    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      The polygon tool for the slab-on-grade foundations is nearing completion. I've got the concrete, perimeter rebar, internal footings and even anchor bolts all working.
      http://design.medeek.com/resources/images/foundation_su35_800.jpg
      The only item still pending is the slab reinforcement (mesh/bar). I've been contemplating devising my own boolean subtraction tool.
      I've even managed to create a fillet tool based on TIG's 2D tools that properly applies the correct bend radius to the perimeter rebar.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        Please make it so the reinforcing and anchor bolts need to be toggled on/off separately.
        • medeekM Offline
          medeek
          This is already the case. Anchor bolts, perimeter rebar and slab rebar/mesh are all independent of each other.
          The garage curb is also working well.
          I still need to do further testing with the metric templates.
          design.medeek.com
          • medeekM Offline
            medeek
            I think I've got the slab reinforcement working now. I haven't tested it enough to determine if its really robust enough to release another update but I'll keep testing.
            http://design.medeek.com/resources/images/foundation_su36_800.jpg
            I owe Sdmitch big time for this one. I've integrated his rebar trim function into the plugin to create a new module that trims the slab rebar or mesh. I am still trying to figure out exactly how the magic is done but most of it is over my head.
            View model here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            A mesh reinforced slab though can get quite heavy with the polygon count so it may only have limited usefulness.
            design.medeek.com
            • medeekM Offline
              medeek
              I've tested it some more this morning and so far I have been unable to break it, πŸ˜„.
              In the next couple of days I will update the slab feature on par with the slab on grade feature so that polygon shaped foundations are 100%.
              Then I will turn my attention to the stemwall foundation and fully implement the polygon layout tool in that as well. I now have all the widgets in my toolbelt to make this happen.
              Once I get those updates done I will release the updated version.
              At that point I may raise the price to $15.00, since I will now have added more functionality.
              The ability to trim rebar is a much bigger prize than just rebar. This will now allow me to do the same thing for floor joists (polygon layout) in the truss plugin.
              design.medeek.com
              • pbacotP Offline
                Wonderful work! For my current uses, which is not a full house modeling, the foundation tool is probably the best because I do like to model at least the basics of a foundation for my exterior house models, and often find this is often the most helpful part to study in 3d.
                • medeekM Offline
                  medeek
                  I haven't fully compiled a TODO List for this plugin yet but there are still a number of items that need to be addressed.
                  • A hole cutting tool that removes the concrete and the rebar and any anchor bolts in the way.
                  • Square and Rectangular Footings for point loads
                  • Strip Footings
                  • A line tool for the stemwall module
                  • Retaining Walls with Engineering
                  • Ability to step foundation walls
                  • Webdialog input for SOG and Stemwall so that interior footings can be configured with ease.
                  Let me know if there is anything you would like to add to this list.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.1.0 - 04.14.2017
                    • Added polygon outline tool for slab-on-grade and slab.
                    • Enabled perimeter rebar, anchor bolts, and slab reinforcement for (polygon) slab-on-grade foundations.
                    • Enabled slab reinforcement for (polygon) slabs.
                    design.medeek.com
                    • facerF Offline
                      facer
                      Medeek,
                      Thank you for the Foundation Plugin update "Easter Egg", enjoy your Easter break πŸ˜„
                      • medeekM Offline
                        medeek
                        Using the rectangular floor primitives I was able to manually create the floor on the previous foundation in about 30 minutes:
                        http://design.medeek.com/resources/images/foundation_su39_800.jpg
                        If I create the polygon floor tool I will be able to accomplish the same thing in under 10 seconds. The polygon floor tool in the truss plugin is next...
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Polygon stemwall foundation with post and beam interior supports.
                          Note that the smaller segments of the interior footing assemblies were created by copying the larger assembly and then trimming it to size with the Trim tool in the truss plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.1.1 - 04.23.2017
                            • Added polygon outline tool for stemwall foundation.
                            • Enabled perimeter rebar, anchor bolts, vents, and internal footings for (polygon) stemwall foundations.
