    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      Recently I've received a number of requests for concrete columns to be added to the foundation plugin:
      https://courses.cit.cornell.edu/arch264/calculators/example7.5/01.jpg
      I'm still trying to figure out how to best add a concrete column module, I think it could gain some serious traction. This would cater more to the industrial rather than the residential side.
      I'll use ASDIP Concrete Software as a guide in establishing the various options to include:
      https://media.licdn.com/mpr/mpr/shrinknp_800_800/AAEAAQAAAAAAAAgkAAAAJDM0YTFiNDVkLTc2MjMtNDFkMy1hZjQ2LTAwOGE2NjU1NWRlYQ.png
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ
        juju
        This is a very interesting development. However, here is something to think about...
        You need to consider if you want to expose yourself (or the persons using the extension) to possible legal action. Soil and load conditions differ from place to place and instance to instance. This would require the input a structural engineer to certify the correct steel choice and configuration. This would then mean that the steel reinforcing in the extension is really reduced to "for illustrative purposes only".
        Which begs the question, just how much effort is thus justified with steel reinforcing options? Do you have a section for regular (non structural engineer) users with a "for illustrative purposes" type of output and a separate section (with all the "bells and whistles") you can only access with the completion / agreement of an indemnity?
        • facerF
          facer
          It looks like the "engineer" in medeek has taken over!
          I agree with "juju's" thread of thinking.
          The depth of detail suggested may be useful in medeek's engineering practice but have less value
          for I guess the majority of users and prospective users.
          My suggestion would be these proposed changes are at the edge of "the bell curve".
          It may be more prudent to stay within the "bulk" of users and prospective users requirements.
          Food for thought! ๐Ÿ˜„
          • medeekM
            medeek
            A couple of things:
            1.) Based on a conversation in the other forum I will be adding a global setting that allows one to specify the number of segments in the circular arcs that make up the rebar/mesh. This will allow a more lightweight model. The anchor bolts are pre-modeled and then dropped into the model as components. I will need to create some light weight versions of them for this purpose.
            2.) So far this foundation plugin has been mostly geared toward the residential designer/architect. Concrete columns, beams, and more complicated footings and retaining walls are typically more the area of the commercial and industrial market.
            It might make more sense to create a separate plugin that deals specifically with these reinforced concrete elements (Medeek RC). My engineering side wants to also integrate the calcs inside the plugin as well, so yes that element of me comes out sooner or later.
            design.medeek.com
            • pbacotP
              Great work. I'd say we use a lot of conc. piers, columns and retaining walls in residential work, probably more than some, due to the soils and topography. Also because the buildings might be larger and less conventional, but still wood framed.
              • medeekM
                medeek
                Version 1.1.2 - 05.06.2017
                • Added "Circle Segments" option within the global settings, rebar and mesh polygon counts can now be controlled.
                http://design.medeek.com/resources/images/foundation_su42_800.jpg
                In this example I set the segment number to "5".
                The global setting circle segment number will default to 24.
                design.medeek.com
                • medeekM
                  medeek
                  The foundation of the that goofy donut house:
                  http://design.medeek.com/resources/images/foundation_su41_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Some common configurations of concrete columns:
                    http://design.medeek.com/resources/images/foundation_su43_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      A slightly darker version with shading pops out a little more:
                      http://design.medeek.com/resources/images/foundation_su44_800.jpg
                      design.medeek.com
                        db11
                        In our Passivhaus builds, this is the preferred foundation type for several reasons.
                        I think you would be surprised at the EPS insulation thickness under-slab... up to 14". Of course, this varies considerably with different climate zones. (We are in Quebec with winters where -40ยฐ is not unexpected)
                        There are modular slab insulation systems for FPSF. Iso-Slab is a Quebec-based one: http://www.iso-slab.com. Their web-site has technical info on these systems that may be of interest to you.
                        • medeekM
                          medeek
                          I've had a request for adding the option of insulation around a slab on grade, in short a frost protected shallow foundation (FPSF).
                          This should not be too hard to add in. There are a number of resources online I will study to come up with the most standard configuration as possible.
                          Are there any particular things anyone would like to see with regards to FPSF insulation.
