Post Size: 4x4, 4x6, 6x6, 6x8, 8x8
                                        Post Height (in.)
                                        Post Base: None, ABA, ABU, ABW, CBSQ
                                        Post Cap: None, CCQ, ECCQ
                                        Post Rotation: 0, 90, 180, 270
                                        I also plan on having the option for steel posts with the following sub-options:
                                        Post Size: HSS4x4x1/2, HSS4x4x3/8, HSS 4x4x1/4, HSS3x3x3/8 etc... (round and square tube)
                                        Post Height (in.)
                                        Base Plate Size (in.) - square shape L x L
                                        Base Plate Thickness (in.)
                                        Base Plate Hole Dia. (in.): 1/4, 3/8, 1/2, 5/8 (4 bolts per baseplate)
                                        Vert. Offset (in.) - for non-shrink grout
                                        Post Cap: Not sure what to do with this yet.
                                        http://design.medeek.com/resources/images/foundation_su49_800.jpg
                                        http://design.medeek.com/resources/images/foundation_su50_800.jpg
                                        I've been contemplating using the Simpson Strong-Tie post caps and bases as provide in the warehouse but I'm worried that the polygon count is too high. I may have to generate my own dumbed down versions.
                                        http://design.medeek.com/resources/images/foundation_su51_800.jpg
                                        My 13 year old daughter asked, "What is this for? What good is it?". I replied, "It is good for all sorts of things, just like a Thneed." Then I proceeded to discuss decks, porches, carports etc...
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Added "FPSF" option to polygon slab-on-grade foundations:
                                          http://design.medeek.com/resources/images/foundation_su52_800.jpg
                                          design.medeek.com
                                          • jujuJ Offline
                                            juju
                                            Can you do that with the option of putting it (as a vertical component only) on the inside of the foundation wall? It may be of use in climates that isn't as cold and you have the option of putting it either inside or outside of the foundation plinth wall.
                                            • 22
                                            • 23
                                            • 7 / 23