                            http://design.medeek.com/resources/images/foundation_su37_800.jpg
                            http://design.medeek.com/resources/images/foundation_su38_800.jpg
                            View model here:
                            3D Warehouse
                            The next improvement would be a web_dialog input so that more than one internal footing can be specified at a time.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I just realized that there may be a few items I missed in the last update with respect to the polygon stemwall tool and metric templates. I will do some more bug testing tonight to verify that all of the issues are addressed. I usually do all of my own work in standard US imperial units so sometimes in my rush to get a release out I forget to check all of the options and possible permutations using a metric template. I apologize for any inconvenience this may have caused. If you do notice an error please feel free to post here or notify me directly. Please give as much specifics as possible, that always helps.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                The trim tool in the Truss Plugin comes in quite handy when dealing with more complex foundation geometry:
                                https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=a2e9a8ec-3df7-44e3-a89e-7011cdd79d3b
                                For this foundation I used the stemwall (rectangle and polygon) function and the slab (polygon) function. I had to trim the garage stemwall and also manually create the smaller interior post/beam assemblies. I also adjusted the position of some of anchor bolts once I cut the doors into the garage stemwall.
                                View model here:
                                3D Warehouse
                                Throwing a roof onto this foundation is fairly straightforward:
                                https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=0893714a-0a63-41f4-acc8-6efc2a837efc
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Recently I've received a number of requests for concrete columns to be added to the foundation plugin:
                                  https://courses.cit.cornell.edu/arch264/calculators/example7.5/01.jpg
                                  I'm still trying to figure out how to best add a concrete column module, I think it could gain some serious traction. This would cater more to the industrial rather than the residential side.
                                  I'll use ASDIP Concrete Software as a guide in establishing the various options to include:
                                  https://media.licdn.com/mpr/mpr/shrinknp_800_800/AAEAAQAAAAAAAAgkAAAAJDM0YTFiNDVkLTc2MjMtNDFkMy1hZjQ2LTAwOGE2NjU1NWRlYQ.png
                                  design.medeek.com
                                  • jujuJ Offline
                                    juju
                                    This is a very interesting development. However, here is something to think about...
                                    You need to consider if you want to expose yourself (or the persons using the extension) to possible legal action. Soil and load conditions differ from place to place and instance to instance. This would require the input a structural engineer to certify the correct steel choice and configuration. This would then mean that the steel reinforcing in the extension is really reduced to "for illustrative purposes only".
                                    Which begs the question, just how much effort is thus justified with steel reinforcing options? Do you have a section for regular (non structural engineer) users with a "for illustrative purposes" type of output and a separate section (with all the "bells and whistles") you can only access with the completion / agreement of an indemnity?
                                    • facerF Offline
                                      facer
                                      It looks like the "engineer" in medeek has taken over!
                                      I agree with "juju's" thread of thinking.
                                      The depth of detail suggested may be useful in medeek's engineering practice but have less value
                                      for I guess the majority of users and prospective users.
                                      My suggestion would be these proposed changes are at the edge of "the bell curve".
                                      It may be more prudent to stay within the "bulk" of users and prospective users requirements.
                                      Food for thought! πŸ˜„
                                      • medeekM Offline
                                        medeek
                                        A couple of things:
                                        1.) Based on a conversation in the other forum I will be adding a global setting that allows one to specify the number of segments in the circular arcs that make up the rebar/mesh. This will allow a more lightweight model. The anchor bolts are pre-modeled and then dropped into the model as components. I will need to create some light weight versions of them for this purpose.
                                        2.) So far this foundation plugin has been mostly geared toward the residential designer/architect. Concrete columns, beams, and more complicated footings and retaining walls are typically more the area of the commercial and industrial market.
                                        It might make more sense to create a separate plugin that deals specifically with these reinforced concrete elements (Medeek RC). My engineering side wants to also integrate the calcs inside the plugin as well, so yes that element of me comes out sooner or later.
                                        design.medeek.com
                                        • pbacotP Offline
                                          Great work. I'd say we use a lot of conc. piers, columns and retaining walls in residential work, probably more than some, due to the soils and topography. Also because the buildings might be larger and less conventional, but still wood framed.
                                          • medeekM Offline
                                            medeek
                                            Version 1.1.2 - 05.06.2017
                                            • Added "Circle Segments" option within the global settings, rebar and mesh polygon counts can now be controlled.
                                            http://design.medeek.com/resources/images/foundation_su42_800.jpg
                                            In this example I set the segment number to "5".
                                            The global setting circle segment number will default to 24.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 6 / 23
