    WrapR 1.1 Beta Trial
    extensions
    32 Posts 9 Posters 20.7k Views 9 Watching
      rv1974
      My most most primitive example added. Notice that Wrap-r skips some diagonals for some reason (don't know whether its good\bad\neutral thing). And it keeps scaling maps up.
      P.S. So happy to hear projection method is on the way! Hope it will be released simultaneously with Retopo plug-in in near future!
      Untitledjjj.skp
        OK, I see the issue.
        Your mesh has all internal edge set to Smooth, Soft, Cast Shadows off. So this is not a true quad face. When you fix that then WrapR can read the faces as Quads...
        Turn off Live Unwrap when you are straightening UVs to make the process easier.
        • O Offline
          oalexis
          I'm having a bit of trouble. I UV'd most of my model then saved and said yes to continue, and when it reloaded the model, it was back to its default state. Am I doing something wrong? Also how do you install the plugin to work inside of sketchup? Thanks
            rv1974
            Right click menu: 'Reload from Wrap-R'.
            • JQLJ Offline
              JQL
              Yup we would benefit a lot with an auto reload on sketchup side. Undo would return the mesh to original state.
              www.casca.pt
              Visit us on facebook!
                what is the big benefit?
                • JQLJ Offline
                  JQL
                  Not having to right click reload, allows for faster workflows:
                  1 - Mark seams on Component#1; Component#2; Component#3; Component#4...;
                  2 - Send to wrapr, assume auto unwrap, save and close.
                  3 - Reload happens automatically;
                  4 - Repeat step two for each component;
                  I intend on using wrapr for such things like multiple windows or doors, or multiple beams in a roof. It's a tedious workflow and any step you could provide to easen the burden would be welcome. That right-click is one such step.
                  I also like when I use sketchup to send a texture to my image editor and it's automatically switched on SU when I save it there. It's not much, but always causes a nice impression on me.
                  www.casca.pt
                  • O Offline
                    oalexis
                    There is no right click menu within the wrapr application that I'm aware of. I did all the cuts and unwrapping in the standalone wrapr application. The save button says it saves and then gives you the option to continue working and it reloads the mesh, but it reloads the original without any of the changes to the UV map.
                    As a separate problem the pluging within sketchup does not seem to install for me. Using the rubyinstaller.exe in the folder brings up an empty list of components to select from and says install components.
                      What version of SketchUp do you use?
                        Gábor
                        Could you please send me a screenshot how the rubyinstaller.exe shows up when you start it separately? Also: Do you get any error messages when you start it up?
                        • O Offline
                          oalexis
                          I had an older version installed, that was the problem so I updated to the latest version and the plugin installed. Now, however after making the cuts in sketchup, and sending it to wrapr it doesn't automatically open wrapr. It creates the component then does nothing and if I try to open the file manually in wrapr it tells me it can't open files with components, so then if I delete the component it opens but doesn't keep any of the cuts I made within sketchup.
                            Gábor
                            @oalexis said:
                            ....and sending it to wrapr it doesn't automatically open wrapr.
                            Please open the ruby console before sending to Wrap-R. Are there any error messages when you try to send?
                            • O Offline
                              oalexis
                              It comes up with this error.
                              Error; #<TypeError; no implicit conversion of nil into String>
                              c;/users/oalexis/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/wrapr/wrapr-loader.rbs;156;in `exist?'
                              c;/users/oalexis/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/wrapr/wrapr-loader.rbs;156;in `run'
                              c;/users/oalexis/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/wrapr/wrapr_run.rbs;28;in `block in <module;Loader>'
                              SketchUp;1;in `call'
                                Gábor
                                Thank you very much for the information. Soon we will be out with a fix for the problem. Just one more question: Did you change the default install path of Wrap-R when you installed it?
                                Sent from my SM-G935F using Tapatalk
                                  Gábor
                                  Wrap-R 1.1.3 Beta is available now and can be downloaded from the link:
                                  https://s3.amazonaws.com/wrapr-download/WrapR-installer_1_1_3.exe
                                  Changes since 1.1.1:
                                  • Several error fixes including the problem with the plugin spotted by @oalexis
                                  • Now the unwrapped SketchUp model can be saved as ".obj" or ".dae" file as well
                                  • The installer will not require to remove previous install, it will simply overwrite the previous install files.
                                  • JQLJ Offline
                                    JQL
                                    Excellent feature as Sketchup nativelly deals well with .dae
                                    Thanks once again Gábor!
                                    www.casca.pt
                                    • SJS66S Offline
                                      SJS66
                                      [*]The installer will not require to remove previous install, it will simply overwrite the previous install files.[/list]
                                      Just went to install the new version & SketchUp still says it's using 1.1.0. What's the best way to install the latest version? When I go to Add Extension in SU Preferences>Extensions it wants a .rbz file which I can't seem to find. Where's the installer file we should use to install the new version?
                                        Gábor
                                        Where do you see the version 1.1.0? In the SketchUp Plugin or on the standalone Wrap-R program's window title line?
                                        The installation should work like this: You start WrapR-installer_1_1_3.exe. When the installer displays the ruby installer window, you select from the list the SketchUp versions you want the plugin to be installed on. When the installation of Wrap-R is finished, you restart SketchUp and you should see the new plugin there. If it was not working this way then it means a malfunction.
                                        To be able to track down the problem, please give us some more details:
                                        • Did you do the installation as described above?
                                        • Is the standalone Wrap-R application version number in it's window's title line correct?
                                        • If yes, where do you see the 1.1.0 version number?
                                        • SJS66S Offline
                                          SJS66
                                          How do you rotate the model in WrapR? I can move it side to side with my right mouse button but can't seem to rotate the model to see all sides.
                                          Don't worry, I hadn't mapped my middle mouse button for WrapR. Now I have, all good.
                                          I reckon some more detailed help files are required for noobs like me. A .PDF format user manual would be handy. Some of us rural Aussies don't have the most reliable internet connection & can't always rely on online help.
                                          • PepetrucciP Offline
                                            Pepetrucci
                                            Hi guys!
                                            I just get back to testing Wrap-r since a couple of very busy weeks, and when i try to activate the new beta license (date 2017-06-08) on the current 1.1.3 installer it shows me the ERROR_A0C
                                            Does anyone have a clue about why is this happening? I have tried on a fresh SketchUp Pro 2017 and 2016 installs, Windows 10 64bit. Previous versions worked flawlessly.
                                            Thanks in advance!