                          The typical installation per the 2015 IRC:
                          The NAHB has an upated publication at this link:
                          http://liteform.com/wp-content/uploads/2017/04/FPSF-Guide-Revised.pdf
                          XPS vs. EPS? Not that this will affect the plugin but I am curious which is preferred by those who commonly install these types of systems.
                          design.medeek.com
                          • medeekM
                            medeek
                            An FPSF with 2" foam insulation along the wall and vertically. 2.5" foam insulation at the corners with the following horizontal dimensions:
                            A = 12"
                            B = 24"
                            C = 40"
                            http://design.medeek.com/resources/images/foundation_su45_800.jpg
                            The rectangle foundation is easy, the polygon shaped foundation will be more challenging.
                            View model here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            One thing to note is that if dimensions A or B exceed 24" then some form of protection for the horizontal insulation is required (ie. conc. slab, pavement, PT plywood).
                            design.medeek.com
                            • medeekM
                              medeek
                              An irregular shaped FPSF, note the 135 deg. corners. Once this angle becomes greater than 135 degrees I would probably just treat it the same as a straight wall.
                              http://design.medeek.com/resources/images/foundation_su46_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.3 - 06.03.2017
                                • Added "FPSF" option to rectangular slab-on-grade foundations.
                                • Added "FPSF" option to rectangular stemwall foundations.
                                • Added an insulation layer in the global settings under the "Layers" tab.
                                http://design.medeek.com/resources/images/foundation_su47_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  http://design.medeek.com/resources/images/foundation_su48_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Working on the square/rectangle spread footing tool:
                                    Post Footing
                                    I will start with wood posts as an option with the following sub-options for the wood post:
                                    Post Size: 4x4, 4x6, 6x6, 6x8, 8x8
                                    Post Height (in.)
                                    Post Base: None, ABA, ABU, ABW, CBSQ
                                    Post Cap: None, CCQ, ECCQ
                                    Post Rotation: 0, 90, 180, 270
                                    I also plan on having the option for steel posts with the following sub-options:
                                    Post Size: HSS4x4x1/2, HSS4x4x3/8, HSS 4x4x1/4, HSS3x3x3/8 etc... (round and square tube)
                                    Post Height (in.)
                                    Base Plate Size (in.) - square shape L x L
                                    Base Plate Thickness (in.)
                                    Base Plate Hole Dia. (in.): 1/4, 3/8, 1/2, 5/8 (4 bolts per baseplate)
                                    Vert. Offset (in.) - for non-shrink grout
                                    Post Cap: Not sure what to do with this yet.
                                    http://design.medeek.com/resources/images/foundation_su49_800.jpg
                                    http://design.medeek.com/resources/images/foundation_su50_800.jpg
                                    I've been contemplating using the Simpson Strong-Tie post caps and bases as provide in the warehouse but I'm worried that the polygon count is too high. I may have to generate my own dumbed down versions.
                                    http://design.medeek.com/resources/images/foundation_su51_800.jpg
                                    My 13 year old daughter asked, "What is this for? What good is it?". I replied, "It is good for all sorts of things, just like a Thneed." Then I proceeded to discuss decks, porches, carports etc...
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Added "FPSF" option to polygon slab-on-grade foundations:
                                      http://design.medeek.com/resources/images/foundation_su52_800.jpg
                                      design.medeek.com
                                      • jujuJ
                                        juju
                                        Can you do that with the option of putting it (as a vertical component only) on the inside of the foundation wall? It may be of use in climates that isn't as cold and you have the option of putting it either inside or outside of the foundation plinth wall.
                                        • medeekM
                                          medeek
                                          I can add another option to insulate the vertical interior face of the stemwall/foundation wall.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Working through the issues of the polygon FPSF option has helped me understand better how to deal with adjacent walls in particular non-orthogonal walls and how best to calculate the geometry at their intersections.
                                            This has me primed for further development of the wall plugin, so even though this feature may not have much use for most of the client base it still have served a major purpose in educating me.
                                            With the tool function I am able to create lines to show preview geometry however I am wondering if there is a way to show a dimension (beyond showing the numerical value at the bottom of the SketchUp window).
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 7 / 23
